Slower on new carbon bike vs. aluminum?
Bikes: Masi PC1
Hi Guys,
I am confused as why I am slower on my new carbon bike vs. old aluminum? I tried many same segments on Strava during my commute and after 3 months still I could get second best or third best but simply it feels so hard to beat any records set when I started riding in April and now it is August so I should be faster with weekly average of 80 miles / week.
I had FELT Z85 with 105 components and it got stolen, recently I bought MASI PC1 with Carbon Frame and Sora components.
Weight was comparable between Masi and Felt about ~21 lbs. Wheels are comparable weight as well, as well but after few months I can not beet some of the records I have made with FELT.
I also upgraded wheels to lighter wheels (Reynolds Solitude), my diet didn't change, bike seems fit.
The only thing I could possibly imagine is stiffness as I am heaver rider (230lbs)
Could it be the stiffness of the frame ?
Any advice is greatly appreciated.
pan y agua
Quoted: 1472 Post(s)
Liked 758 Times
You'd expect the bikes weighing the same to be comparably fast, all else equal.
The Masi isn't magically faster because its CF
What probably isn't equal is your position. If your fitness is the same or better, the most likely explanation is that your position is a bit more upright, i.e. less aero, on the Masi
You could get lost and die.
You could hit a tree and die.
Bikes: Masi PC1
I didn't mention that the MASI is 56cm not 58 cm as my previous Felt, and also the components are Sora on Masi vs 105 on felt. Could components make a difference, like quality of hubs, bottom bracket etc ?
Also could it be that difference in frame dimensions affect power distribution ?
Super Moderator
Quoted: 1174 Post(s)
Liked 936 Times
And/or weather conditions, accuracy of measurement, and all the other variables related to human performance and the natural environment.
Bikes: Lynskey Twisted Helix Di2 Ti, 1987 Orbea steel single speed/fixie, Orbea Avant M30, Trek Fuel EX9.8 29, Trek Madone 5 series, Specialized Epic Carbon Comp 29er, Trek 7.1F
Quoted: 12 Post(s)
Not fit properly, different gearing, hotter weather, wind conditions, ....... The list goes on and on.
Beer >> Sanity
Bikes: 2014 Evo DA2, 2010 Caad9-4, 2011 Synapse-4, 2013 CaadX-disc
How do you know it's the same effort? Are you using a power meter? If not, then hard to say two rides were the same effort. Also, same effort doesn't equal same results as wind alone could change results. Also, beating a PR isn't as easy as it seems. You make a PR when all the conditions are favorable (wind, hydration, fitness, energy level, etc.). To break that PR you need all these to be favorable again or you have to make marked improvements in fitness and still have everything else remain similar. Buying a new bike (unless you are going from mtb or hybrid to road bike) isn't enough by itself to suddenly make you better.
L-I-V-I-N
Look, you went from 5700 105 to 3500 Sora. That 2200 difference has to come back and bite you somewhere.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
meh
Quoted: 1112 Post(s)
Liked 1,013 Times
I've used a Kona Dew Drop for most of my commutes for 5 years and I started running Strava about 3 years ago. Last fall I picked up a Z85, it's about 6lbs lighter, better components, etc. Even after a year, my old Kona owns some of my PR for my commuting route. This is a little shocking, but with the number of rides the Kona has, it's understandable. Just the right wind conditions, just the right timing on lights, etc. The Felt is taking over most of my top three, but I still get a little giggle to see the old Kona in the top 3 on a segment.
IMO - if the new CF bike is about the same weight as the Z85, there will be a very small improvement in performance. CF by itself will not be fast.
The Kona Dew Drop:
The Kona Dew Drop:
Beer >> Sanity
Bikes: Masi PC1
Bikes: Masi PC1
The Kona Dew Drop:
The Kona Dew Drop:
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
Commute time is an awful indicator, at least for me. Traffic lights and amount of traffic have more bearing on my record attempts than gearing or frame material.
Also, without being on the same wheels and tires it is incredibly difficult to test the real effects of a frame change.
meh
Liked 1,013 Times
pan y agua
Liked 758 Times
Any difference in the friction between the two component groups would be so small as to be noise in this computation.
Quality of the shifting might have a very small effect, to the extent better feeling and quicker shifting might encourage you to be in the most efficient gear more, and might give a positive sensation of quality that could encourage you to push harder.
Bikes: Masi PC1
Deminimis. Friction in all the various components is a very small part of the equation. Far and away the biggest force involved (on flat ground) is wind resistance, then rolling resistance of the tires on pavement. Mechanical friction in the bearings is a distant third.
How about frame stiffness ?
Bikes: Masi PC1
