My wheels look like crap
Rehabing on old bike with Araya alloy wheels. Wheels are nice and straight, and bearings/cones in like new condition, but the wheels themselves look like crap. Apparently the coating (anodizing?) is wearing off in different degrees around the wheels so in some places shiny, others dull, and the rest in between. I think I could polish them with compound to get a more consistently shiny surface. Any suggestions or methods or products to make them look more presentable? Thanks
You can tear them down, remove the clear anodizing with oven cleaner, then polish them with aluminum polish.
I would then reassemble, and they should oxidize gradually and more evenly after that.
(Compound will not remove anodizing)
- Auchen
- Auchen
I've done that, and it's a ton of work with nice results. However, I ended up buying new nipples and rim strips. Probably 30 hours of labor. Good therapy, but I wouldn't do it again.
By tear them down do you mean...
"I've done that, and it's a ton of work with nice results. However, I ended up buying new nipples and rim strips. Probably 30 hours of labor. Good therapy, but I wouldn't do it again"
Not something I really want to do either.
Was hoping for an easier fix like maybe rubbing wheels with 0000 steel wool impregnated with the aforementioned polishing compound.
What do you think?
Bikes: 1962 Carlton Franco-Suisse Custom,1968 Raleigh DL-1/Tourist, 1971 Holdsworth Professional, 1973 Holdsworth Mistral,1973 Raleigh Gran Sport,1974 Raleigh Grand Prix, 1993 Trek 2200 Composite, 2011 Trek 7.3FX
Liked 6 Times
ive used 0000 steal wool on some alloy hybrid rims, it definately evens out the oxidation... doesn't take it away, just dulls it alot... it willl pass the 5ft rule..
Well, you don't have eyelets in those rims, so I would just go after them with a rag wrapped around your index finger and some Mothers. Still lots of work. I like working on bikes, but dread polishing rims. Having them disassembled like Auchencrow suggests makes it so much easier.
Bikes: '73 Flandria 3 speed, '84 Lotus Legend Compe, '87 Merckx Corsa Extra, '94 Kona Kilauea
I've gone through this on several wheelsets and the fact that you don't have eyelets would make me favor unbuilding the wheels, removing the anodizing with oven cleaner and polishing. I've tried taking the easy way out and working around spokes and it is tedious and hard to get even. You just can't get in close to the spoke nipple easily. If you are good and quick at building wheels, the re-building will be the hard part. I could strip and polish rims without eyelets in about an hour. Rims with eyelets? Never again!!
All Campy All The Time
Bikes: Listed in my signature.
Liked 116 Times
First you should determine if they are actually anodized or just dulled aluminum. Rubbing a spot with a rag and some metal polish will make the rag black if not anodized (and the rubbed spot will quickly come up shiny). If not anodized, you can easily polish the rims with some elbow grease and metal polish.
Whether anodized or not, I like to clean the braking surface (only the braking surface) with Brillo soap pad and water, using long strokes following around rim, then rinse with clear water and dry with a rag. It shines and smooths the scratches somewhat, removes grime, and cleans the tires a bit in the process.
In some cases, the best remedy for tired looking rims has been to buy some (new old stock) rims and spokes and have a respoking day.
Really Old Senior Member
I stink at wheel building so
"First you should determine if they are actually anodized or just dulled aluminum. Rubbing a spot with a rag and some metal polish will make the rag black if not anodized (and the rubbed spot will quickly come up shiny)"
Gonna try this and see what happens.....will let you know the results. Thanks all for suggestions.
it worked!
Tried some aluminum polish I had laying around and that did the trick. Rag came away blackened and the wheel shines. Difference is amazing.
I'll post a photo when done. Based on the sample sections I did last night, it shoudln't take more than 45 minutes to get them cleaned up.
-If the polish is working then certainly they were not anodized -( though I still might be tempted to rebuild the wheels - probably with new spokes and nipples for an even more thorough face-lift. )
- Auchen
- Auchen
Liked 2,262 Times
It's good to know you are excited about the cleaning process. I have to work up to it anymore. I really enjoy the mechanics of bicycling and have accepted the cleaning process as a neccessary evil. I getting tired of the battle. For this process, I like to use my bare skin. For some reason it works really well faster and you can feel when you are covering the joints around the spokes. Makes a mess of your fingers but it does wash off. I like to go around the whole rim and then do the "shoe shine" approach with a clean rag to polish. Final polish is attacking the spoke area and valve stem.
Bikes: Trek 4300, '84 Trek 400,'88 Trek, 85 Trek 720 560, 82 Motobecane Randonee, 75 Schwinn Collegiate, Schwinn Sierra, '84 Trek 890, 2001 Trek 5200 OCLV USPS, 99 Trek Y Foil
Liked 14 Times
Go to the hardware / paint store, get a couple of wood paint stirrer sticks, glue some wool felt pads to 8" of the ends of the sticks, use Mothers Polish, It's way faster and a lot easier on your fingers to get them to really shine.
Wheels finally done
And they look pretty good. Took about 35 minutes per wheel + a few extra to do the rim sides (with Brillo as suggested. Bearings are back in hubs, new skins, and wheels installed. Would have shown completed set up on bike but didn't feel like carrying it thru 2 feet of snow to be photographed. Tried to take pics in the basement but lighting too poor and flash added too many weird reflections.
The comparison pic #2 shows the difference even with some water spots I hadn't yet wiped off. The first photo shows done/undone wheel sections.
Not the most enjoyable job in the world but you do get almost instant gratification. No question best way would be to remove spokes but I am a terrible wheel builder so I decided to do it the "easy" way.
Started out with some very old Eagle One aluminum polish and finished with a fresh can of Mothers.
Overall not a terrible way to spend some time while recooperating from back surgery. Thanks for alll the tips.![](https://bikeforums.net/attachment.php?attachmentid=368097)
