Planet X CNC brake calipers (Pictures and info)
King Hoternot
Bikes: 2015 Cannondale Evo Hi mod
Quoted: 127 Post(s)
I just got a set of Planet X brakes from the US headquarter warehouse. I had been researching brakes for a long time but didn't feel confident ordering any of them without feeling or testing them first. I found out that Planet X was based in Portland, OR which is about 15 miles form where I live. I went down and asked if they had any bikes built up with the brake calipers that I could test. They brought me back to their warehouse and let me check out a couple of their bikes. I told the tech that I did not want a dual color though (Original black set is black with a red cam arm). She had a set that she dismantled earlier and said she could put the black cam arm for me which would give me what I was looking for. She also threw on the green swiss stop pads instead of the stock pads that come with them. They were SUPER friendly and wanted to go the extra mile to help me. I told her that I had read about these brakes being difficult to center/install correctly. She said she would install them for me if I needed her to, so I ran home and got my bike. Brought it back and she took it to the back room and set it up. She was very detailed with the install and adjustments. She also took the time to true my rear wheel The quick release seems to have been such a big issue that i thought i would clear the air and tell you it isn't difficult at all. I took some pictures and posted below to show you the process. Literally takes 3 seconds. With a correct set up and green swiss stops, they feel just like my ultegra 6700 calipers. They rate them at 205g, but when she weighed mine they came in at 193g! My ultegra 6700 calipers are 319g just to compare. For $109 they are a great option! When I got the bike home I went on a quick 5 mile ride and they felt great. I didn't notice any difference between these and my ultegra brakes, so for those of you who are using tiagra, tektro or apex and looking for a good brake upgrade this is something i could recommend, especially at a great price! Even if you have an ultegra, DA, force or red and want to save some weight, these will do the trick for sure.
There has been a lot of questions regarding the caliper not having a quick release. This was a concern of mine because there were several people talking about it being some drawn out process or big deal. When I asked the tech about this, she showed me how their system works and it was super easy. Dont really understand what the big deal was. I took some pictures and have included them below to show exactly how it works
IF you are interested in purchasing a set and wanting to see if they will swap out the cam arm, PLEASE do me a favor and DO NOT use me as an example. I would recommend you ask out of curiosity if they can do this for you, but I am sure they do not want to make this an option for each set purchased. I plan on doing doing some work with them in the near future for their grande opening for their showroom with my company and dont want any issues. Thank you.
Here are a couple pictures that will hopefully help give you an idea how to use the planet X quick release
There is a Cam arm that lifts. The cable has a "stopper" attached to it that fits under the cam arm.
Pull up on the cam arm and push down on the "stopper"
SkinnyStrong
Wow, thanks for the write up. I've been looking for new brakes - I actually don't like my Ultegra 6600's, they feel old - I think these will be my next set
Bikes: 2014 Felt F2 2015 Specialized Tarmac Sport
These are great brakes, I just upgraded about a month ago. The lack of a quick release is not that big of a deal. I got the all silver ones with the black actuation arm. They are comparable to my 5700 105's maybe slightly better. They look great bianchi10.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2741 Post(s)
Liked 3,342 Times
however im not against aftermarket brakes at all as I have magnesium TRP R970 SLs on one bike. I've been interested in these planetX CNC brakes for a while as they seem to get good testimonies.
"Your beauty is an aeroplane;
Throw the stick!!!!
I've been using these for a couple of years now, I have them on two bikes. I am very happy with them, I like them as much as the ZG's I used to use at a fraction of the cost.
I may be fat but I'm slow enough to make up for it.
Bikes: MTB: Stumpjumper FSR, Road: De Rosa King 3
Thanks for the review. I just ordered a pair. These will go very nicely on the De Rosa!
They look much better in all black. The red arm makes the black ones look cheap. They really should make it an option.
I was considering these at one point and was told that the return spring is stiffer than DA7800. Do you guys with them agree? That kept me from using them as I prefer light action brakes.
King Hoternot
Quoted: 127 Post(s)
I have little experience with mine so far, but I think they are lighter than DA and roughly the same as ultegra Maybe a little bit "squishier" than my ultegra, BUT when I say that I mean a very small amount I mean that. These seem to be a responsive brake set, especially paired with the swiss stop pads.
toasty!
Bikes: 1998 Cannondale r200, 2011 Bianchi Via Nirone 7; 2007 Redline Conquest Pro
Dang, those do look sharp. Sound like a steal, too.
I like beans
Bikes: Tarmac Pro, Bianchi Zurigo, Raleigh Gran Sport, Fuji Del Rey, Ironman Centurion
Nice little writeup. Might give these a run after reading.
SkinnyStrong
Are brakes in general meant to be serviceable? I pulled apart a brakeset once and the set screw that keeps the pivot screws in place messed up the threads. Even though I loosened the set screw it felt like it was grinding away at the threads of the brake-arm as I was taking it out. I can't imagine that can be done too many times before the screws just don't hold anymore.
King Hoternot
Quoted: 127 Post(s)
Wow, those are rad looking.
https://www.pedalroom.com/members/iamtim
I like beans
Just ordered a set of black and reds for my Ti bike. thanks.
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Is the cam arm (that's usually red) aluminum?
Wondering, cause I may de-anodize them if they are.
Throw the stick!!!!
Just for the heck of it.
King Hoternot
Quoted: 127 Post(s)
Yeah I saw that with a couple members at weightweenies. Might look into other options. Right now my prioritybisbto look at expander plugs. Like the ultra star but I don't know if it will fit. Otherwise ill get the new 2013 cannondale plug that is only 12g as apposed to the stock fsa one I have now which is 50g. Just ordered veloplugs today Also, hope to get those by end if week so I can install my ultra light tubes and new lighter tires.
King Hoternot
Quoted: 127 Post(s)
THANK YOU!!! appreciate the heads up, just grabbed one.
King Hoternot
Quoted: 127 Post(s)
Throw the stick!!!!
I'm one of those guys that never opens a brake's quick release.
