New Bike Ramblings - long...
Bikes: 2012 Schwinn Slicker, 2011 Trek Sawyer, 2014 Kona Unit
This is mostly to get my thoughts down on "paper", but would welcome any input...
My current commuter is a 2003 Specialized Allez that I've upgraded to 105 (or 105 level) components all around. I've managed to squeeze some 700x28 tires on there, but there is no extra clearance whatsoever. That being said, I'm happy with a road bike for my commute. I don't need fenders, because it rarely rains in the mornings (when it does, I just drive in) here in the desert and I don't particularly care if I get wet on the way home. I travel light (change of clothes and an iPad, maybe lunch) with a messenger bag, so a rack isn't a necessity, but may be a nice option.
My commute is a little more than 13 miles one-way (downhill and usually cool to work, uphill and usually hot on the way home). I usually ride in the mornings and take the bus within 5 miles of home in the evenings, so about 18 miles total per day, approximately 3 days/week. I also ride 10-15 miles for general fitness a couple additional times a week. I occasionally (like every few years) will do a century or similar ride. No group rides.
I've decided on a steel frame, because I like them My other bikes are a steel single speed MTB (KHS Solo One) and a steel Trek Sawyer 29er (set up for MTB, not road).
Requirements:
Steel (I could possibly be talked out of this, but not likely)
Drop bars
Reasonable tire size (28s or a little bigger might be nice)
Fenders are not necessary and would likely not be used
Rack would be a nice possibility, but not absolutely necessary
I'd like to keep the budget under $1000
My first thought was to build a Surly Pacer or a Soma Smoothie using the parts off of my current bike. It looks like about $400 for the Pacer frameset and most everything would swap over, except for brakes (I think).
I've gone to several bike shops over the past week or so and rode a few bikes, including several cross type bikes and I think I want to lean more towards the road spectrum than the cross spectrum.
One shop had a 2013 Kona *****tonk on clearance for $850 in a 53cm. My current road bike is a 54cm and the 53 felt a bit cramped when in the drops, but okay on the hoods. The LBS seemed to think a longer stem (it came with a 90mm stem) and a bar rotation would correct that as well as flipping the stem. I'm a bit worried about the Sora components, but since they eliminated the thumb shifter, I think I'll be okay with them. I'm planning on selling my current bike, so I could possibly move the 105 stuff over.
Finally, I spotted a Schwinn Slicker on the local CL for $250. It's a 1x9 and for my use, I think it would be fine and actually kinda cool. That being said, I think I've talked myself out of that one, because I'm worried at some point that I'll want a few more gears on my road bike.
Anyhow, those are my ramblings...I'm definitely leaning towards the *****tonk at this point and will see if they will set it up with a longer stem for another test ride on Friday (if they still have it).
Thoughts, if you have any...Thanks!
Requirements:
Drop bars
Fork and spoon operator
Bikes: 2013 Surly Crosscheck, 1990 Schwinn Impact, 1973 Schwinn Continental
Quoted: 37 Post(s)
Liked 11 Times
I just rode along with someone on a Surly Pacer this morning. It's really nice looking-- I actually sped up to catch up to him so I could see what it was. The guy riding it appeared to have 28 tires in addition to fenders, so you could probably use even bigger tires than that. You might also want to consider the Cross Check instead though, just for the sake of flexibility. The frame set only weighs an extra 0.53 lbs, and as a trade-off you can fit bigger tires and attach fenders and racks. It's designed for V-brakes or cantilevers instead of calipers though.
Bikes: All City Macho Man Disc, Surly CrossCheck, Surly Steamroller, Voodoo Agwe, Trek FX 7.2
All City Mr Pink?
https://allcitycycles.com/bikes/mr_pink
Quoted: 37 Post(s)
Liked 11 Times
Raleigh Clubman?
https://www.raleighusa.com/bikes/stee...ng/clubman-13/
Quoted: 7389 Post(s)
Liked 2,546 Times
Have you considered something used or even vintage? You get a lot for your money that way, especially lighter weight.
All City Mr Pink?
Raleigh Clubman?
ah I thought $1000 for all options, i think the frameset is like ~$700, everything would swap over but you'd need a bb30 crankset/bb
I was thinking about $1000 for a complete bike minus the $4-500 I could get for my old one. That being said, I may have to save up a bit longer for the Mr. Pink...it looks perfect for what I want...
the pacer should be getting an update this next year also, but its not as good as a package as the all city imo.
Liked 2,546 Times
I'd say anything made of Reynolds 531 or Columbus tubing should be nice and light. A big popular choice is the Raleigh International, but don't set your heart on any particular model. In fact, I know a guy selling a 56cm International fairly cheap. I don't remember how much, but I could find out if you like. What size are you?
Quoted: 37 Post(s)
Liked 11 Times
Jamis Satellite Sport? MSRP is only $695.
https://www.myjamis.com/SSP%20Applica...odel=Satellite Sport&cat_grp=road_8
Liked 2,546 Times
Brifters attach to handlebars, not the frame, so yes. The cable stops that attach to the frame use the same type of fastener they did years ago.
back in the saddle
Bikes: Raleigh Olympian, Trek 400, 500, 1500, 6700, Madone 6.9, Sekai 2400, Schwinn Passage, KOM, Super Letour, Nishiki Sport, Vision R45, Bike E, Volae Team
Bikes: A few ;)
The red Mr. Pink framesets are on Closeout, have your LBS check QBP. I just built one up for myself and I love it! You will need new brakes and bottom bracket/adapter or new PF30 crankset if swapping parts over.
Jason
Jason
Liked 2,546 Times
Nishiki
Fuji (you got that right)
Centurion
Not that you said anything wrong, but I'll add that Trek frames were made here for a while and then started to be made in other countries. I believe Trek is now the biggest bike company in the world, yet the standards are still pretty good.
If cat (the OP) is not familiar with these names, I'll spell them properly so he/she doesn't go through a frustrating search:
Nishiki
Centurion
Nishiki
Centurion
I still haven't decided what to do now...if anything...
Liked 2,546 Times
Have you looked at any bikes in the flesh yet? That will help you decide. Visit a bike shop or two. Or go look at the bikes available on craigslist. Or do both.
I've tested 7 or 8 bikes at several LBSs. The only one that I really like so far is the Kona ***** Tonk (on clearance). I haven't tried any CL bikes yet, but I may go do that at lunch. It'll probably be the end of the month before I'm ready to pull the trigger, so I don't want to scour CL too much yet.
Bikes: Gary Fisher Sugar 4+, Kona Rove
If you've ridden 8 bikes at your LBS and the Kona is the one you feel the most comfortable on, and if they changed out the stem for something a little longer, then that's your bike. I sometimes think that the Internet gives us way too many options.
Liked 2,546 Times
Maybe you're best off with a new bike. I looked up the Kona you mention. It looks very nice.
Update - Went back to the LBS and rode the Kona *****Tonk again with a longer stem, set just a bit lower. Yep, that's the one and I think I have a buyer in line for my old bike. If I pull the trigger, I'll post up some pics. Thanks for the input everyone!
