80s Sugino cranksets vs. Modern cranksets
Hey everyone,
I've been slowly gathering the parts I need to build up a VO Campeur, but lately I've been on the fence about my crankset. I have a Sugino GT crankset 26-36-46 on an old touring bike ... I'm thinking of using that on my new bike even though it's older and has some obvious signs of use. However, there's a part of me that's tempted to drop 150-200 on a new crankset--maybe a triple from Velo Orange or a Sugino XD or something similar.
My question is this: is there a functional difference between an older touring crankset and a modern one? Is it worth "upgrading" or should I just stick with my old crankset until it wears out? Oh, and I plan on using this crankset with 8-speed friction bar end shifters.
Liked 2,007 Times
As long as it's not worn, and the spacing is such that an 8-speed chain won't fall down between the chainrings, it should work just fine.
Bikes: 1983 Trek 520, early 80's Univega Gran Tourismo, '98 Santana Arriva, '71 Dawes Galaxy, '77 Peugeot UO10
Chainrings are the parts of a crankset that wear out and they can be easily replaced. I like the sizes of those on the OP's Sugino. I put a 24 for the granny ring on mine.
There are some advantages to cranksets that use external bearings. They're stronger and the bearings are cheap to replace. You also don't need a crank puller, - maintenance or emergency repair is easier. A 5mm allen key is typically all you need. It's also easier to use spacers to optimize chain line.
That being said, if you've been happy with your Sugino, there's no reason you'd need to replace it.
Liked 326 Times
Had the self extractor ring push the threads out, rather than budge the crank arm.
so might be a good idea to use a regular extractor,
if you don't know how tightly affixed the arm is to the spindle.
working on my sandal tan
Liked 2,579 Times
I think the most noticeable difference is that the new chain-rings will have ramps and pins to aid in shifting. Most 80's stuff assumed friction shifting, not indexed. OTOH, if your build is using friction shifting for the front, I don't see any practical difference.
In the right lane
I'm personally confused about why anyone would want to have an indexed shifter for the front. The ramps and pins are great, but 6 clicks often isn't sufficient.
I love modern indexed shifters but yeah I agree, especially for a double. It seems to have taken nearly 3 decades for indexed shifting on the front to work as well as friction did.
I agree that it does take a bit of skill to properly set up an indexed front, but I've never had the range of indexed shifts and trim be insufficient for nice clean shifting.
In the right lane
Oh well, you can't stop progress!
![Smilie](images/smilies/smile.gif)
In the right lane
High-end Suginos are great. I have a swaged Sugino crank on my old Fuji road bike (I think the crankset is from 1982...) and it seems like they are bent. Very slight, but very annoying too.
A one-piece spider would be great.
Mad bike riding scientist
Liked 4,338 Times
Using spacers is not possible with most external bearing cranksets installed in the bottom bracket width they were designed for (68mm for road). If I added a spacer of any sort to mine the left crank wouldn't bottom correctly on its shoulder. The spindle also can't be changed for a longer one because it's permanently bonded to the right crank.
It's not just about the stiffness. The ease of installation is a very large difference and advantage. That it is stiffer is just a bonus.
Stuart Black
Stuart Black
