hose clamps
Bikes: Trek 520, Peugeot PX-10
hose clamps
While searching the Internet to find a solution to my dilemma of adding a water bottle cage to my seat tube, the best/only solution I found was hose clamps. All other doodads were wanting me to mount the cage to any component other than the frame. I even saw one that mounted o a helmet. Background: 70s steel frame, paint not in perfect
condition but is pretty good for the age. This bike will be added to my stable of commuters(which currently has 1, so its a very small stable. Also will be set up as the grocery getter and the all around utility bike) if I go this route, electrical tape will be used to avoid further scratching under the clamps. So, here are my questions;
1. Has anyone done it, or found a different/better solution? Don't mind spending a little extra. I do want the cage on the seat tube and not on other whacky places. I won't drill, too many variables there. Other clamp/attachment ideas welcome!
2. If you have done it, or any other clamping method,anything I need to look out for? Do they stay tight, any other issues that you've run in to?
Thanks in advance!
Thanks in advance!
you might find bottle cages with ears to go under a Hose clamp.. they are less common ..
two-fish makes a rubber block/velcro strap on bottle cage ..
Zefal has a do-dad, a plastic hose clamp with a raised part made to thread into ,
and KlickFix has band on bottle cages ..
American Classic Had a nice band on bottle cage scheme , but that was 25 years in the past
and last mention Riv Nuts work very well and are done cold, no heat involved..
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,582 Times
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
specialty tools involved in installing them?
like a poprivet pulling the back towards the front expands it, but the thread of the insert is what pulls it outward.
so a bolt thru a stiff enough washer over the outer flange , tightened up, will also expand the riv-nut.
and tighten up ones that feel loose..
Powerful-Ugly Creature
I've got one of Minoura's clamp on bottle cage holders. It'll mount to anything on the bike that's round, including frame tubes. It can be set to be parallel or perpendicular to the frame, or anywhere in between. Does hold the cage out a bit from whatever you mount it to, though.
One less car
Bikes: '08 Soma Groove (commuter/long distance tourer), '97 Lemond Zurich (road commuter/tourer),'01 Seven Axiom Ti, '03 Look KG381i, '01 Santa Cruz Superlite X
I used hose clamps to mount two trek bat cages to the front fork of my Salsa El Mariachi. I used a dremel tool to ream out a channel in the plastic for the hose clamps to go through and it worked great on the Great Divide...
Jay
Jay
Rocketship Underpants
Bikes: '94 RS Bikes Stampede (commuter), Scattante XRL Team road bike (formerly '05 Cannondale R5000), '05 Cannondale Prophet 1000
Back in May I did a three day trip, and to carry additional bottles I used two methods to mount cages on my fork legs.
On the right leg I used an SKS mount. Worked very well, didn't sleep, easy to mount (and take off and steal if that's a concern), and relatively cheap. https://www.amazon.com/SKS-Bottle-Ada...dp/B0045HY85M/
On the left leg I put a section of old inner tube around the fork leg to prevent scratching and provide grip, and used two hose clamps. Worked just fine.
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
OT question about those trekking bars, is there any kind of weird or excessive flex when gripping the ends of the bars where you have the brakes and shifters mounted? Seems like there would be with that much "bar" between the stem and the actual ends of the bars.
Surprisingly, no, they're actually pretty stiff. I've used steel ones years back that were like wet noodles, but these are aluminum and pretty thick.
Quoted: 676 Post(s)
Liked 13 Times
alright cool, now carry on!
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 393 Post(s)
Liked 49 Times
If your bike has standard (traditional, steel frame) tube diameters, then the "proper" way to do it is with $3 water bottle cage clamps like
https://store.velo-orange.com/index.p...age-clamp.html
and a cage that has "tabs" like these, but preferably longer ones
https://store.velo-orange.com/index.p...w-version.html
I suppose hose clamps will work, but they are pretty ugly . . .
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,582 Times
Quoted: 393 Post(s)
Liked 49 Times
If you have to ask . . . yeah, mismatched wheels roll just as well as matched ones, and hose clamps will hold on a bottle cage.
Other sources for the correct clamp:
$10.00 https://www.bikepartsplace.com/discou...clamps-silver/
$0.99. https://item.mobileweb.ebay.com/viewi...d=400536317030
klick fix makes some nice durable water bottle holders
https://www.klickfix.de/index.php?mod=13&lang=en
sorry about the german only webpage but it has the best photos:
https://www.amazon.de/Rixen-Kaul-Halt...fix+bottle+fix
Bikes: 2014 Brodie Argus
I'm using hose clamps to anchor the front rack plates to my front forks from swinging forwards or backwards, will these hold fully loaded?
Quoted: 5234 Post(s)
Liked 3,609 Times
hose clamps or zip ties, but they aren't pretty
OlyCommuter
Bikes: Spot Ajax for commuting, Jamis Dakota Sport for dirt.
You can get stainless steel hose clamps from a marine supply store, and forget about rust.
Or 'Jubilee Clips' as the British call hose clamps ..
like using any Vacuum cleaner is Hoovering, and any message over the Tannoy is a public adress thru speakers .
that too is a specific companies product becoming a generic term
https://www.jubileeclips.co.uk/
Liked 6 Times
Yes, I've used stainless steel hose clamps on a steel frame that had no mounts. They work fine. I put a layer or two of electrical tape aroung the tube before installing, and the paint was fine when I took them off each year for a total bike cleaning.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
I'm not going to put Rivnuts into the seat tube on my Paramount. I'd use hoseclamps before I would do that.
Bikes: yes
Quoted: 512 Post(s)
Liked 420 Times
Hose clamps are rock solid and not really much uglier than standard water bottle clamps. If the paint is rough, I wouldn't even think twice before using them. If you're really worried about the paint, use some trimmed electrical tape, rubber from a tube, etc. under the clamp. If you have excess band sticking out after installing you can trim it back with some snips (mark the spot, remove, trim, reinstall).
These are what I used and they held up! I didn't put the tape because the bike was old so I didn't care about scratching, but good idea though.
HillRiderEast
Recreational & Family
22
07-30-12 03:06 PM
courtesi
Bicycle Mechanics
22
10-29-10 12:43 AM
