Another old Worksman Trike
Bikes: 2015 Windsor Oxford; 2012 Trek T900; 2008 Iron Horse Commuter; 1999 Specialized Stumpjumper M2 Pro; 1999 Kona Lava Dome; 1992 Trek 520 Tour; 1980 Fuji Grand Tour SE; 1973 Raleigh LTD-3; 1956 Robin Hood; 198x Worksman Industrial Trike
Quoted: 5 Post(s)
Hi,
I was always interested in trikes and found an old Worksman Trike. It appears to be solidly built,
It is pretty rough so it is a project. The previous owner had no idea about year and model.
It has 24 inch wheels with 24x2.125 size tires. The front has a drum brake (which is dragging now).
The rear has a Shimano 3-speed coaster brake hub.
I plan to strip it down and then rebuild.
Here is a pic. Any idea about the year and model? It does look like one of the current Industrial models.
Thanks,
Thanks,
Quoted: 5 Post(s)
unfortunately I cannot read the serial number as the trike was partially re-painted in the bottom bracket area. I started cleaning and lubing it and know it is an old version of the current "Adaptable Industrial Tricycle ADP-3CB". It has a Shimano 3CC hub which works beautifully. The wheels are very strong with 11g spokes and look like motorcycle wheels.
I got the front drum brake to work. It might still need some adjustment or it just has a different feel than rim brakes. This is my first experience with drum brakes.
The front wheel is actually a 26". It rides well now but I will be greasing all the bearings in the next a few days.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 16 Times
Yes it is solidly built... it is a Worksman. Email them with the serial number. Depending on which Shimano 3 speed would lead me to believe mid to late 1990 model.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Quoted: 5 Post(s)
Aaron: The hub us a 3CC that uses a full cable housing all the way from the shifter to the bell housing. I have a bike with the same setup and I think it was called positron?
Just a try...you still got this old girl? I recently got one and am all Worksman crazy! Let me know!
Quoted: 5 Post(s)
Yes, I still have it.
I stripped down and fully serviced it and put three new tires on. I ride it frequently.
Excellent! I have rode mine every day since I got it a month ago. Sometimes up to 7 miles in a day, which is a lot for me, especially with a load on the end of the "loop". I love mine, although it is the 1 speed version. I've gotten the pdf manual from the Worksman site and am going to convert mine to 3 speed when able. Yours is very nice. Good luck with her.
Quoted: 5 Post(s)
Good luck on your conversion project.
I have made some changes when I re-conditioned her. I changed out that very strong but heavy metal basket to a (still strong) plastic one. I also installed a foldable bike hanger so I put more stuff on that. Here is a latest pic.
Yours was the wire basket at least...mine is the flat steel basket. I need to find out what year mine is still. Thanks for the update
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
I think if I worked in a large factory I would spend too much time zooming around on one of those, and not enough time working.
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times
I have a Worksman Trifecta with 20" tires and a its a single speed.I got it when it was 4 months old from the original owner who happened to be a middle aged lady.
Bikes: MASA Slingshot (x3), Miami Sun trikes, Trailmate Desoto Classic trikes, Schwinn Town & Country trikes, Schwinn Meridian trikes, ReBike, Solar cruiser, 1975 Schwinn Collegiate, 1979 Columbia trike...misc othersmore
Bikes: 73 Schwinn Continental, (my first), 1993 Nobelette, Cannondale 500,Team Fugi, Raleigh Supercourse, Raleigh Gran Sport, 1976 Krystal, Tsunami, Giant Boulder SE, Series 30 Paramount, Scott Unitrack, As long as I have room the Hoard will grow...
Quoted: 26 Post(s)
Liked 25 Times
Worksman Question
On a related, but unrelated note, I purchased a half dozen trikes from a local sale, and pretty much bought them sight unseen and found the whole lot has solid tires, I guess they last a lifetime on concrete. I want to convert the tires to pneumatic and have had no success having the factory reply to my emails. Simply put, the rims are 24 inch, and have a hole where the stem of a tube would go, but all I want to know is there a way to remove the solid tire without cutting it off. Any ideas...
Bikes: Ridgeback Steel Tourer,Recumbent SWB,Steel Road,,Raleigh Twenty,Elephant Bike,Pashley Pronto TNT.
Quoted: 21 Post(s)
Liked 5 Times
Custom built tyre fitting wheel fittings puncture proof tyres Try some bigger levers than usual.Also see if they are glued on.They will be tight.Good luck.
Proud hobo biker
Bikes: 2019 Surly Ogre, 2016 Giant Anyroad 2, Lightspeed Roadrunner trike, SE Tripel (in process)
Quoted: 202 Post(s)
