Fattest tires on an Ironman?
Chainstay Brake Mafia
What are the biggest tires you've been able to install on a Centurion Ironman? I don't mind going with mismatched sizes even. Using 600EX short reach brakes
I've got some 700x23c but after riding fat 26x2" tires, they feel like i'm riding on the bare rim. I'm wondering if a slightly bigger tire would make a difference, though I'm not sure if it would be a big enough one
the weird thing is I used to ride this bike often and not really mind the harsh ride.. I can't really figure it out. i do think installing the ass-hatchet saddle might also have something to do with it too tho
Bianchi Goddess
Liked 3,128 Times
One of the Dave Scott Ironmans? I would be suprised if you could get much more than a x28 but depending on your weight you should feel a difference. Something like Pasela should give you a nice ride. Be careful though, what works in the stand may not work when you ride it.
Sugar "Kane" Kowalczyk
![lol](images/smilies/lol.gif)
i doubt many folks have tried out these tires: https://www.cswestbikes.com/servlet/t...FSmCQgodNB0ANg
![](https://1mg.me/?f=BPUserPhotos&filename=283733_0.jpg)
only looking at them cause they match my color scheme, though i suppose that's not a very good reason to pick tires
working on my sandal tan
Liked 2,579 Times
In this situation, I like to use allen wrenches as feeler gauges to find out where the tightest spot is between the frame/components and the tires. On my road bikes, it's usually been the fork crown. For example, if you can only fit a 3mm in between the tire and fork crown, then you'll probably be able to run 700x25, but not 700x28.
Cat 6
That fyxation tire - I'm wary of any tire that doesn't advertise their thread count. It's not the only thing, but higher thread counts usually ride nicer (more supple).
The current Vittoria Rubino Pros (III's?) can be had in a nice green. (150 tpi, about as low as I'll go). I'm not sure they come in a 28, though.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
i might just need a better saddle and to stick to better paved roads.. not sure, but I'd like to start riding the bike again
Liked 2,579 Times
Based on some Googling, it looks like the Fyxation is 120tpi.
One thing to keep in mind about the tires marketed to the fixed-gear crowd is that the tread will be thicker (mad skidz, yo.) That means you'll either have less clearance at the diameter than you'd expect, or the tire will be skinnier than normal to make the diameter work out right.
I've installed a few of the Fyxation tires at my LBS. They have a very thick tread and are heavy. You have to decide what balance of ride quality, flat protection and price you're most comfortable with.
Jan Heine has this to say about TPI, though using to TPI numbers to qualify other tires seems a bit like talking out of both sides of his mouth.
TPI (threads per inch) is a meaningless number. It’s easy to quantify, and so some companies like to use it in their ads. We tested a two Grand Bois prototype tires, identical except one had twice the TPI. Their speed was indistinguishable. What appears to matter more is how many casing layers you have, at what angles they are overlaid, what material is used for them, how thick the tread is, how hard the tread is, and whether the tread is vulcanized or glued by hand.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
SNARKY MEMBER
If you want a bike that has the same ride as a mountain bike, you have the wrong bike. That is like buying a Porsche and expecting it to have the same ride as a Cadillac. I doubt you will be able to get anything bigger than a 25 on that bike. What air pressure are you using?
My 85 takes 28 Vittoria Rando's easily, but it's a first year model. Later years may have less clearance. I've put modern wheelsets and 25's on MV models.
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
I'm hoping another week of dieting and i won't be eligible for the clydesdale forum any more ![lol](images/smilies/lol.gif)
especially if they're $50/tire
Your's is an '89, and probably has the least clearance.
If I go to L'Eroica, I'm taking my '86 Ironman, with non-aero DC levers vs. the OEM aeros. They recommend a larger tire, so I'm quite happy to know I can probably run Gatorskin 28's on it.
hmm if i can only go from 23 to 25 then i don't see much point. a 650b conversion would be cool but if i'd rather just go for a different bike rather than buy 650b wheels and proper brakes.
I think i will have to find a better saddle and maybe that will help.
There are shorts available from China that have a chamois that's bigger than a car wash sponge...... Just sayin.
