Prepping a Carbon Rim...Acetone?
Bikes: De Rosa Idol, Felt TK-2, Pinarello Paris, Williams Gemini alloy, Basso Astra, Basso Laguna, Bottecchia Leggendaria, Cinelli SSCX, Argon 18 Electron track, 60-70 wheels
I have been reading opinions on prepping carbon tubular rims for the initial glue job. What say you all about the practice of cleaning the carbon surface with acetone and a scotch brite? The abrasive pad seems OK but it occurs to me that carbon fiber is held together by resin i.e., glue and of course acetone does a number on glue... I did prep a set in this manner but I don't think the acetone removed any sort of oil that would impede the tire adhesion. That surface is pretty clean to begin with and I'm guessing you can weld the tire on there with no special prep. Fire away gentlemen...
Liked 58 Times
Acetone is a bit aggressive for epoxy resin holding the carbon fiber together. I would go with no more powerful a solvent than isopropyl alcohol. You know, just buy the alcohol swabs they sell at the pharmacy for prepping injection sites. Wipe once and you are done. That is what I just used to clean my carbon rims before applying the decals I had made for them.
Robert
Robert
Thanks...found some info
Robert
Robert
So maybe that's good news considering I prepped a set already using acetone.
Bikes: CAAD10
For just prepping new rims, isopropyl alcohol is fine. Acetone won't hurt the rims, but it's a stronger solvent than is really necessary. When I first prepped my carbon wheels, I used isopropyl alcohol applied via paper towel - no abrading - and it worked just fine. I have since re-glued those rims, and when taking off the original tires, I can assure you - they were well adhered!
Liked 58 Times
So much going on here! First the OP was asking about prepping the tire contact surface for gluing. IPA is a good choice. Perhaps acetone is safe, but it is not necessary. Second he mentioned sanding. That's a different issue than cleaning with solvent, and I did not treat that. It has nothing to do with what solvent is chosen. Finally, he made no mention of removing paint or decals. Perhaps acetone is needed for that, perhaps something even stronger. I don't know. I do know you have to be careful, and the rim manufacturers neither envision removal of paint and decals with aggressive solvents nor design their rims to withstand such treatment. Do what you want. Just beware. - Robert
Señor Member
Bikes: 2018 Lynskey R380 Ti | 2011 Hampsten Travelissimo Gran Paradiso Ti | 2001 De Rosa Neo Primato - Batik Del Monte, Genius | 1991 Eddy Merckx - Motorola, TSX
Liked 14 Times
Several years ago when I bought my tubulars (they were slightly used), I used medium grit sandpaper to lightly sand the surface before mounting the tires. Depending on which Scotch Brite pad you are talking about, if you are referring to the standard green one, I don't think it will do squat to a carbon rim unless you are REALLY working it and this sort of thing is totally unnecessary IMO for a brand new rim. Even acetone is overkill IMO for a new rim surface.
I normally use VM&P Naptha for cleaning excess glue nowadays (way better than acetone IMO). Naptha is also great for when it's time to remount. Just use a rag with some Naptha and some elbow grease and it allows for the old glue to be evenly distributed, since you will inevitably have uneven spots when you take off the old tire.
Just make sure to wear nitrile gloves while working with all the glue, solvents, etc.
Good luck, tubulars are fun!
