1st Ride With Clipless Pedals
Quoted: 167 Post(s)
Liked 11 Times
Got my pedals installed today, picked out shoes and spent some time in the trainer getting my bike fit and learning how to clip in and out of the pedals.
So, tonight I decided to go for a 10 mile ride to work on getting in and out of the pedals (it is going to some getting used to). I got 5 miles into my ride and decided to push it out to 15 miles at the 7.5 mile mark (my turn around) I decided to just go for 20 miles. I can really tell the difference with the cleat on the few uphill climbs I have to make. Most of the time I was able to get back in the cleats after a stop fairly well but, I did have a few problems.
FYI - I did not fall once but came close at my last stop before home, I did not get a great start at the light and I was in to high of gear, I stuck my non cleated foot on the pedal and immediately locked in. It was shear panic trying to get enough speed up to keep from falling over but, I managed to stay upright.
My calves are sore and my right knee is a bit stiff from getting in and out of the pedals (I have had 3 surgeries on my right knee and it is stiff most of the time anyway).
The LBS moved my seat a bit higher and rotated over a little to get my wrists into more of a neutral position. The setup was more comfortable.
What type of pedals / cleats did you go with? I have an older pair of SPD pedals that clip in and out so easily it seems a wonder that my feet even stay connected with the pedals, but they do. I also ride with SPD-SL pedals on another bike - not as easy to clip in, or out. I took a spill this spring, and I've been riding clipless for a number of years. I just wasn't thinking - came to a near stop behind a vehicle at a traffic light and before I knew it I was on the ground. Ooops. So if it hasn't happened yet, it will. Don't worry - it's only a bike. It's the body and in my case, the ego, that took the most bruises.
That doesn't sound right about your calves. They shouldn't be sore. If the soreness doesn't go away after four or five rides, check into getting an adjustment from a fitter, (if you use one). Your knee is understandable. You might consider uncliping on the left side instead. It will take some getting used to, but might eventually be more comfortable and easier on your right knee.
Quoted: 3352 Post(s)
Liked 1,056 Times
Clipless pedals on a tadpole trike is almost mandatory for safety. But there is no problem using them the first time or ever, since you never need to unclip when you stop, nor will you fall over.
Bikes: 1997 Specialized M2Pro
Club Tombay strikes after a few rides, when your confidence grows. Practice clipping out hundreds of times on a small road, and clip out from different positions in the stroke.
Quoted: 167 Post(s)
Liked 11 Times
You do know that the clipless or not argument is a religion and people get upset?
Bikes: Giant TCR SL3 and Trek 1.5
Quoted: 12 Post(s)
If you haven't already or if your shop didn't, loosen the tension in your pedals for a while until you get the hang of it. On most pedals, it just requires a multi-tool or the appropriate Allen wrench key. If you don't plan on doing hills right away, having them a bit too loose isn't going to hurt.
You may also find that your knee responds to playing around with cleat position. In my own case, my right knee appreciates it if I adjust the cleat so that my toe is turned fractionally inwards when cleat and pedal are engaged. Your mileage will, of course, vary but it is worth a bit of experimentation to find what suits you best.
Bikes: 2013 Specialized Seceur Elite, Soma ES custom build
aka Phil Jungels
I love the 324s. They are the nuts for running to the store in my sneakers......................... or sandals.
I actually set the tension as tight as it will go, and it's still easy to clip out with the SH56 cleats. I wished I had used them when I was MTBing.
Momento mori, amor fati.
Liked 12 Times
Unfortunately, I’m 57 years old and I’m unwilling to risk falling over as virtually everyone does via clipless pedals at some point, so I’ll be sticking with regular platform pedals. I have a feeling it would be quite difficult to go back to platform pedals once the advantage of clipless pedals have been realized, so I’ll attempt to refrain from trying them so as not to get hooked on them. Even so, my curiosity is on the increase (ut-oh, me senses the potential devouring of ye own words some dayeth).
FYI, I started bicycling at 58yo on a mtn bike with loose clipins, and easily went to clipless that year when I bought the road bike. 14 years later I now have a road bike with clipless, a road bike with loose clips and a mtn bike with platforms, and I move easily between the three. But, I love the clipless for the road bike, and am really glad I got them. Yes, I fell 2 x's in the first month, but have not had a clipless-related fall for 13.5 years.
Don't let age stop you if you would like to use them.
Quoted: 7397 Post(s)
Liked 2,571 Times
I keep my tension as low as possible. In panic stops, I forget to twist out, and I pull straight up, and my shoes come out. Works for me. Not recommended for racing.
I also keep my tension as loose as possible. Maybe I can do that because I use the zero-float SPD-SL cleats, (the red ones), so my feet don't "wiggle" side-to-side throughout a pedal rotation. Then, when I want to unclip, it just takes a little twist, and I'm free. I tried the float cleats that normally come with a set of pedals, (the yellow ones), and just hated them right off. Didn't even get half-way down the block before I went back home and put on zero-float cleats. To be fair, maybe the reason I've never had problems with clipless is that I've been riding so long and started out with the old "rat trap", toe clip/strap system.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 7 Times
With platform pedals you get 100% range of movement and motion to allow your leg to float during each and every pedal stroke.
I think you need to rethink this and leave the clipless to the racer boys.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Bikes: Diamondback Edgewood LX; Giant Defy 1
Why on earth would you risk further damage to an already weak knee by using clipless that lock your leg in a rigid position??
I ride with toe clips but I do not have them cinched tight, but with the ridges on the pedal and where my shoe's toe box are in the clips, I'm don't think my foot rotates/floats much. I would think if I did use clipless with float, my foot wouldn't be any more restricted, or at least to any more significant amount. Now, if you mean by platform pedals that you have no toeclips or(and) a true flat surface, then you could have a lot more float, and/or slippage on the pedal. I don't think you need to be a "racer boy" to want to use clipless. I'm actually considering going clipless as the compression of the toe clip, I believe, is contributing to my toe issues.
Randomhead
Liked 3,786 Times
you just reminded me that I'm going out on SPD for the first time today and I'll probably fall over. Not good
aka Phil Jungels
I have a bad knee, and spd clips actually help keep my knee stable, and connected. As opposed to being prone to failure/buckling, and/or slipping off the pedal.
Sometimes, what sounds like a bad idea, can be good.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 344 Post(s)
Liked 247 Times
Timely thread.
I just put some Shimano 105 pedals on my old Team Fuji last weekend, after a lifetime of toeclips and straps. I've ridden 65 miles since and I haven't fallen over yet, but I came close on the first ride when I tried to pull my foot back out of my toeclips, and my foot didn't pull out.
I think I'm going to try the non floating cleats, since I find it a bit awkward twisting out outward with the floating cleats. Inward is fine, but I'd like to be comfortable twisting out both ways.
Other than that, I wish I hadn't waited so long to go clipless.
Bikes: Trek 7.5fx, Specialized Roubaix Comp, Allez , Create 2013, Dutch sit up and beg, Mountain bike,
