Bike Maintenance Tips
I would love to know what the minimum things I should be doing for my bike and how often I should do them. The extent of my maintenance now is to take in for 2/year tune up. Other than that I might lube my chain every now and then. I had a guy at the bike shop that almost had a heart attack when he heard I wasn't lubing my chain atleast every other ride. What is reasonable to keep a safe bike? Thanks.
wipe down chain and relube it (i like prolink) every 100-150mi for me.. every once in a while i pull my cassette off and clean all of the cogs with Simple Green. at the same time i'll clean the RD pullys because they tend to get gunked up at about the same rate.
minimum though you really should lube your chain more often.
Liked 477 Times
I degrease my chain, derailleurs and chainrings with WD40 every couple of weeks. Spray to remove gunk, I use a tooth brush to really clean the chain...hold bristles against all four sides of soaked chain while turning cranks to loosen and remove gunk...use wd40 to spray off the gunk, etc. wipe clean with rags, including chain rings, etc. Lube chain with lube of choice, also lube pivot points on deraillerus. While lube is soaking in I wipe down the frame and brake calipers...lube those pivot points as well...clean brake pads off with a light scrubbing of sandpaper. Wipe excess lube off chain, etc., wipe down frame with a bit of wd40 sprayed on a clean cloth...old tshirts cut into pieces...also wipe down wheel set and tires...I like to use Windex to clean my bike and wheels...no real reason except it works and I like the smell...put the wheels back on...I take the wheels off when doing this maintenance...check cable tension for derailleurs and I'm ready for the next ride.
Other than lube, keep tires inflated to correct pressure.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Check your tires for embedded sharps that haven't worked through the casing. Check brake pads for wear, aluminum shards, debris etc.
SuperGimp
Just make a good effort to keep your bike clean - you'll discover things that need attention if you do a nice job cleaning it. If you think your chain needs to be cleaned & lubed, the rest of your drive train probably does too.
After each ride you should dismantle your bike entirely - storing each part in a separate ziploc bag. This includes dismantling the chain into separate pins and plates.
That should keep bikeshop guy happy.
Liked 3,110 Times
Doing this every couple of weeks is excessive. I give chain a very quick wipe with dry rag after every ride to remove debris accumulated during that ride. Then a bit of lube as needed and a more thorough cleaning with degreaser every few months -- the regular dry wipe down keeps chain pretty clean.
especially if you're brake happy and descend a lot. The pads can glaze over and compromise stopping power. A couple swipes with a metal file makes the pads like new. Your brakes will work better and your rims will last longer.
Tour De French Fries
Bikes: 2010 Cervelo R3 SL & 2013 Airborne Goblin
i have two chains. One soaks in degreaser while i'm using the other. To me it's easier than cleaning, and gets the chain cleaner. About every two weeks or when chain looks dirty i swap it out and put some lube on it.
Bikes: 2012 Giant Escape, 199? Specialized HardRock
120 grit sandpaper on a flat surface, lay each pad flat on the sandpaper and slide across a couple times. That's all it takes to remove the glaze. then wet a scotchbrite pad with water and Dawn dish soap and wipe down rim surface to clean off brake pad material off the rim. Just did this yesterday on my Giant Escape 2 with 300 miles on it and it felt like an 60% increase in stopping power. I also used the rubberband trick to put some toe-in on the pads when reinstalling.
Make sure to label each ziploc bag, and date it with an expiration date.
Bikes: Pinarello Paris/Ui2, BMC TeamMachine SLR01/Campy Record EPS
Liked 58 Times
There is a serious confusion in this thread of maintenance to assure safe riding and long life of components with aesthetic prejudices. Keeping brake pads in good order is important. Adjusting brakes is important. Checking tightness of fasteners, the same. Lubing the chain is necessary. But cleaning the gunk off chain, cassette, and derailleurs is pure vanity. Derailluer pulley bearings nowadays in high end products are sealed so lubing them is silly. I respect folks who like their drive trains to look pristine, but there is no benefit to it besides cleanliness. Knock yourselves out, but don't think you have to do it to be a real cyclist. - Robert
Liked 58 Times
Yes, I think most people who read and post here will tell you that. I don't think they are right or at least not right enough to matter very much. My chains last for a long time, certainly long enough to satisfy me. I have a Shimano 600 crank that I have been using since 1983 on which the teeth are still well formed and which still shifts fine. Simple lubrication is what it is all about.
Forgot where I read about it but to set the toe-in on the pads, you wrap a thick (.030") rubberband around the back edge of the pad (so its between the rim and the pad) to set the toe in, thghten the pad then remove the rubberband. This seems to help with squealing brakes.
Liked 58 Times
Bikes: S5 VWD & SL-7 S works Red.
No need to go crazy cleaning the chain and cassette, just wipe down the chain and lube. I never remove my chain except to replace it after thousand of miles. The chain will stretch no matter how clean it is.
I also never wash my bike just spray it with Windex and polish with Pledge. I never let my bike get really dirty and if conditions are really bad will use a sponge with a little dish soap.
The one thing that I find important is the clean the braking surface on the wheel. Not everyday but about once a week depending upon usage.
No need for special "bike" soap or polish but a good bike chain lube is important.
