Trek Y 22 MTB - cheap shock available
I have a Trek Y 22 (1997 model) carbon frame mountain bike that needs a shock replacement. Is there an inexpensive alternative to use. I would only ride it occasionally, but would like to be able to take it out now and then. I understand that it is pretty short by todays standards (6.5 inches with only about an inch and a half of travel) Any leads would be appreciated.
Quoted: 113 Post(s)
Liked 16 Times
I would try and rebuild it first, these older shocks are often pretty simple to rebuild.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
I got 99 projects
Quoted: 42 Post(s)
Ride, Wrench, Swap, Race
Quoted: 1575 Post(s)
Liked 1,324 Times
The Risse shocks have proven to be the best for a low-cost, but hi-quality, rebuildable replacement.
in one case, a Risse replacement reduced the rear travel of my ProFlex Attack to about 1" at the axle, but this was a retrofit for a short elastomer stack that never accommodated a damper in the first place. So now it's a race-able "soft-tail" sort of frame, whereas before it had more cush but a bouncy lack of motion control.
My brother replaced the front coil-over shock on his Girvin Vector linkage fork, and the action improved beyond all expectations.
