Never clean your bike again??.....
Old 02-08-13, 11:30 AM
Syncmaster
GO, Mordecai!
Syncmaster's Avatar
Imagine spraying your clean frame and all other non-moving parts with this stuff. Would never come back from a muddy/wet ride with gunk stuck in all those hard to find places... Would need to keep it away from all the moving parts though. Don't see being able to spray this near derailleurs, brakes or bearings, but it could make keeping a bike clean so much easier.
Syncmaster is offline
Old 02-08-13, 11:39 AM
escarpment
escarpment's Avatar
Bikes: cannondale crit 3.0, specialized allez, old giant mtb/hybrid
that would be sweet, although the commercial reminds me of sham wow or other shady infomercial techniques.
But the frame is easy to clean anyways, its all the small moving parts that suck.
escarpment is offline
Old 02-08-13, 12:04 PM
THSdrummer
THSdrummer's Avatar
Bikes: '12 CAAD10 3, '88 Raleigh Talon
Hydrophobic coatings are popping up everywhere. I've even seen a few companies that use hydrophobic coatings to make water resistant phones, tablets, etc.
It wouldn't be a bad idea on bikes. I'm curious if it would work well enough to prevent build-up on cyclocross bikes...? Now that could revolutionize how cyclocross races go in the mud. People without extra bikes in the pit wouldn't have to worry about dealing with build up of crud.
I can see a few interesting uses with this stuff. Might be pretty cool! What if you just sprayed a stripped frame? You wouldn't have to worry about hitting any mechanical parts in that case, and it wouldn't leave any frame areas that could accrue debris.
THSdrummer is offline
Old 02-08-13, 12:18 PM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
I'd like to try it on a bike chain. I'm sure it would wear off where metal parts rub, then lube it.
wphamilton is offline
Old 02-08-13, 12:19 PM
ARPRINCE
ARPRINCE's Avatar
Bikes: 2021 Tern Verge X11 + Cannondale 2016 CAAD12 eTap + 2011 Synapse Alloy 5 Ultegra
Quoted: 150 Post(s)
Liked 24 Times in 16 Posts
kewl!
ARPRINCE is offline
Old 02-08-13, 12:20 PM
Inertianinja
Bikes: Felt AR1, Cervelo S2
Quoted: 17 Post(s)
Liked 4 Times in 3 Posts
I'm waiting for the SL version next year. I hear this stuff is heavy.
Inertianinja is offline
Old 02-08-13, 01:49 PM
TDRILL
Bikes: 11 BMC SLR01 / 09 Madone 4.5
I wonder how long it actually last. RainX is cool stuff . . . for a couple weeks
TDRILL is offline
Old 02-08-13, 02:06 PM
Crappymonkey
Guitar Master
Crappymonkey's Avatar
The video was enternaining. If it actualy works I'd consider using it.
Crappymonkey is offline
Old 02-08-13, 02:38 PM
NWS Alpine
I coat my new frames with Optimum opti-coat 2.0. It's harder than clearcoat and is a permanent bond. It's used in the high end detailing industry. I've had it on my car since I took delivery over a year ago and it's still as good as day one. Nothing sticks to the coating so a simple spray down and the bike is clean as new.
NWS Alpine is offline
Old 02-08-13, 09:29 PM
Syncmaster
GO, Mordecai!
Syncmaster's Avatar
I would definitely take some of this, strip my frame and give it a proper coat. Would make clean up so much easier through the winter.
I sent a message to the manufacturer but I can't tell if you can buy this stuff yet.
Old 02-08-13, 10:34 PM
IcySmooth52
IcySmooth52's Avatar
I'm sure this stuff is just a spin on teflon. Gore-Tex, DWR, Nikwax, waterproofing leather treatment, and all such anti-H2O things are all that same material. It would stay on a frame just fine, but it wears off fairly easily with any sort of abrasion. So I wouldn't even consider it being on gears or chains. Go with wax lube there.
IcySmooth52 is offline
Old 02-09-13, 02:45 AM
JimF22003
JimF22003's Avatar
Bikes: 2008 Trek Madone 5.5, 2009 Cervelo R3SL tdf edition, Cervelo R5 with Di2
Somebody should make a water-resistant water bottle...
JimF22003 is offline
_ForceD_
Bicycle Mechanics
9
12-14-15 07:18 AM
Bustaknot
Bicycle Mechanics
32
09-29-14 03:54 AM
spectastic
Bicycle Mechanics
13
09-15-14 09:26 PM
Badgerjohn
Bicycle Mechanics
4
02-23-14 03:14 PM
pierce
Bicycle Mechanics
24
11-29-10 04:57 PM
