24 inch mod?
how many tools do you have in your home shop ? brazing cutting and all that .
just changing the fork drastically changes the steering .. easy rider chopper your goal? ..
The Recumbent Quant
It would not be easy to put on a rear 24" wheel on almost any 20" folder. Changing on the front only isn't the best idea either.
Regardless, why would you want to?
2. could fit more easily on airplane than 26
3. i've ridden a 20 inch before and I did not like it much at all. Hopefully, 24 would be better and close enough to a 26
Just speculating. I figure that some frames could likely handle it (just 2 inches) while others cannot. Big thing would be brake braze-ons, to which it looks like disc brakes are the only way to go. Or just putting brakes on the front and relying on a coaster brake.
The Recumbent Quant
1. see very few 24 inchers
20" don't ride that differently. You didn't like the bike on which the wheels were mounted...
Bikes: to many
considering that a 24 inch Tern Node d8 is 750 all built up and ready to go, it doesn't make sense to make a monsterbike which doesn't work cause the geometry is all wrong
here is an example
https://www.thorusa.com/tern/noded8.htm
here is an example
2) Even 20" folders usually require some disassembly to fit in standard luggage that's compatible with airline size limits. I'd expect a 24" version to require considerably more effort and likely special luggage that's more likely to raise questions at the airline counter even if it does eventually pass their tape-measure tests.
3) Probably a characteristic of the particular bike you rode. My 20" folder's handling characteristics actually fall in between two of my 700c road bikes (one is a quick handling crit-bike, the other a touring-oriented bike). The smaller wheels are a bit harsher with the same width tires, but using slightly wider tires eliminates that issue. And rolling resistance is marginally greater, but this is pretty insignificant anyway at normal cycling speeds. And I'd be concerned about the variety and availability of good 24" tires in comparison to 20", 26", or 700c.
Raleigh20 PugFixie, Merc
On a Raleigh 20 you need to remove/move the rear seat/chain stay bridges and get a longer fork.
Makes for a nice - and cheaper - ride than an Airnimal.
Mine is running a 7 speed Shimano 110 gruppo. Have brazed new stays in since this pic and it's nice bbq matt black instead of hot-rod primer grey.
![](https://farm3.staticflickr.com/2739/4351558982_6e0587f073_o.jpg)
My Raleigh Twenty site | foldr : A flickr pool | #6460, #5632 & #3407 on the fixedgeargallery
eicca
Bicycle Mechanics
14
09-08-15 10:33 PM
ColonelJLloyd
Classic & Vintage
13
09-15-10 06:52 PM
