Inner Tube Behaving Badly
Bikes: 1997 Specialized M2Pro
It seems that recently, as I'm pushing the bead of a tire into place, the inner tube keeps flopping out and getting in the way. I can get the job done, but it's annoying. Perhaps the tubes I'm using now are different.
Is there any trick to making it behave, and stay in the channel of the wheel while I'm seating the tire?
Liked 6 Times
I generally inflate the tube enough that it will stay in the tire by itself before I attempt to mount in on the wheel. I then place the valve in the valve hole and mount one side of the tire. Next, I start to mount the remaining bead at the valve and work in both directions a small amount at a time. When I reach the point toward the top of the wheel where either the tube starts to show outside of the tire or it is in danger of being punctured via a pinch, I deflate the tube enough that I can easily push it up into the tire cavity with a tire lever. I then continue to push the second bead in until all is complete. I should point out that I almost never use a tire lever to actually mount the tire. I do it with just my hands. On some tire and rim combinations it takes a toll on the thumbs, but by pinching the tire and tube together I've always been able to manage.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Liked 14 Times
Tubes behaving badly?
Here I had a vision of your tubes running off to the track and gambling away the grocery money, while getting drunk and smoking cigars, then going to a motel of ill repute with some girls they met. (Who needs latex? I'm butyl, baby!)
I was terribly disappointed to find they're just flopping out of the bead.
Partial inflation works for me. Just the amount I can blow in there with my own lungs.
Liked 6 Times
Wow, even if it is a new tube I'd never dream of putting my mouth near a bit of equipment that has to ride through goose droppings, road grime, and who knows what else.
![EEK!](images/smilies/eek.gif)
Thanks, Mr. B, I think the "pushing the tube in with four fingers" as I put the bead on will help (rather than as a separate step). I also inflate it a little with my mouth, even if it isn't a new tube, but I always wipe the goose droppings off first.
![Wink](images/smilies/wink.gif)
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
![Big Grin](images/smilies/biggrin.gif)
I use the cap to keep the stem from debris so given a choice, I'd gladly lick a stem before putting the bottle in my mouth.
![Roflmao 2](images/smilies/roflmao2.gif)
Liked 6 Times
![Smilie](images/smilies/smile.gif)
Getting older and slower!
I also keep my tubes stored in baggies with a little talcum powder. (Whether in my tool box or bike bag.). The talcum helps the tube "behave" better as it doesn't want to stick to the tire and moves freely. Also the talcum/baggie keeps the tube from rubbing against the bike bag. Friction can compromise the tube before you use it.
I use my valve caps until I lose them, usually about the fifth time I air up the tire. :-)
Liked 6 Times
Commando valve stems?!?!?
Bikes: Diamondback Edgewood LX; Giant Defy 1
![roflmao](images/smilies/roflmao.gif)
Liked 737 Times
It happens to me all the time. I deal with it, no biggie. It happens less with fatter tires.
