What does the "LE" stand for on a Schwinn bike?
Can someone please tell me what the "LE" on my Schwinn bike stands for?
I've noticed online that there are regular Schwinn Cimmaron and then there are the Schwinn Cimmaron LE which I have. I am curious. Thank you.
Thunder Whisperer
Bikes: '06 Kona Smoke
Liked 6 Times
It typically denotes its place within a model line hierarchy, much like the trim levels on automobiles.
Community guidelines
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Liked 5 Times
I agree with "limited edition", but it probably means a different paint job. I doubt it had anything to do with different or better components. It probably was just a different color scheme for a new production run, or for a different vendor.
What year is the bike? You may be able to find its catalog online.
Thanks mprelaw. That sounds about right to satisfy my curiosity. Mine is from the year 1985, the first high end mountain bike Schwinn ever made.
It's green in color. Blue for '86 and red for '87 and later. But I've seen the '85 model without the "LE" that mine has and that's what prompted my post.
The Cimarron LE was a "Limited Edition" 1988 model that came only in Forest Green. It was not listed in the Schwinn catalog at the time and I *believe* they were built up to use excess inventory of leftover '85-'86 Cimarron frames. The Cimarron frame geometry changed from 70/70 head and seat tube angles ('85-'86) to 70/72.5 for '87-'89. If you could measure the seat tube angle and also post at least the first two digits of the serial number (on the underside of the bottom bracket) as well as the 4-digit number on the headbadge it would be very helpful to confirm more about the bike.
OK, well that shoots down my theory that the '88 Cimarron LE was only made to use up older 70/70 geometry frames, as your frame was built in Oct. '87, and should therefore have the later 70/72.5 geometry. What is the 4-digit badge number?
rebmeM roineS
Liked 348 Times
My 2008 RANS V-Rex LE came with some lower level components than the previous year's V-Rex. It cost less; LE must mean 'Less Expensive'.
Less expensive is funny! Lol. No I don't think that's the case because I have a better handle bar than the one on their 1985 catalog.
What is a badge number? I don't see any number on the Schwinn metal badge in the front of the bike.
Uber Goober
eberts0604
1
09-29-13 04:04 PM
