Wheel Circumference Measurement for Garmin Edge 500
Old 04-26-12, 09:41 PM
Tall Cool One
Tall Cool One's Avatar
I am in the process of setting up my Garmin Edge 500. I have a 700c wheels and run 25 mm Continental GP4000s tires. My best effort at measuring the diameter of these wheels was 680 mm. Hence, the circumference would be 680 x 3.14... which comes out to 2136 mm for the circumference. Is that within the proper range for this setup?
Tall Cool One is offline
Old 04-27-12, 09:24 PM
Giro
Better yet, take a bike ride on a measured course and use the late, great Sheldon Brown's method. Google maps and the like make it relatively easy to set out a measured course and you get probably the most accurate calibration for your weight, tire, pressure, and courses you will ride in the future.
Giro is offline
Old 04-28-12, 12:10 AM
znomit
Zoom zoom zoom zoom bonk
znomit's Avatar
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Liked 740 Times in 377 Posts
The edge works out the wheel size for you using the GPS.
znomit is offline
Old 04-28-12, 12:15 AM
mechBgon
mechBgon's Avatar
Liked 6 Times in 5 Posts
Alternately, just measure the effective circumference the obvious way: mark the tire, line that up with a mark on the ground, sit on the bike and roll it forward one revolution. Make a second mark on the ground where the tire's mark ends up. Measure the distance between the two marks.
mechBgon is offline
Old 04-28-12, 12:26 AM
Shimagnolo
Shimagnolo's Avatar
Liked 5,651 Times in 2,932 Posts
^This.
Shimagnolo is online now
Koonstheman
30
09-08-17 01:32 PM
dalava
Road Cycling
15
11-19-16 01:20 PM
himespau
3
05-21-14 05:25 PM
Sasquatch16
1
04-13-13 05:45 PM
Kolelo
Road Cycling
12
07-01-10 11:43 PM
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
