Brand new bike, broken bottle cage bolt/thread.
Hi everyone,
Bought my daughter her first geared bike today! First thing i do is attempt to attatch the bottle holder and find the bottom bolt just spins with its thread. The thread is not attatched to the frame!
Obviously the bike will be returned first thing.
But do i request an new undamaged frame? Is that pedantic? I have written down the frames serial # so i will know.
I suspect they will simply locktite the thread to the frame or something similar.
Cheers Guys
Pete
Cheers Guys
Pete
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Liked 277 Times
Take it back to the store. Easy enough. And yes request a new undamaged frame, don't let them try to bully you into accepting a repaired bike. If you bought the bike at Walmart or some similar place they'll just exchange the bike.
Liked 1,102 Times
+1 These are easy to tighten and should cause no problems if done properly. A search here will give you directions on how to do it yourself if you don't want to make another trip to the bike shop.
Liked 277 Times
The above is not necessarily true, at least in part. Factories have defects all the time from low to high end bikes, and in fact most high end bikes come out of the same factory low end bikes were made at, and China does not have a stellar record for quality control. I would return the bike and not accept an issue even though it's relatively minor. The new bike you get will probably not have that issue.
It may be true you can get a better bike by paying another $300 extra, but if you can't afford another $300 then just get the one you had.
Liked 277 Times
So just accept things as they are, and don't bother making any warranty repairs or replacements.
rivnut loose is not warranty as in the manufacturer will replace the whole bike. generally the shop will eat it and replace the rivnut themselves. hell i replaced the thing for free for others before
Liked 277 Times
Ok, that's fine, then he should take the bike back to the LBS and get it fixed. I thought he bought the bike from a big box store and not an LBS, big box stores won't fix anything they will just replace the bike as defective.
