Can't find a $2.50 part I need
Hello,
Just got another bike and want to attach a Topeak Road Morph pump to the down tube next to a water bottle. The problem is that the mount that comes with the pump is solely for the top tube. In the past, I've purchased a simple plastic pump mount from Performance (same screws are used for the pump mount and the bottle holder) and my problem was solved. To my dismay, Performance stopped carrying the mount.
Is anyone aware of a site that I can purchase one of these things?
Thank you.
Thank you.
Insane Bicycle Mechanic
Quoted: 821 Post(s)
Liked 771 Times
Topeak used to list that mount on their website as a separate item. It's gone now.
Jeff Wills
Jeff Wills
Mad bike riding scientist
Quoted: 6296 Post(s)
Liked 4,332 Times
Hello,
Thank you.
Thank you.
Stuart Black
Stuart Black
Q; can you accept something less narrowly specific ? ' twofish' makes velcro straps and molded rubber bits to tie 2 tube shaped things to each other..
Twofish Unlimited - Bicycle Accessory Fasteners
Attach rubber O-rings under the two screws of your water bottle. The O-rings should be just big enough to slip the pump through. Find them at a plumbing-supply, or auto-parts store. They are a couple of mm thick, and about the size of a quarter.
slide the pump in. It will be held firmly in place, in the V of the tube and the water bottle cage.
This is a weight-weenie thing, for the lowest possible weight pump-holder... But it works great, even for non-weenies.
I just took a pic. My O-rings came from a light-mount, so they have the little tabs on them, but a regular O-ring would do the job just as well.
Location: In The Middle Of "Out There" / Downtown "Lost Angels"
Bikes: 2001 Trek 520 - Hvy Hauler, Epic Adventure Bike / 2011 Fuji Newest 1.0 - Sporty Quick Bike
Quoted: 16 Post(s)
^^^^^^ I'm not seeing the attachment? Possibly broken.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
WB Bracket for Road Morph, Peak DX, MT Rocket, Harpoon, Mini ? Todson
Quoted: 821 Post(s)
Liked 771 Times
It's still on Todson's web page. (Todson is the U.S. distributor for Topeak.)
Jeff Wills
Jeff Wills
I didn't see it when I checked the site either.
Thank you everyone for your input.
