What Winter jacket do you own/wear?
I've been looking for a replacement for my Louis Garneau Massimo 2 --- it's an excellent jacket (can survive the winters in the north east paired with UA Cold Gear turtleneck) but it's American cut. I also got a Nalini Pike jacket but bought a size too big I'm now using an old Castelli jacket which is more geared for fall weather but I'm braving it out.
Just wondering what everybody's using.
Carpe Velo
My warmer riding jacket is a performance Wind Jacket. Why they call it a wind jacket, I don't know, as that suggests it is a windbreaker and it is actually a relatively thick, fleece lined riding jacket. Easy to access rear zippered pocket, waist pockets, and a really handy left chest pocket.
Bikes: Specialized Roubaix SL4 PRO 105
Thanks guys.
I'm currently eyeing the Castelli Espresso Jacket and Gore Tool Jacket (apparently, it's the same as the Xenon SO and Power SO? Can anyone clarify that?)
I can find the Castelli in the colour I want but it's $70 more than the Gore (ehh, I can deal with the Red for more visibility I guess). Both are apparently good for our constant 35F and below weather here but a review said the Castelli is over-vented that it actually lets the cold in instead of venting out the heat from your body.
The past three years my outer jacket has been a $10 no-name windbreaker. In 30-50 weather I just wear a wicking shirt underneath, 10-30 I go with a sweater/fleece, and below 10 degrees I add a thin third layer. Works perfectly for me.
I use this one, and are really happy with it.
https://www.bikeradar.com/gear/catego...acket-11-45457
I use a mec ferrata 2 (schoeller dryskin) or a mission workshop orion (schoeller c-change). The schoeller dryskin has adwr treatment, whereas the orion is fully waterproof w/ taped seams/zippers.
Both are great, huge fan of schoeller fabrics.
I wear a defeet long sleeve base layer with a merino wool sweater and sometimes a sportswool long sleeve jersey underneath the jackets.
I'm guessing you mean the Espresso Due Jacket? I love mine and ride it down to Zero F with proper base layers. Not cheap buy any means but worth every penny to me. To be honest when I took it out of the bag I was like... sure... But to my pleasant surprise it is a great jacket!
fasthair
fasthair
Thanks guys.
https://www.backcountry.com/gore-bike...ol-jacket-mens
just another gosling
Liked 2,111 Times
I like a microfiber type windbreaker, non-waterproof, something on the order of the Performance Century jacket, something that will easily stuff into a jersey pocket if I start to get warm and it's not raining.
Bicycle Repair Man !!!
Columbia Omnitech shell over how much wool I need to stay warm.
The stock liner for the jacket cannot compare to the wool and I wear that separately or in warmer weather.
Bikes: '12 Felt F75X, '11 Scott CX Team, '08 Specialized Singlecross
+1 or the Gore Phantom 2.0. I had searched high and low looking for a new winter jacket. I had decided on the PI Pro Softshell 180, but then I found the Gore jacket on sale for $55. This was well below the cost of the PI jacket. I figured for the price, it could not be beat; if it didn't work out, I'm not out a ton of money. I have been very happy with it so far. I have used it down into the low 20s without issue. Once it gets below 30 degrees, I pair it with a mid-weight polypro long sleeve, and it has been great. Just note that this jacket has a breathable back and it is not a full softshell. Since I have a hardshell for the rain and slop, this was not a deal breaker for me, and I actually like the increased breathability it provides.
Bikes: Diamondback Copperhead (hardtail, winter bike), 2014 Giant Rapid 2, 2015 Kona Big Rove ST
We can get temps down to -20C (or lower) here. I wear a Descente Course ski jacket in neon yellow on the coldest & snowiest days.
Bicycle Commuter
This is my first winter bicycle commuting, but I have found a system that works well for me. I wear a Yellowjacket windbreaker:
https://www.bicycleclothing.com/Wind-Jackets.html
Similar to Lasauge (previous post), I just vary the layers under the windbreaker (temp range is approximate and changes if wind becomes a more major factor):
40-50 F - loose polyester running shirt,
30-40 F - either poly running shirt or midweight merino wool shirt,
20-30 F - either midweight merino wool alone or with a poly running shirt on top of it
10-20 F - wool with poly running shirt on top of it
The things I really like about the J&G Yellowjacket are:
- pitzips can open if things get warmer on ride or for afternoon commute, etc.
- with the jacket and a poly shirt and a wool shirt (on me or in the pannier), I can vary layers and cover a huge temperature range
- reflective stripes on sleeves and back
- durable and fairly breatheable nylon
- machine wash, hang dry, and it dries quickly, always by next morning in our house
It is cut full/roomy, so if you are a speed demon that might not be appealing to you. For a layering approach on a city bicycle commuter, it rocks.
I also tend to go a little warmer on legwear than many might, mainly to avoid muscle tightness in cold weather (in addition to stretching and warm-up) - but the upper and lower work together in body warmth.
I am a full-time bike commuter now and have been using this jacket every day in temps down to 7 F so far with varied layers underneath. I like it. For our Central Illinois climate, I think I am pretty much covered.
Wow thanks for the responses. I ended up with this through some research/reviews:
https://www.goreapparel.com/gore-bike...T&navid=search
Review: https://road.cc/content/review/28181-...ygen-so-jacket
It's $112 right now @ PBK then I used PBK10 for 10% off. It's half of the Castelli Espresso Due jacket I really wanted and I think $100 is a LOT of savings. There's also the Gore Path jacket (Goretex!) for $135 @ PBK which is highly rated but I wanted something more form fitting (the Oxygen jacket is a Tight fit according to Gore).
Now onto some serious winter gloves...
Here is what is written:
My only real criticism is the lack of ventilation: you have the front zip but that’s all. Windstopper fabric is reasonably breathable but even in the sub-zero temperatures of some of our test rides I was sweating on the big climbs. Pit zips would have helped keep the atmosphere less humid in there. There’s a lot to be said for the clutter-free approach too though, and it ultimately comes down to a matter of personal preference.
Biscayne below is a link to the Phantom 2.0 that's on sale for $125 (plus you can get another 8% thru Mr. Rebate). It offers: warmth; a 2 in 1 jacket (sleeves can be removed and worn as a jersey); venting if needed (you can slightly unzip the sleeves if you'd need to); venting out back. It provides the same warmth as the one you linked. I know it's your preference, but I think you get more for your money with this jacket and it cost less, depending on your size and color preference (different colors are on sale). "It's better to have and not need than to need and not have." Take a look at it.
https://www.backcountry.com/gore-bike...questid=289910
https://www.mrrebates.com/merchants/a...d.asp?letter=b
I have the MW Orion, I liked it so much off the bike that I bought the Bosun and Trigger when they had the 30% off sale. I really like these Schoeller fabrics. I picked up a couple of rapha's base layers when they were on sale for my base layer.
