brooks saddles on road bikes?
Still can't climb
no.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
To me, they just don't seem to be good designs for someone riding in a road cycling position either in the drops or on the hoods with a typical saddle to bar drop. However, to each their own. In my opinion they are much better suited for touring/trekking or casual shorter rides. Also it is tough to understand why someone would spend a bunch of money on a carbon bike and then put an anchor on their seatpost - the lightest brooks saddle is 370g. However, I've heard enough people swear by them to acknowledge that they are extremely comfortable for some.
pan y agua
Liked 769 Times
However, if you look at the setup on most of the bikes that use them, they are pretty upright, and appear to work better with an upright position for most riders (although the swift model is supposed to be better for an agressive position.)
Thus, if you don't run much if any drop, and value comfort over weight Brooks may work for you.
You could get lost and die.
You could hit a tree and die.
Still can't climb
pan y agua
Liked 769 Times
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
Yes. They work exceedingly well on road bikes. I'm not a weight weenie, though both of the steel framed bikes below weigh in the 21-22 lb range with pedals, bottle cages, etc. Almost all my bikes are equipped with a Brooks or Ideale saddle.
![](https://farm8.staticflickr.com/7218/6936273250_23fccdbb97_b.jpg)
Rapide - WMRT Ride - 1 by Sallad Rialb, on Flickr
![](https://farm9.staticflickr.com/8234/8393527366_9e1868cdf8_b.jpg)
Alpine Cycles - Mid- to Late-80's - 2 by Sallad Rialb, on Flickr
Liked 10 Times
![Thumbs Up](images/smilies/thumb.gif)
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Depends on the setup. In general Brooks saddles work better with minimal to no saddle to bar drop. The short rails often mean lots of setback is needed. The Velo Orange seatpost is good for this if your bike takes a 27.2 post.
Aesthetically they can look great or really out of place depending on the bike.
Bikes: Bridgestone Diamond Formula, Fuji Royale, Peugeot psn10, Motobecan grand record
Bikes: 2012 Scott CR1 Comp
While not a brooks, I run ~5cm of drop (not a lot, but a lot more than I used to) with my selle anatomica titanico, and have no problem with all positions. SA Titanicos are also heavy saddles, but the thing could weigh 5 pounds and I would still use it. I can't tolerate a normal saddle, now (surgery over my right sitbone last year to remove some large painful cysts has made it impossible to tolerate the pressure on the sitbones from a normal saddle).
Pretty rigid member
Bikes: Sycip Unleaded, Raleigh SS, Trek 1.5, IF Crown Jewel, QR Kilo
Cycling to me is a form of exercise and not a fashion show so anything that meets my needs is going on my bike.
Liked 10 Times
Good point, for some people that is the case, but for others cycling is a lot more. Interestingly enough, I have ridden other saddles and they are just uncomfortable to me. I've not yet had a Brooks saddle that wasn't comfortable to me. I like a saddle to be comfortable to me.
If you ride on the tops, sure. The saddle will weigh as much as your frame, though.
Notice the cross brakes. If you can get beyond the distraction...
This. I've been riding for 44 years as an adult, owned at least 15 bikes, some of them extensively personalized, and I can honestly say I've never given 10 seconds of thought to what something might look like on my bike or what anyone else thinks of it. If it works, if it suits me, I'm good.
Bikes: '89 Cannondale SC600, '05 Marin Fairfax, '10 Specialized Roubaix Elite Compact
I have a B-17 Narrow on my Specialized Roubaix. I must admit that the retro look of a Brooks saddle on a carbon fiber bike took some getting used to.
