9speed shifter 8speed cassette
Looking replace my down tube shifters which are friction only with something that has both. Checking the bay there are a few 8speed friction/index (sis) that pop up, but more 9speed options (DA-7700) . I like the gearing on the Shimano 8sp cassette so would prefer to keep it, I've poked around on the forums and get a lot of conflicting comments -- can anyone confirm the success with indexing 9sp shifters with 8sp cassettes? Perhaps using the alternate cable routing Sheldon recommends here?
https://www.sheldonbrown.com/dura-ace.html
notes: dual chain ring so not an issue, rear derailleur DeoreLX m581
Thanks.
Thanks.
Not what you asked, but you can get new Shimano 8 speed downtube shifters for $29 from Ribble. 8 speed bar ends are $63.
6,7,8 all have the same indexing spacing anything nore 9 or 10 need to use indexing specific for those speeds.
The only way you might get away using it with other than it was made for is in friction mode. 8 levers in friction mode may work on 9 if it has the extra movement to travel the distance for the last cog some do some don't same from 9 - 10 friction only.
The only other way to get indexing with a mix it using something from problem solvers, but if that’s the case just buy a 9 speed cassette for the 9 speed levers and forget about it if your wheel will take one.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Liked 732 Times
This is a piece of piss. It's the first combination listed for the ShiftMate model #2.
I have a feeling running a ShiftMate will also result in crisper shifting thanks to a shorter and less curved rear housing.
