Guess the vintage tool!
Old fart
Liked 3,683 Times
Park fork alignment gauge, model #FT-4
+1 with JDT, I got a out of whack fork made right going to a shop that had one,
A good score, since They stopped making them years ago .. now tweaked forks just get replaced.
Liked 3,044 Times
I've used this tool TWICE in the last couple of weeks!
First, I used it to straighten a steel fork on a racing bike with 700c wheels.
Then I used it to widen and de-rake the fork on my 1973 Raleigh Twenty.
It's a great tool. I mentioned to my LBS that I'd like to buy it, but the folks there only chuckled in response.
K2ProFlex baby!
Its a 1950s car jack thats been altered into some kind of bicycle tool. Did I guess it?
You see, their morals, their code...it's a bad joke, dropped at the first sign of trouble. They're only as good as the world allows them to be. I'll show you. When the chips are down, these...These "civilized" people...they'll eat each other. See, I'm not a monster. I'm just ahead of the curve
Bead jack for Challenge tires?
Liked 3,486 Times
tubular tire stretcher? I haven't the faintest, but am guessing I will feel dumb when the answer comes out
Life is too short not to ride the best bike you have, as much as you can.
Liked 3,044 Times
It's a head tube straightener. We had that at a shop where I worked.
Cool tools Eric.
Is there any chance you could show us a pic of these things in action?
- Not that it isn't immediately apparent to ME how to use these things - Oh nooooo.....
- Auchen
- Auchen
Known around here as a "Fork Jack" for pushing out stuffed forks.
Heres the headtube straightener, you pre-guessed my next one. Looking at it now, maybe with a little ingenuity, you could actually use the fork jack to push out a buckled headtube.
Ride, Wrench, Swap, Race
Liked 1,392 Times
This thread is interesting in that I have been at work with the design of a "lowest-cost fork/headtube straightener" for home use.
Also working on a system of removing toptube/downtube dents from the inside.
I promise to post what I come up with.
What??? Only 2 wheels?
Liked 752 Times
Walnut cracker. Or headset installer/remover. (Just guessing but it looks familiar, like I should know.)
Real cyclists use toe clips.
jimmuller
jimmuller
Bikes: Indeed!
Liked 3,801 Times
We tried, with limited success, to use the fork jack as a head tube straightener in a shop where I worked in the early seventies. We would put one of those super-beefy MX forks (Cook Brothers?) in the headtube to be straightened and use the jack to push on it. Unfortunately any frame with serious crimps under the top tube and down tube would often end up with small crimps on the top of the tubes as well after this treatment!
Brent
Brent
in the "Love of English 3 speed" thread?
And the second tool is actually a fork straightener as well- it's exactly like the one we had back in '73 and ''74- the summers in college I worked at the Bicycle Peddler at 38 th and Georgetown Roads in Indianapolis. It worked pretty well on the cheap bikes I personally used it on once or twice- but I wouldn't want to have ridden them much either- and never in a race!
The flats behind the moving "jack" part rest up against the BB and one of the hook slots of your choice on the red part of it fit on the hub axle- you pump the handle and - voila- the car jack pushes the axle away from the BB.
By the way, I ordered a used replacement fork for the 3 speed- but then found some new ones on Amazon too, shipped under $20- although they are out of stock on the chrome I would have preferred. Don't know what a shop wants to straighten a fork these days-
the park tools are listed on ebay starting about $65.
Liked 3,044 Times
But that Huffy's fork is very bent, and it's a Huffy, not a Raleigh.
My LBS won't bend steel frames any more. They got rid of all their tools for steel frames and had forgotten about the gauge that eric showed us. They let me use it myself, since they don't want to do it.
Old fart
Liked 3,683 Times
If your carbon fiber fork gets whacked out of alignment, it's time for a new one anyway, I suppose.
Here's one I've only seen in this catalog drawing. Hint: it's made by Campagnolo, but hasn't appeared in their catalogs since the 1950s:
Busted!
and it is a Huffy- and not a Raleigh- sometime in the 60's I guess they quit importing them- so its a heavier American frame with a big bottom bracket-
a '69 I believe- just took the crank off tomight- a great big 48 tooth sprocket HEAVILY chromed- higher quality than they got later even-
One of the reasons I bought it was to have the option of motoring- though I doubt I will- that always messes up the paint- so it's a cheap throwaway of sorts- I'm just overhauling- got burned another $19 for the fork beyond the 39.95 I paid for it.- Cleaning up nicely tho.
