Underlying differences between Specialized Toupe and Romin saddles?
Liked 58 Times
I am impressed by the wide range of widths available across the Specialized saddle line and different weights available at different price points for the same models. Can anyone explain to me the fundamental differences between the Toupe and Romin models? They seem to both be available at similar price points for similar weights. They also appear to be offered with the same range of widths, more or less. Both feature cutouts. So what is different between them, or IOW what is the difference in intent for the two model types. Thanks in advance.
Owned and ridden both. Biggest diff is shape which of course is the biggest diff between all saddles. Most after cycling for many years know what they like....a flatish saddle aka Toupe...front to back and side to side versus a curvy saddle like the Romin which kicks up in back down in the middle and back up at the nose...and side to side convex down....a distinct contrast to the Toupe. That said, I can ride both and believe many could if they get the right width to support the sit bones which is the most important parameter of any saddle I believe.
The Toupe is my favorite saddle. Specialized as with their bikes is forever tweaking their saddles. I would like to try the new Toupe Expert for 2014 or new Toupe Pro which has carbon rails. Specialized finally did away with the goofy front and back pieces on the Toupe to make the saddle even more minimalist.
HTH
HTH
Liked 58 Times
^^^ Thanks. That is what I was looking for. I agree completely with you about the importance of width. Hence my approval of each model being offered in a range of widths. And interestingly the emphasis is not on the narrower widths like 127 mm as in so many other brands. 143 mm and wider are very strongly represented. This is a very sensible way to construct a line of saddles.
Many complained about the nose width on the early Romin and Specialized changed the nose of the Romin a short time back because of rider feedback.
To the Romin 155: I appreciate the fact that you exist. A lot.
Bikes: Orbea Orca Rival, Specialized Roubaix SL2 Rival, Specialized CrossTrail Sport
How do each of those two (Romin and Toupe) compare to/contrast with the Avatar? I have the Avatar Comp Gel on my Roubaix, and it's much more comfortable than the factory Orbea saddle on my Orca. I want to put a new Spesh saddle on my Orca (to go w/ those new Fulcrums, campag4life).
The contour of the Romin and Avatar appear similar, what separates the two is padding with the Avatar having more. There maybe be other differences, but the padding seems to be the most obvious.
I have two Avatar's and two Toupe's, both in 143 and 155. I like them both. Some days the Avatar feels perfect and other days I really like the Toupe with the flatter profile. Still undecided as to the width, perhaps it doesn't matter so much with my body shape.
Falls Downalot
Bikes: Now I Got Two
I rode both Toupe and Romin extensively over a period of about two years. Medium width (143). Toupe worked much better for me, the rear upwards curvature at the back of the Romin never led to comfort on long rides since it seemed to limit the range where I could adjust my azz around. I no longer use either.
I've ridden both. I find that the upward tail and side to side curve of the romin keep me planted in the saddle and thereby let me transfer more power to the pedals.
Bikes: 1975 Albert Eisentraut, 1992 Bill Davidson, 2006 Moots Compact, 2007 KHS Solo-One, 2010 Van Dessel Drag Strip Courage, 2013 Alchemy Xanthus, 2016 Breadwinner Lolo, 2018 Moots VaMoots RSL, 2019 Chapter2 Tere Disc, 2020 Chapter2 Ao Limited Edition
Liked 32 Times
I have both the Toupe and Romin. I use the Toupe on my track bike because of it's flatness it's easier to slide forward onto the rivet during hard efforts. Both are 143 wide. Also I've broken three Romin saddles (across the cut-out every time) and Specialized gives me another one for free.
Liked 671 Times
If you think about it...width and shape are most important. But shell flex that Specialized seems to get right matters a lot...and so does the center cutout for perineal relief.
I have a modern Toupe Gel, and it doesn't have "upholstery" all the way out to the nose tip. To adjust setback would I measure (as I did for my older Toupe and Alias) from the BB plumb line to the front of the saddle? Or, should I work out how to measure from the BB plumb line to the sit bone contact center if I can find that point?
I've always liked the inner thigh clearance of the Toupe 143 (my width) and the 130 (my sit bones only fit this one in the most aggressive position).
The fact that you understand the relation between saddle width and how aggressive your position is says that you get this stuff. Many don't.
Cheers.
