Help ID a Claud Butler
I just picked up this Claud Butler Franken and I'm just wondering if anyone here could help me ID it. It came with some campy bits and some old Dura Ace (two sets of old Dura Ace - one high flange and a set of low flange). It has a 3ttt stem and Cinelli bars. The headset, BB, rear derailleur, seat post, brake levers and crank are all Campy. I think that is what it came with originally. The rear derailleur in a Nuovo Record and it says pat. 73 on it so I'm wonding if that places this bike around then. It has Campy dropouts but it has been repainted with the original decals left intact. Any ideas on what it could be?
Stop reading my posts!
any serial number?
It has Prugnat lugs and one of the "cut-down" Vagner type crowns...but is that seat cluster fastback? Fillet brazed?
Show a pic of that...
Might be a later Holdsworthy CB, but might even be a Falcon-era frame...
I did. Well worth the drive. All Dura Ace and Campy and the seller didn't mention that at all in the ad. That said, its pretty rough but it has lots of nice parts and I think a decent frame under it all.
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
A Claud Butler with tri clips? An interesting setup, for sure. That is quite a nice score and I look forward to seeing it cleaned up.
hmmm. I'm a bit stumped: the lugs and lack of braze-ons points to an early (like '70s era) frame, but something about the semi-fastback stay-tops and how narrow the stays are placed looks later...wonder if it's been repaired.
Serial number would be a big help for somebody who knows the CB format.
I will try to take a better look for the serial number when I get a chance. It looks like it was hand pinted with a thick layer of paint so it might need some stripping before I can get at it.
Unworthy1- if it were repaired do you think the stays would be replaced all together?
Bianchi Goddess
Liked 3,272 Times
We have been trying to tell you that for years!!
Interesting looking bike. Ditch those geek bars, clean her up and tell s how she rides.
Sugar "Kane" Kowalczyk
It's still a mystery to me.
^Yes, usually...at the least the 3 main tubes would be (or at the very least the seat tube).
I gather that the Colstar was usually the same as the Holdsworth Mistral (for many years) yet this frame looks not like any Mistral I've seen.
https://homepage.ntlworld.com/nkilgar.../Cata42_43.jpg
This page here says it's the same as a Holdsworth Special which seems right. I'm going to do some work on it tomorrow and I will take some better daytime pictures. Hopefully I will be able to find the serial number.
you'll notice that that description of the Colstar (frameset alone) is with "bottle cage bosses, cable guides and gear-stops/tunnels" for that year...none of which your frame has.
The other frameset (akin to the Holdsworth Italia) that has Campy DOs also has full braze-ons.
yes that's a good drive-side shot...and it DOES have some braze-ons on the chain stay, and those cable/housing guides are more-or-less what I'd expect to see on an early ('70s) British frame...
Edit: did some hunting for some Claud Butler pix and found this one with those same Prugnat lugs, but other differences: note the stay tops, the eyelets on the DOs, the cable guides on the TT, the flat Vagner crown (and the lamp bracket for UK use), pump pegs...plus this is a plain-gauge 531 tubed frame.
Still, something to compare with:
https://www.lfgss.com/thread30559.html
dannyg1
15
08-26-12 09:19 AM
HolyGhost
4
08-30-11 04:52 AM
KonAaron Snake
Classic & Vintage
28
05-19-11 07:35 AM
