A better argument for today - how much weight matters
out walking the earth
One bike weights 1/4 pound more than the other. How much of a difference does it make over an hour going up hill?
Super Moderator
Liked 944 Times
How steep is the hill ?
https://kreuzotter.de/english/espeed.htm
At 300 watts, save 1 minute over 10 miles at 10% (according to them.... sounds like too much)
Calculator seems to not work correctly. I change variables, but the result sometimes stays the same.
Making a kilometer blurry
What's the total elevation gain on the hill in question?
You're looking at 0.1134kg.
Force required to lift it F=ma, so F = 0.1134kg * 9.8m/s^2 = 1.111N
Work = F * d = 1.111N * elevation gain in meters. For a 3000ft climb, it's 914m, so 1.111N * 914m = 1016Nm = 1016J of work
If you spend an hour climbing this hill, you've 1016J / 60*60s = 0.28J/s = 0.28W to get this 1/4 lb. up the hill at that pace.
So just substitute your elevation in meters and the Strava KOM time for duration and recalculate.
41 seconds?
Super Moderator
Liked 944 Times
33 seconds of you're racing
starting pistol means war
Bikes: Cervelo R3
In the Pain Cave
well my question would be what would the advantage of using the heavier bike be
If you can go lighter I say go lighter. My thought process has always been go as light as possible until it starts becoming less aero or less stable to handle. That or the $$ just is not worth the marginal gain
I do know that if I was 10 pounds lighter in one of my April road races that I wouldn't have been dropped.
![Smilie](images/smilies/smile.gif)
Super Moderator
Liked 944 Times
Reported
Ninny
Strava Segment | Whiteface Hillclimb
According to Bike Calculator 0.25 lbs is worth 3.6 minutes [edit: seconds], making some other reasonable assumptions.
According to Bike Calculator 0.25 lbs is worth 3.6 minutes, making some other reasonable assumptions.
gees that can't be true can it? jinkies, just losing all the extra clothes I normally haul to the top, along with the repair stuff, and using race wheels dear god I'm losing pounds. I'm going to rip a hole in the god damn space time continuum.
Bikes: 89 Raleigh Technium PRE, 92 SP 1000 ti, '09 Team Pro, 72 International, 63 Hercules 3-spd, '81 Vitus 979, 2 Kabuki Submariners, 2 C. Itoh Submariners, Gary Fisher Big Sur, Skyway 3-spd, Robin Hood w/ S-A IGH 5 speed.
How much does a McDonalds quarter-pounder weigh?
Yeah, I'm seeing a difference of 0.38W to maintain speed with the extra 1/4 lb, assuming you'll be in a break with somebody, and in the pack before that, your time will actually be the same. Throughout most of the race, you'll be costing yourself a whole 1/3 of a Watt.
I say I still win, because power needed to keep up is the important figure, unless this is a time trial.
It's still ****ing deflating though.
mass start hill climb. it shatters though and everyone rides alone.
for 3 seconds I'll just ride the bike I keep up there so I don't have to bring extra stuff back and forth
