Carbon suspension stoker seatposts
Tandem Vincitur
Bikes: BMC Pro Machine SLC01, Specialized Globe, Burley Rock 'N Roll tandem, Calfee Dragonfly tandem.
For a while now, the premier suspension stoker seatpost has been the Thudbuster®. It is seen on a lot of tandems.
You don't have to be a far gone weight weenie to have some pause before installing a Thudbuster®. There are two models, the 570 gram Long Travel (left), and the 450 gram Short Travel (right). In comparison, the captain's Thompson seatpost on the depicted DaVinci weighs 193 grams. The Thudbuster ST and LT thus adds 257 and 377 grams (9 and 12.6 oz) respectively.
There are two new seatposts becoming available that may provide some stoker relief without a significant weight penalty.
The 220 gram Ergon CF3 Pro Carbon, which is listed as not yet available at Bike24 for 250 euros.
Edit: News about availability--
And the $200, 250 gram Specialized COBL GOBL-R carbon seatpost.
Don't laugh - the strange-looking Specialized COBL GOBL-R really works, and quite well in fact. The benefits vary depending on saddle positioning but even in the forward-most setting, it takes the sting out of bigger bumps in the road.
The COBL GOBL-R isn't available until September as an order item, but newer Specialized bikes are equipped with it. I rode one last Saturday, but it was difficult to compare on a different bike. The LBS offered for us to borrow the COBL GOBL-R, and I hope to put it to the stoker test on our ride on Saturday.
Originally Posted by Bike24
The CF3 Pro Carbon is a new development based on the Ergon CR1 support. The system follows a novel approach by two parallel plate springs with a flip head.
The CF3 Pro Carbon principle of operation is as simple as perfect. The thrust of the force (obstacle) and the compression direction are physically on the same path and work optimally together. More efficient principle than of the conventional seatposts suspension. The highly sensitive, tight response of the VCLS plate springs makes a genuine "road bike ride feeling". Conclusion: A true comfort revolution, ideal for steep seat tube angle by low setback, in super light weight and absolutely maintenance free.
The CF3 Pro Carbon Seat Post with 330mm length and 27,2mm diameter is available for Flip Head saddle rails in two sizes: 7x7mm and 7x9mm.
Product Name:..........Ergon CF3 Pro Carbon Seat Post 330mm / 27.2mm
Manufacturer:.......... Ergon
Item Code:.......... ERG158451
Year:.......... 2013
Material: ..........carbon fibre
Weight:.......... approx. 220 gram
Color:.......... black
Length:.......... 330 mm
Diameter:.......... 27,2 mm
Originally Posted by Ergon International FB
Ergon International Production is set for completion on Aug. 25. Worldwide delivery to follow after that. We will announce N. American delivery as soon as they land Stateside.
Originally Posted by Specialized
The COBL GOBL-R seatpost extends the concept that “Smoother is Faster”. This revolutionary post features 18mm of vertical compliance, Zertz vibration damping, and FACT carbon construction. The COBL GOBL-R delivers unsurpassed comfort, control, and efficiency without adding weight or complication to the frame. No matter what surface your ride takes you on, the COBL GOBL-R will make it better.
- Revolutionary design allows 18 mm of vertical compliance
- FACT carbon construction blends durability and comfort
- Vibration-damping Zertz for increased comfort
- Cylindrical aluminum head assembly adjusts fore-aft and tilt with an easy-access single bolt
- Diameter:..... 27.2mm
- Length:....... 350mm
Half Fast
...The 220 gram Ergon CF3 Pro Carbon...
...And the $200, 250 gram Specialized COBL GOBL-R carbon seatpost...
Bikes: Co-Motion Speedster Tandem, S-works 29r, Specialized Tarmac SL4
We've run the old Specialized Pave Zertz in back since we bought the tandem. Tried a thudbuster and my wife absolutely hated it. This thing actually works really well. Tough to find nowdays. The updated S-works version didn't work as well.
Tandem Vincitur
We visited Mike's Bikes, who lent us a demo Cobl Gobl-R,
It turns out to weigh 257 grams, whereas our 27.2 mm, zero offset ENVE weighs 169 grams. So, an additional 88 grams (3.1 oz).
How it looks mounted.
We road the tandem around the block a few times (it is very bumpy, and is slated for repaving) first with the ENVE seatpost, then with Cobl Gobl-R. The ENVE post ride was much more punishing for the stoker, Mrs. R estimated it dimished the magnitude of the uneveness by 40-50%. With the ENVE she clammed up, anticipating bumps, but with the Cobl Gobl-R kept chatting about the house's landscaping through the bumps.
We'll see how it fares on tomorrow's ride, which features over a mile on dirt/gravel trail, and some fairly rough roads.
Bikes: 2004 Co-Motion Speedster
+1. I added a Pave post for my wife 3-4 years ago. (Both of our then-single bikes -- Roubaix and a Ruby -- had them and my wife thoroughly loved her post, so a Pave post was one of her Christmas presents.) The Cobl Gobl-R does look interesting, though. Bizarre looking in any case.
Jeff
Learn from other people's mistakes. You won't live long enough to make them all yourself.
2010 (Specialized) Carmel comfort (my neighborhood bike)
2008 Raleigh comfort (wife's neighborhood bike)
Jeff
Tandem Vincitur
We rode the Cobl Gobl-R today on a ride in the Santa Cruz mountains. In the Santa Cruz mountains, there are smooth roads with high traffic, and rough roads with little traffic. Our descent, SJ-Soquel and ascent, Mt. Charlie, are respective examples of the former and latter. So, this was a good test for the Cobl Gobl-R.
Mrs. R really liked the Cobl Gobl-R. It smoothed out the many bumps for her a lot. She felt it was like having a cushier seat, or an extra chamois. That made it a lot easier to be a captain, as I found myself not tiptoeing around every little bump, but more inclined to keep my line and run over road irregularities. I think it helped with stoker confidence and morale, and lessened fatigue. So, I think what I dub the Stokr Coddl-R® to be well worth the price and extra grams.
I'd like to compare the Ergon CF3 Pro Carbon, but alas, it doesn't appear to be available until September.
Here's a video from Interbike 2012 at which both are discussed.
What the ST can do that the CBR can not, is maintain seat plane in relation to the handle bar. Also, the rear of the bike pivots on the front axle axis, the seat travels in an arc relative to that axis, a bump encourages your bottom to follow that arc and pitches body weight forward. A saddle on an ST moves rearward countering the forward pitch. To keep things relative, the arc is tighter on a single than tandem, so the benefits are greater on a single. The majority of the CBR's deflecting movement is downward only.
Bikes: 2013 Co-Motion Robusta, Litespeed Classic,Litespeed Bella
Tandem Vincitur
Hmmmm... I'll have to ponder this. That would be a useful comparison. My Calfee might rebel, however, at the indignity of sporting a 440 gram seatpost, if even for just a demo.
just another gosling
Liked 2,111 Times
We're using a telescoping post that's fairly stiff and has a good bit of internal friction. Stoker likes it. Advantage is that it doesn't bounce with Stoker's pedaling, like I've observed with Thudbuster's on other tandems, yet it yields to larger hits. I know it's not light. Always been tempted to go to a carbon post, but the ones in this thread are a bit pricey when what we have works. OTOH, Stoker gets a sore butt after 80-100 miles and I wish she didn't. That's been a distance limiter for us. Could be the internal friction on the little stuff. So maybe worth the money . . .
Liked 23 Times
Stoker Kay does not use any type of suspension seatpost on our last five tandems.
Been tandeming since 1975.
Did do roadtesting for a few companies (including the original Thudbuster and a few others). What she liked the best was the old Allsop beam setup.
However our standard setup on our c/f Zona is Thompsons for both pilot and stoker.
Works great for us.
Pedal on!
Rudy and Kay/zonatandem
Works great for us.
Pedal on!
Likes to Ride Far
We've already done the Thudbuster ST vs. Cobl Gobl-R comparison on the back of our tandem. Here's the full story:
We've had a Thudbuster ST on the back of our Co-Motion Speedster since it was new, about 4-5 years. The stoker liked it, with the only complaint being a pogo-stick effect on certain sizes of speed-bumps, where the post would compress as we hit the front of the bump and then launch her upwards as we went over the top of the bump - this was much worse on certain kinds of speed-bumps, especially those in France (Swiss ones are built quite differently). It did fine at absorbing regular bumps/irregularities in the road, and my stoker was generally happy with it, but would occasionally complain when she had an uncomfortable pogo experience.
I had her try riding with a rigid carbon post a few times a couple of years ago because of the extra weight of the Thudbuster. Despite riding regular road bikes with rigid seatposts and a hard-tail MTB without many complaints, she couldn't live with a rigid post on the tandem and wanted some extra comfort.
When the Cobl Gobl-R seatpost was announced last year, my boss at the bike shop where I worked immediately wanted one for himself, so I asked him to order one for our tandem, also. They finally arrived in mid-June, but we've been riding MTBs and road singles a lot this summer so haven't logged too many tandem rides - maybe two or three 2-4 hour rides since the post change. So far, my stoker is sold on the Cobl Gobl-R, and actually PREFERS it to the Thudbuster. Apparently, it's about as good at soaking up small bumps and doesn't have the pogo effect on speed bumps, so she is happy. I'm obviously happy because of the significant weight loss. She's so convinced that she won't change her mind that she's already given me the all-clear to put the Thudbuster on e-Bay.
My boss is pretty obsessed with seatpost comfort and has ridden MANY different carbon posts on his road bikes, and until now found the Alien post by USE to give him the most comfort of any that he'd tried. But now that he has his Cobl Gobl-R I don't think you will ever be able to separate him from it, and he's promoting it to anyone who wants to listen and isn't totally turned off by the look. For the first week or so after he got it he kept riding over every bump he could find just to test it out, and kept coming back from his rides raving about how wonderful the post was. It has just the right amount of comfort while generally being stiff and solid according to both him and my stoker.
Availability is certainly still a problem, but hopefully that should be improving soon.
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
Liked 103 Times
I sold our Thudbuster because of its weight and installed a USE Alien, which my stoker likes.
Tandem Vincitur
Ergon has finally gone into production with their CF3 Seatpost, and so it should be available soon.
At Interbike, Ergon will be showing their setback version of the CF3 Seatpost. This looks to me like it would have more suspension than the straight version of the seatpost.
Someone at Twitter got a chance to try out a CF3:
Matthew Page (@mattpage24)
9/14/13, 7:50 AM
It took less than 1km riding for me to decide I want a [MENTION=111717]Ergon[/MENTION]_Intl VCLS seatpost on every bike. Wow, that's a comfy perch!
[MENTION=53521]AndyW[/MENTION]aterman very impressive. It's like loosing 50psi from a tyre but still motor along on the tarmac. Light too, sub 200g.
New CF3 Pro Carbon Setback
Setback version of the CF3 Pro Carbon seatpost with 25mm of setback (reduced to 13mm by flipping the FlipHead). The system possesses the same twin carbon fibre VCLS leaf spring design and ball bearing equipped pivots allowing a parallel suspension movement. Highly sensitive while retaining that ‘direct road bike’ feel.
9/14/13, 7:50 AM
We have been using a Specialized Pave and it seems to work ok.
I would be interested in the Cobl Gobl-R but I can't find anywhere selling it.
On specialized web site they are now calling it CG-R and they don't have any, says coming soon.
Tandem Vincitur
CG-R CARBON SEATPOST
The seatpost that we trialed was cannibalized from demo at the bike shop. When they checked, it was to be available in September. So, it must be soon.
Now that we are back to our conventional carbon seatpost, the stoker says it is just fine, but it isn't just the stoker that benefits. The captain is in more control on, say, a descent on a rough road, if the stoker has less vertical movement.
Bikes: Paketa V2r di2, C-Dale MT 3000, Teesdale, 1963 Huffy Daisey
We like our Cobl gobl-r acquired about a month ago. Not too deep an offset to work for us, and a shockingly tight dimension between bottoming out the seat post into the frame and the seat rails. Necessary on our cross tandem for getting the seat low enough. Even with a bit more post showing on the road bike, I've not noticed a change in handling given the .25 to .375" vertical movement of the post. Maybe less under my 104# stoker. But she says it is working well.
Tandem Vincitur
The Ergon Setback seatpost is not yet available, but it does now appear on the Ergon website (though not to purchase), so its availability appears to be drawing nigh.
CF3 Pro Carbon SetBack
The Ergon web site claims no sleeve can be used with this seat post. I called Ergon & that's there company policy, but couldn't tell me why. My Co-Motion is 29.6 I believe. Any thoughts to why this might be dangerous & not approved. We now use a Cobl Gobl & my 102 pound stoker claims it does not help with bumps at all.
Clipless in Coeur d'Alene
The Ergon web site claims no sleeve can be used with this seat post. I called Ergon & that's there company policy, but couldn't tell me why. No modern tandem I know of has a 27.2 seat tube. My Co-Motion is 29.6 I believe. Any thoughts to why this might be dangerous & not approved. We now use a Cobl Gobl & my 102 pound stoker claims it does not help with bumps at all.
There has been some mention that Specialized would have different density elastometers available to tune the CG-R. OOTB it is likely setup for a 150-180lb rider. Maybe give them a call to find out.
Calfee is one mfr that uses the 27.2mm standard. Bet he would be surprised his bikes are not "modern". I certainly was. With this breaking news coming to light, now I'll need to send our frame back for a seat tube modification to 29.6mm so we could also start using shims :/
I did call Specialized & told them about my issue, but they had no advise.
Have a great day & I hope Craig doesn't send the Calfee police after me. I like Calfees
