Still Fighting Saddle Issues
Bikes: 2014 Giant Defy 1 Endurance Road
Quoted: 7 Post(s)
I'm still fighting saddle comfort issues. I've been through half a dozen saddles, on a Defy Endurance bike on which I have been fitted. It turns out my sit bones are far apart, and I need a wide saddle - the common 140mm and 150mm wide saddles leave the bones hanging over, and are horribly uncomfortable. I resorted to trying a Bontrager Commuter Gel CRZ+, and it resolved the sit bone pain I was suffering, and despite the fact that it has a channel for soft tissue relief, the sides of that channel are still putting some pressure on the soft tissue, despite wearing padded shorts. I've lowered the saddle nose by 2°, and that has helped, but there is still pressure where, as I understand it, there shouldn't be any. I'm getting frustrated.
I'm beginning to wonder if I need to tinker with the fit - something I have been reluctant to do. The seat is already all the way forward on a zero offset post, and it is KOPS correct - I can't imagine I need to be more forward. The handlebar is all the way up. The saddle height, arm angle, leg angle, etc. are all correct as per the fitting. I've considered tinkering with all those parameters, though. Maybe lowering the seat, raising the sweep on the handlebar to raise the hoods, etc.
If anyone has any constructive suggestions or comments on things I might try, I would welcome them.
Thanks...
Thanks...
Quoted: 1871 Post(s)
Liked 670 Times
I'm not familiar with that saddle, but if its width is what you need, so be it. But, how did you determine that? I don't know what Trek dealers have, but Specialized shops have a neat little device for measuring sit bone width. If possible, get checked at a Specialized shop and see what it shows.
The theory behind the saddles is that there are wide "platforms" which are designed for the sit bones to rest on. Once this is achieved you should not have much pressure on the soft tissues, of either gender. One hitch is that if the saddle is too far back, your body is not in the position that best suits and it tends to reposition forward. This takes you of of the platforms. Another hitch is that if the saddle is tilted too far down you will tend to "fall down the slope" due to gravity. Again, your sit bones slide off of the platforms. I think you also could be falling off of the platforms due to reaching too far to reach the bars, for a third hitch. i think the final one is that if you have the saddle in the correct position and not tilted too far down, it could be tilted with nose too high. Even if everything else is fine, this could cause excessive pressure on the soft tissues.
So for your pain I think there are these four possible causes, not a simple problem. I can suggest the following first step to begin to see what's what. I don't know your answer offhand.
I'd suggest starting with the saddle all the way forward and dead level. Then try to pedal sitting bolt upright and notice if you tend to slide forward or back over say a 20 minute period. It's probably best to do this with the bike on a stationary trainer and with the front wheel propped up so the bicycle is level. We want to see if you need nose up or nose down from level.
I'd also suggest posting a good-size picture of you on the bike in riding position, viewed from the drive side dead on straight. From it one can make an assessment of whether you are reaching too far forward, and just get an overall impression of fit. It's possible to help someone fix their fit remotely, but it needs some direct information, and some teaching moments.
just another gosling
Quoted: 3917 Post(s)
Liked 1,974 Times
OK, try one of these:
Revolutionary Noseless Bicycle Saddle -
Yeah I know, money. BUT. I have a riding buddy who's been on one of these for many years. He's ridden many 1200k brevets and PBP. Says he can't ride a normal saddle at all, and that he has no control problems with this one. He's 6'5", so that may have something to do needing this adjustable approach. There are many of these things from different manufacturers on the market, but this one seems to work and be good quality.
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
Quoted: 32 Post(s)
I've never ridden one of the nose less saddles but know others that have, they sing their praises. OTOH I do believe you could find a Brooks that would make you smile. Have you tried one of those already ? It may be worth your time to have a look at them, sprung or un sprung.
Bikes: Ritte 8055, Felt TK3, Cervelo S2 & P3, Giant TCR
if youre looking for soft tissue relief and often sit on that part (i did on a selle italia slr for years), check out selle smp..they're ugly as hell, they let your pelvis rotate, they're wide(r), and they actually have some studies behind them more than the common "sit bones" bs. they take a few miles to get set up PROPERLY but worth a few miles of fidgeting
Or something like the Concor or those SMP where the nose rises , and the 'saddle' curve between nose and tail
holds you in , better ..
Or a droopy Selle Anatomica they stretch out easily it seems ..
Quoted: 7 Post(s)
I've ridden a lot this week, trying different saddles. Perhaps I'm sore and need to give myself time to toughen up, but I thought there wasn't supposed to be any pressure at all on the soft tissue.
Quoted: 7 Post(s)
Quoted: 7 Post(s)
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
Don't be proud, check out a women's saddle. They are for wider sitbones. I picked up a leather Selle Italia made Terry Liberator women's saddle for $10, shipped, on ebay. It was in perfect condition. I put it on a bike for a female friend to ride. I see nice women's saddles all the time for a fraction of what the equivalent men's saddle goes for.
Quoted: 663 Post(s)
Liked 496 Times
The tricky thing about saddle comfort (or discomfort) is that everything effects everything else. A minute amount of saddle tilt can effect hand pressure on the bars and hand pressure can effect saddle pressure. A fitter cyclist pedals with more force which unloads saddle pressure. The handle bar even or lower than the saddle has the cyclist leaning further forward able to press the pedals with more force that unloads the seat pressure.
Like yourself, early on I despaired for finding saddle comfort but eventually did find it. My longest rides these days are 50 to 60 miles and the saddle is only a problem if I've not been riding much such as Spring after being mostly off the bike during the snow months. This points to another issue - that there is a certain amount breaking in of the butt involved AKA as time in the saddle. Good luck and stay with it.
Quoted: 7 Post(s)
Another one I rode that was decent was Fizik Tritone, it's meant for time trialing but it has a wide channel and you can sit further back on it if you'd like (unlike the Adamo), and it's meant for TT. They build most TT saddles to relieve or alleviate pressure on the soft tissue. Don't buy a saddle without trying it out for 20+ miles. Also, don't give up
https://www.bicycling.com/bikes-gear/...classic-shapes
https://www.amazon.com/Fizik-Tritone-.../dp/B00GFDRK0Y
Liked 670 Times
Thanks for the suggestions. I will post a picture ASAP. One local LBS has a pressure pad for measuring sit bone width, and it did indicate that mine are wide at around 135mm. I need at least a 160mm saddle. I did indeed try the saddle all the way forward, and level. I've also tried a 2° downward tilt. That helped, and I didn't seem to be sliding forward, but there was still some pressure. According to the fitter where I bought the bike, I'm not too far from the handlebar, but I'm beginning to doubt that.
I have not found a fitter who can get me set right, but I have done it for myself a few times.
Liked 670 Times
At this point, I have no pride. I'd ride a pink saddle if it were comfortable. The men's Liberator is wide enough, and it is on my list to try. I just picked up a Selle Royal Ellipse Athletic to try. It has a wider channel than anything I've tried. I also picked up a different stem, just in case. My current one is 110mm with an 8° rise. The new one is 90mm with a 25° rise, which will bring the handlebar a bit closer and a little higher. If the seat is still uncomfortable, I'm changing the stem. If that doesn't work, I might give up and take up golf.
