Seat post recommendations for controlling Brooks Flyer setback and angle?
Quoted: 63 Post(s)
Liked 10 Times
Nice weather finally, and took the tourer out for a couple rides. All measurements are the same as last season, except changed saddle to a Brooks Flyer. Feels great on the rear, except the stock Laprade seat post on my bike won't allow me to get the nose low enough to remove pressure from that delicate spot in front where you don't want pressure! I know it is supposed to be a little nose-up, but no matter the position, the Laprade keeps it too high and ends up putting pressure there.
Best I can tell, the VO Grand Crus post should do the trick and give me better control. But are there any other seat posts out there that give better control over the angle especially?
Quoted: 1628 Post(s)
Liked 635 Times
Hmmm... I like my most of my saddles just a tad 'nose down' from level, too, but I've never met a seatpost that wouldn't let me go way, way past my ideal position.
Pictures?
Pictures?
Bikes: 1980 Gios Torino Super Record, 1989 Bridgestone RB2, 1985 Trek 520 Touring Rig, 1983 Trek 720, 1985 Guerciotti Sprint, Panasonic DX5000, Miyata 916, 1989 Bridgestone MB2, '87 Schwinn High Sierra, Miyata Ridge Runner
I too find it hard to imagine a post that will not angle the saddle way down past what you would want to ride with. On the other hand, I have had setposts that would not angle the front high enough for my liking. But I do like the front higher than the average rider. If not, it seems harder on my arms and I keep sliding forward.
Any other of your favourite brand seatpost should work. Some have touble getting a brooks back far enough and purchase a setback seatpost like the Gran Cru you described.
Flyer is sprung .. a Saddle clip on a plain post will do ..
Brompton has made the best saddle clip ever .. step-less adjustable and predominantly Aluminum.
Brompton | wallbike.com
SNARKY MEMBER
Are you sure you are not installing the saddle backwards. I did that once with an SR Laprode. I mean I know this guy that did that once.
No longer active
Quoted: 89 Post(s)
Liked 6 Times
That Brompton clamp is impressive. Do you think it would work with a double-rail saddle?
As far as the OP goes, I had similar problems mounting a Brooks B-17 on my XO-3; I never could get the angle quite right with the XO's original Kalloy seatpost (whose clamp is almost identical with your Laprade).
It was kind of a conundrum: on the one hand, I knew a two-bolt adjuster seatpost, like a Thomson or a Thomson look-alike would certainly solve the problem, but, on the other, it would also sorta spoil the looks of the bike (like putting a modern wind-deflector on a classic E-Type Jag). I thought about using a Campy track seatpost, but it seemed... well, too Italian for a famously Japanese bike (sorta like installing the steering wheel from a Ferrari in an E-Type Jaguar).
However I was on the right 'track' with a track seatpost (pardon the cheap pun; it was such a bargain, I couldn't resist it), and after some searching I found a Nitto track seatpost, an SP-72 'Jaguar' :
It has about an inch of setback and the adjustment mechanism is similar to a Thomson's, and (also like a Thomson) can be adjusted quite finely within a very wide range. I should note that a lot of these seem to have NJS 30mm rail clamps, so it took a little while (a patient three months) to track one down with a standard 44mm clamp, but once done: problem solved.
Quoted: 359 Post(s)
Liked 85 Times
Find a saddle that works is my suggestion.
I hate how Brooks saddles have such short rails so they cant be put into a decent position without using a different seatpost.
Only way I could ride a Brooks was to tilt the nose up.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 99 Times
Which is the proper attitude for a saddle, I believe?
mnmkpedals - It sounds like the installation of the post & or saddle is incorrect. Also a saddle with the nose below level usually ( stress on usually) indicates that the reach to the handle bars is too far or too low.
Quoted: 359 Post(s)
Liked 85 Times
Get off my lawn!
Quoted: 93 Post(s)
Liked 99 Times
Wow, you should let Brooks know this before they make any more mistakes!
Quoted: 359 Post(s)
Liked 85 Times
You should go measure the rails vs others.
It is an outdated design from when seat tube angles were much slacker.
Ride them if you like.
I will use a saddle where I don't need to compromise.
But everyone's bums are different and maybe they work for some.
Cisalpinist
Bikes: blue ones.
Quoted: 5 Post(s)
Liked 17 Times
Yes, brooks saddles have oddly shaped rails, but between flipping the post around and infinitely micro-adjustment it's perfectly easy to set them up right. And yes, riding with the saddle tilted slightly up is indeed the way to go with these saddles.
Cisalpinist
Bikes: blue ones.
Quoted: 5 Post(s)
Liked 17 Times
Here's a pic, from a member we all know and love for his veddy briddish IGH beauties.
Quoted: 63 Post(s)
Liked 10 Times
Thanks for the interesting discussion, and let me be the first to say that, yes, I wouldnt be at all surprised if I weren't doing something wrong in this case!
Sorry for not attaching pics with the OP. I posted while heading off to work yesterday, and just getting back now to check in. Here are two pics. One with the seat as far set back as possible, the other with it as far forward as possible. I want it as far back as I can, and to clarify, I'm not looking for it to be nose down, just nose a little lower, since it's a shade too much pressure up front.
No matter how much I fiddle, can't get the tilt any lower with it, so I was speculating it might have been a post issue. Sorry for the less than perfect pics, had to snap these quick before work, and thanks for any help.
Quoted: 443 Post(s)
Liked 28 Times
Get off my lawn!
Quoted: 93 Post(s)
Liked 99 Times
Quoted: 805 Post(s)
Liked 1,858 Times
Nearly any decent correct sized seat post clamp combo hould give you close to 2.00 inches front to back and 30 degrees frome horizontal up or down and 1 to 6 inches rise on a basic brooks saddle this should be more than enough. If you can't make it work within these you likely have a frame that is to big or too small.
Quoted: 359 Post(s)
Liked 85 Times
It is not about a bike being too small or too big, it is about seat tube angles.
As I said earlier, I cannot get my saddle far enough back with a Brooks, but then again I cannot get it far enough back with basically any saddle except for SMP so perhaps I am in the minority.
But as I said earlier, some people love Brooks and that is OK.
