Holy crap Kettlebells are awesome!
Bikes: Cannondale CAAD-10
Well, I've been dreading the crappy weather that will reach me here in Washington any day now and likely last until around June of next year (not even joking!). I rode in the cold and rain last winter but it sucked and wasn't fun. I was looking for a different workout for crappy days. I tried the "Insanity" workout and found it to be a bit too intense for me. I was listening to the Joe Rogan podcast the other day and he was talking about how his entire workout is with just 1 kettlebell. And that dude is ripped! So I bought a 25 pound kettlebell that came with a DVD. I tried it out today and I had to tap out about 15 minutes in! It's mostly doing squats and lunges while swinging the bell in different ways and after squatting nonstop for 15 minutes my chest was burning and my legs felt like jello! Kettlebells are supposed to be great for core strength and abs. I can totally see that as it feels like I did a hundred crunches! I'm gonna try to keep up this workout and hopefully get to where I can complete the entire 50 minute workout. I'm still a little shocked that 1 25 pound kettlebell has kicked my butt this much!
Bikes: Salsa Vaya, Fuji Aloha, Giant OCR2, an older Giant XTC, and a couple of singlespeeds
I completely agree - I took some Crossfit classes for a while, and they were all about the kettlebells - I became a big fan. I'd like to eventually buy some for home use.
I took a look at an online workout and it looked pretty intense. I think that I could get the same workout with a 5 lb dumbbell. I might be able to work up to a higher weight but 25 lbs seems to be pretty heavy to me. Also like mentioned the deep squats might be a problem for the knees. Younger fellows can probably just dive in and hit it hard. For us older guys it might be better to just ease into the program of this different exercise.
It is interesting enough that I will probably have to grab a dumbbell and do some experimenting.
Lover of Old Chrome Moly
squats make my already bad knees want to scream
Bikes: Felt Z85
I was going to post something about kettlebells here but thought I'd just bump this thread.. they'd be great for cyclists though I'm using them as part of the 'four hour body' to build muscle in lieu of deadlifts. Proper form is important. They really work the core which is why I mention this exercise here.
Here's a video on proper form and how to make your own kettlebell setup where you can use weights. I used 3/4 inch inner diameter and weight with a one inch inner diameter hole fit perfectly. Then I just use a piece of microfoam tape which I can get for free at work and it holds all the weights in place, though you may want to try something more sturdy. Anyways the videos
The Perfect Posterior: Kettlebell Swings and Cheap Alternatives
You should be able to find the pieces to make your kettlebells at home depot or a local runnings fleet farm type store, otherwise you can order the "Hungarian Core Blaster", which is basically the same thing but costs more, online.
Another site that shows the homemade kettlebell setup, though I would recommend the 4 inch length for the handles, the 6 inch are wider than necessary. Also if you can find some free caps to put on the ends of the handles, which my store had on some larger length pieces, it's a free way to cover up the threading.
Setup works best with 10 pound (and 5 pound) standard cast iron plates by cap barbell, with the one inch diameter inside holes.. I personally find the large vinyl weights the author of the below site uses a bit annoying. With 10 pound plates you could fit 120 pounds on one, but a road biker won't need anywhere near that much weight.
https://ianrobertanderson.com/diy-adjustable-kettlebell/
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Liked 459 Times
That's neat. Kettlebells are a serious workout. Great for those rainy days.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Well, I posted this thread a while back. Interesting to see it resurrected. I have maintained a kettlebell routine as part of my regular workout regimen since I posted this thread. At the time I posted this, we were well in to the 9 months of rain we get here in Washington, so I wasn't doing much cycling. Instead I would run at the gym on the treadmill, lift weights, and 1-2 days a week I would do a kettlebell routine. This spring when the sun finally came out, I hopped on the bike expecting to be sluggish and slow from not riding for several months. I was pleasantly surprised when I felt like an absolute beast on the bike! Especially in the hills. My average speeds didn't drop at all and it used to be if I stood out of the saddle and pedaled, I would be gasping for air within seconds. Now I'm powering up hills that used to kick my ass. I'd have to say that is 100% due to all the kettlebell squat/swings I've been doing.
Bikes: Felt Z85
something of note, the correct form of doing the swing is not entirely correct in the video I posted... the neck should remain neutral with the spine, meaning on the downswing your head/neck should be neutral with your spine and not bent looking upward straight ahead like he was doing it.
![](https://chroniclesofstrength.com/uploads/2/7/4/1/2741964/3310402.jpg)
Key Aspects of the Kettlebell Swing
A kettlebell workout with the right weight as as intense a cardio workout as sprinting, you can find yourself gasping for air sprawled out on the floor when you are done, it also builds muscle like sprinting does. If a person could only do one exercise the rest of their life, I'd pick kettlebell swings or squats. I do sustained moderate pace jogging because I enjoy it, but from what I've researched there's not much benefit to be had from it.. though there's not much benefit to be had from extended road biking sessions either, it's high intensity interval pacing that really brings the most benefit for the least time... but I like biking, so I won't give that up either.
- Your back is flat, and your head stays inline with your spine throughout the movement
- Your weight is on the heels of your feet, and your knees stay in line with your toes (they never collapse inward or extend outward)
- You engage your lats(back and armpit muscles) to keep your shoulder pulled back and down into its socket
- There is no forward knee movement, your knees bend only as much as your butt goes back
- This is not an arm exercise! Your butt, hamstrings, and lower back power the movement entirely, your arms never lift the bell
- You stand straight up at the top of the swing, never leaning backwards. Your knees and hips are locked out as well
- Swing high! The kettlebell handle never passes below the knees
![Smilie](images/smilies/smile.gif)
The Left Coast, USA
If you want to add a little adventure to your kettlebell swing, stand on a BOSU ball..flat side up. I've seen one routine where you jump from the floor to the BOSU (round side up) at the bottom of the swing, and jump back again after two reps, alternating between floor and BOSU as your platform. Obviously, not a safe routine for everyone..and you can't get a wide stance unless you use two BOSUs.
