Favorite Grips
Old 08-12-14, 11:49 AM
cartesian
Liked 6 Times in 5 Posts
Favorite Grips
Your favorite grips for riser bars?
I like the Odyssey Aaron Ross. But I kinda hate that it says "Aaron Ross."
cartesian is offline
Old 08-12-14, 12:02 PM
SquidPuppet
Calamari Marionette Ph.D
SquidPuppet's Avatar
Bikes: 3 Chinese Gas Pipe Nerdcycles and 2 Chicago Electroforged Boat Anchors
Quoted: 2358 Post(s)
Liked 33 Times in 26 Posts
The curved arch is great on your plam. Kraton rubber. Soft yet firm.
SquidPuppet is offline
Old 08-12-14, 12:21 PM
PistaB
Bikes: Bianchi Pista
so good
File Type: jpg
PistaB is offline
Old 08-12-14, 12:52 PM
cartesian
Are the Vans comfy? They look like conceptual art.
Old 08-12-14, 01:00 PM
PistaB
They actually really are IMO. I felt like they took a little while to break in (about a week or so) but once broken in, super comfy and a lot of grip. I have them on my FGFS and my Pista.
PistaB is offline
Old 08-12-14, 01:14 PM
cartesian
Cool. They look like they would dig into your palms, and not provide a lot of cush against vibration. But if it works, it works.
Old 08-12-14, 01:19 PM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
I've got a set of Oury grips on my Masi. I like the grips a lot. I'm switching to bullhorns shortly (with bar tape), but as far as riser grips go, these Oury are my favs.
I will say that installation was a chore. I did the hairspray thing, but one of the grips never did set correctly. I found that cleaning the bar really, really well and then spraying the actual bar itself with a thin, even coating of hairspray gave the best "lock" for the grips (as opposed to spraying inside the grip). Once they lock down, though, they're a bear to get off.
heymatthew is offline
Old 08-12-14, 01:30 PM
cartesian
I go up and down on the Oury's. I'm not the biggest dude, so sometimes they feel too big in my hands. But the design and the cush are tops.
Hairspray is an old trick, but it can be messy. I used to work at a shop, and sometimes we would use either the air compressor or a syringe with rubbing alcohol to get the grips on or off.
Old 08-12-14, 01:34 PM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
I tried the Alcohol thing and couldn't get 'em to dry out and stick (admittedly, I probably used too much) and I didn't have a compressor handy to try that trick, but I saw online that a kid used like 4 of those zip tie things (with the pointy end inside the grip. He pulled the grips on with the zip ties spread out evenly at 12, 3, 6, 9 and once the grip was on, he used pliers to grab the ends of the zip ties and pull them out. Hairspray worked well for me, but I'd probably try the zip tie thing next time.
Old 08-12-14, 01:44 PM
cartesian
Weird. I can see how that would work. The problem with hairspray is that if the grips get too hot, it can warm up the "glue," and then your grips are sliding around. I find alcohol works pretty well. But you don't need a lot.
Old 08-12-14, 01:54 PM
murrellington
murrellington's Avatar
I'm not a big fan of the oury grips. Maybe because I'm just not a fan of riser bars. I had riser bars with oury grips then switched to horns and never looked back
murrellington is offline
Old 08-12-14, 01:56 PM
Carcosa
Carcosa's Avatar
Quoted: 332 Post(s)
Liked 4 Times in 3 Posts
Not trying to derail, but have you thought of bar tape?
I had grips on riser bars but they were cheap and uncomfortable. Pulled them off and wrapped the whole bar in some nice Fizik tape.
Thought it looked better, was more comfortable and gave me more hand positions. Just IMHO (which isn't worth much).
/Continue thread.
Edit: Also switched to bullhorns and never looked back. ^
Carcosa is offline
Old 08-12-14, 02:04 PM
cartesian
Bar shape has a lot to do with the kind of riding you do. I find risers work well for riding in the city.
Old 08-12-14, 02:37 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times in 17 Posts
Yoshida champ grips
Super tacky, supple, and the best part, don't get nasty like ourys and cheaper alternatives do over time as the oil in your skin degrades the material.
Leukybear is offline
Old 08-12-14, 02:42 PM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
Originally Posted by Leukybear
Yoshida champ grips
Ooooh!!! Those look GOOOOOOD!
Old 08-12-14, 03:14 PM
SquidPuppet
Sand the bar to make it fairly rough in the grip area. Lightly Windex the inside of grip and shake out all excess. The grip slides on effortlessly and as the Windex dries the amonia acts like a glue. That method works on grips that are too tight to get on wothout lube. If the grip is big enough to get on without lube, then the only thing that has worked for me is grip specific glue, like Renthal's. Easy to use, no mess, bolted on forever.
Old 08-12-14, 03:24 PM
Philasteve
Philasteve's Avatar
Bikes: Surly CreamRoller. 98 Giant Rincon. SE UVT
Quoted: 5 Post(s)
Liked 12 Times in 9 Posts
Vans Waffle Grip. Odi Longnecks and Ourys for MTB Bars.
Philasteve is offline
Old 08-12-14, 06:59 PM
Char005
i used water activated grip tape for golf club grips for my oury grips. simple as pie, gives you a little time to slide them around into the position you want and then on there like like they were forged onto the bars. i don't think there is an easier or more secure way to do it
Char005 is offline
Old 08-12-14, 07:21 PM
cartesian
Yoshida champ grips
I like these. But man, I'd feel guilty about cutting them to put on a brake.
Old 08-12-14, 08:02 PM
jlafitte
Pirate/Smuggler
jlafitte's Avatar
Quoted: 13 Post(s)
Liked 7 Times in 7 Posts
Origin-8 340mm, was no problem mounting on these Nitto RB-018s
Great setup for busy downtown riding.
File Type: jpg
jlafitte is offline
Old 08-12-14, 08:09 PM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
Those Origins look great on the Nitto Bars.
Old 08-12-14, 08:33 PM
johnnytheboy
johnnytheboy's Avatar
Quoted: 443 Post(s)
Liked 12 Times in 7 Posts
they don't get alotta love in ssfg, but ESI chunky grips rule hard.
johnnytheboy is offline
Old 08-12-14, 08:37 PM
jlafitte
Pirate/Smuggler
jlafitte's Avatar
Quoted: 13 Post(s)
Yep, and on a humble Kilo. Bars and tires are the only upgrades on that bike, almost as sweet to ride and getting as many compliments as my Big Block.
jlafitte is offline
Old 08-12-14, 08:47 PM
heymatthew
heymatthew's Avatar
Bikes: Nashbar SSCX
Ive got some Somas on the way that I had planned to use bar tape on but I'm thinking I like the Origin grips instead. Thanks for the idea. I might be stealing it.
Old 08-13-14, 06:02 AM
jlafitte
Pirate/Smuggler
jlafitte's Avatar
Quoted: 13 Post(s)
No worries bro
jlafitte is offline
