Bringing my bike out of storage
Bikes: 1st 2009 Kona Blast
I didn't know were else i would post this so here it goes.
I bought a Kona Blast.... 3-4 years ago I think. Any who I used to ride pretty often. Loved getting out into the hills and getting my ride on. 2 and a half years ago I decided to join the military and had to leave it in my sisters garage as storage. I recently have got some plans together to hopefully make my way back home and grab my bike and bring it down south to were I am stationed. I have had this hunger to ride for a bit now and this needs to get done haha.
So for the questions. The bike has just sat for probably a little over 2 and a half years, does it need any specific maintenance. I figure it will need the usual lobe up from sitting for so long, and probably new tires. Anything else that I might be missing? Does anyone know a good shop down in the Oceanside, CA area that I can get the bike looked over and revitalized so I may once again ride?
Thank You in advance for any and all answers!
I would change the tubes, keep the tires. Clean the chain and cogs then re-lube. Shift and brake cables may be a little stiff. Some people lube them, some replace them. 2 years storage in a controlled environment isn't that bad.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6814 Post(s)
Liked 5,525 Times
Why post this in Foo? Seems to me to be more of a General Cycling question.
But thanks for your service.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
^^Indeed.
Moving to General Cycling.
Community guidelines
on by
Quoted: 927 Post(s)
Liked 690 Times
A sturdy u-lock. My first MTB, a Diamondback, was stolen on base (shipyards actually) after just two weeks of ownership even though it was locked nest to a guard shack. All you nice taxpayers reimbursed me. So thanks.
The tires may be ok as long as it wasn't exposed to the elements or cooked in a hot garage for those few years.
Bikes: 20" Folder, Road Bike
Hi,
It depends on how well it was maintained before being stored
on what needs doing now, tyres and tubes should be fine.
Nothing will need relubing if it was properly lubed.
rgds, sreten.
rgds, sreten.
Bikes: Specialized Allez, Specialized Sirrus
Quoted: 17 Post(s)
Overhaul.
Bearings that sit in grease, unmoving, for just a few months can get awfully sticky. Repack 'em (sealed cartridge might be OK) all. New cables, housing, tubes, AND tires. If your bike sat on them during storage, not only will they be flat, they'll have taken the shape of the flattened area. They'll ride like garbage until that goes away. I'd just as soon roll new, as there may be dry-rot, as well.
I ride a Kona, as well; the brand deserves better than a half-assed restore.
Homey
Quoted: 2427 Post(s)
Liked 1,409 Times
Overhaul.
I'm sure this bike was very well maintained before he left and was kept indoors. I don't think he needs to repack the sealed cartridges. He does not need new cables, housing and tires. If anything, new tubes. I have bikes that have been in longer storage than his and all I needed was new tubes, a bit of cleaning and lube.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,562 Times
I stand by what I said, until we know if the garage was in a milder, more temperate part of the country.
Quoted: 14 Post(s)
Liked 13 Times
Replace tubes? Perhaps if latex, but certainly not butyl tubes. I've got tubes ~14 years old in some of my bikes. They may have a lot of patches, but the tubes themselves are fine. Butyl is pretty resistant to deterioration on its own, and installed inside the tire, it's fairly well protected from ozone and anything else that might cause them to deteriorate.
Alan's Bike Shop on Coast Highway is in downtown Oceanside.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 16 Times
I would get the bike and take it for a quick spin and see how it rides compared to what it did when you parked it. It may need a light tune up and possibly some lubrication. FWIW I have taken old bikes, some stored for over 20 years, given them the quick once over and taken them on a 50 mile ride. I have also had brand new bikes that I had to do partial tear downs on.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Homey
Liked 1,409 Times
The bike was stored in NorCal, mild temps, indoors IIRC.
Mad bike riding scientist
Quoted: 6263 Post(s)
Liked 4,286 Times
Stuart Black
Stuart Black
Pwnerer
OP, if you're concerned, most shops offer a minimal "safety check" that should find anything to be concerned about at a minimal price. Ours is $25. Probably worth it for peace of mind.
Liked 4,286 Times
If a bike is just sitting around a garage for 2 years, how does a derailer hanger get bent? It's low on the list of possible problems. I'd put it lower than the tubes needing replaced. If the derailer hanger got magically bent or, more likely, was bent before storage, it would be one of those maintenance items to be addressed that I referenced in my post.
Stuart Black
Stuart Black
I would like peace of mind before I get out there and mess something up. But if it is messed up then fixing it before I ride or riding it and breaking it will really be no different. $25 bucks for peace of mind to me is not worth it. Ill give it the old look over and see what I see, pretty knowledgeable on bike mechanics. If there is something I'm not sure about Ill just be back on here asking more questions. I'm sure Ill have the hardest time finding a pump to pump up the tires... unless my little hand pump is still attached to my bike... that would be super convenient.
Thank You all again for your answers and input.
I still have a picture of my arm in a cast when I broke it on my phone. Maybe Ill post a then and now picture... the contrast is... amazingly different haha.
Pwnerer
Liked 4,286 Times
Boxes stacked up against it, etc. If it was storage used by others, they might not take the same care. I check the hanger on every tuneup and have had furious customers come back complaining about the poor shifting. I check the hanger again and it was bent due to transporting it on the drive side. Considering the potential results, it's always worth checking IMO.
Stuart Black
Stuart Black
