Burley trailer: excessive tire wear?
Certifiable Bike "Expert"
What kind of tire life are you seeing with your Burley trailers?
I have an Encore, one of the last of the old US-built design. Sort of a stripped-down D-lite. I've just worn the second set of tires down to the cords. I pull it fairly regularly, but I'm hardly a fanatical trailer user. I'm guessing I got less than 1000 miles from each set of tires.
This trailer is designed (?) so that the wheels have a bit of inward camber,
kinda like this: /--\. I'm guessing that's why they wear out so fast...?
Anybody else?
Anybody else?
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
The negative camber is causing the excessive tire wear. Fixing the problem may be tough to do, as something is bent or the trailer is chronically overloaded.
I'd suggest putting on a decent set of tires. I run Scwalbe Marathon Racers on my Nomad and have 5,000 miles on them and counting. They still look perfectly good, and I haul a pretty heavy load. The camber shouldn't be very severe (mine has the same thing) and I doubt that is your problem.
Bikes: Trek 800, Free Spirit Town and Country, 80's Norco Nomad
Yes...this is an alignment issue given they really shouldn't wear out at all. Like said earlier, not sure how to fix it, maybe a shim can be fabricated.
I wouldn't expect the camber to be that big an issue. It'll cause wear to the tread more to the inside than right in the center, but that shouldn't make the tire wear out so quick. Wonder if you might have an alignment problem with toe-in (or toe-out) which would cause some scrubbing action on the tire and also increase the rolling resistance. Measure the distance between the two wheels right at the front and again at the back to see if the two readings are different.
The brand of trailer you're pulling probably doesn't have anything to do with tire wear. Doubtful that Burley's magically wear out tires faster than others.
Trailer wheels, like sport wheelchairs, often have a camber in order to make it harder for them to flip over in corners. You are correct by assuming stability is the reason.
Spend a buck or two and put on some quality tires and I'm thinking you'll see much better mileage.
Thread Killer
Liked 1,931 Times
Excessive tire wire is usually a result of under-inflation.
If the problem is camber, you could swap sides with the wheels (if that's possible--I don't know that trailer) or remount the tires so they lean the other way. We have a lot of steeply cambered roads here, and road tires wear on the left side because they're effectively on a sidehill all the time. Some people say it's dangerous to rotate them, but I've done it for 30 years with no problems.
Bikes: Borealis Echo, Ground Up Designs Ti Cross bike, Xtracycle, GT mod trials bike, pixie race machine
I don't think a little camber would do much for tire wear. What I WOULD check though would be the amount of toe the wheels have. If there is excessive to you will just be scrubbing away the tires as you ride. It sounds like you are familiar with the different alignment angles but if not, measure how far apart the front of the tires are compared to the rear of the tires. Also make sure the hubs are in good shape because that could cause you to scrub the tires as you pull the trailer.
Thread Killer
Liked 1,931 Times
I will be shocked--shocked!-- if this has anything to do with camber or toe issues. I think the likelihood is extremely low, first because bike trailers don't have adjustments for those settings, and it's a Burley USA made, legendary for quality, so probably not a production flaw.
Any hub failure to cause uneven wear would be obvious; you'd feel that right away. I doubt it's that.
OP: what do you inflate to? Do you check periodically with a gauge? What type and brand of tire?
As for wheel adjustments, no, there is no mechanical means to do it, but if things are bent, they need to be unbent. Toe would be the big issue, in or out, it's going to erase tread.
Thread Killer
Liked 1,931 Times
Yeah...um, in today's world or shifting factories and layoffs, you can never ASSUME quality...that's like saying a Cadillac is the king of cars...they once were, but that ship has sailed a long time ago. It all starts somewhere.
Regarding bent wheel mounts, knowing how the Burley's are built, I think that's an extremely unlikely scenario.
IDK I have a Burly Trailer The 2 406 wheels are dished, for wider track , But
they are not cambered, something is Bent if they are not straight up&down .
its a CoOp made Flat bed..
I heard the CoOp was driven into the ditch by a hired Manager-CEO,
who bought the company privately at the Bankruptcy.
and is responsible for the Job Offshoring, making Them.
Thread Killer
Liked 1,931 Times
The scrub angle, An offset viewed vertically, (like toe in/out)
not being at right angles to the centerline of the trailer.
would have potential tire wear..
Camber if axle is square to direction of travel. would only move the contact patch A Bit.
have you analyzed the tire wear pattern..?
Decent car mechanics have done that for a long time..
