Does the last vestige of C&V prejudice lay with the steel rim?
Bikes: too many
Quoted: 417 Post(s)
Liked 249 Times
Of all things classic and vintage what can you not tolerate?
Decrepit Member
I think prejudice is the wrong word since it implies a preconceived opinion that is not based on reason or actual experience.
In the case of steel rims, I think most cyclists who have ridden bikes with steel rims will tell you (based on actual experience) that they're heavy, rim brakes don't work well in wet weather, and they rust.
IOW, objectively they suck.
working on my sandal tan
Quoted: 3874 Post(s)
Liked 2,579 Times
I figure they were obsolete as early as ~1928, so I have no love for them. They suck even with the best brake pads you can get.
I've never serviced the BB on my old 3-speed because of the cottered cranks -- did people really drive out the cotter pins and reinstall them every year to maintain their bottom brackets?
Quoted: 1628 Post(s)
Liked 635 Times
I find carbide lamps to be vastly inferior to more modern lighting systems. And nay, I will not use them, sir!
Ride, Wrench, Swap, Race
Quoted: 1575 Post(s)
Liked 1,319 Times
I've got bikes with 27" steel rims that look and work great with the right brake pads, which are old OEM ones.
It rains very little here, but I have experienced the dramatic wet-braking power loss, which is scary!
Sometimes it's hard to find steel rims with smooth, even brake tracks on both rims, and I don't much like the ones with embossed brake tracks.
Araya and Ukai made 27" steel rims that seemed the best to me.
Cotter cranks are good and easy to service if one has a cotter press and uses the original, hardened cotters. Installed cotters must be fitted tight, with alternating nut torqueing and light hammer taps until the nut resists further tightening.
In the C&V world, I have almost no tolerance for older chains or for non-clipless pedals.
Older chains are noisy, shift poorly and even worse with sparse lubrication.
Vintage road pedals work poorly with any kind of shoe that fits my feet, and vintage shoes usually fall apart.
Quoted: 5938 Post(s)
Liked 3,659 Times
Yes!
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 348 Times
My truest hatred is for toe clips and crappy tires.
Scooper covered all of the bases. Why would I want to use a rim that doesn't stop in the rain, offers inferior braking and is heavier to boot? They also invariably come on bikes I have no interest in.
Still learning
Certain electro forged frames made in Chicago that were sold as "racing" bikes. More like boat anchors!
I've been riding mine about 100 miles per week. I select the Varsity often even though I have several bikes to choose from. To be fair, I did replace the steel rims and Huret rear derailleur with aluminum and Suntour.
Polymultiplié
Bikes: Yes, please.
Quoted: 2224 Post(s)
Liked 4,845 Times
One could almost build a complete bike with all the parts mentioned so far. Where is this leading?
and I use the Fibrax Raincheater brake blocks, with the leather strip produced for steel rims.
Still not as good as modern brakes, but I readily accept the performance difference and adjust my riding accordingly.
multimodal commuter
Quoted: 1908 Post(s)
Liked 575 Times
Yup.
OP nailed it and Scooper's reply (that it isn't prejudice at all) proves the point. But you're comparing cheap bike boom crap to much finer gear, aren't you?
Most steel rims (just like most steel cranks) seen today were made after improvements in materials and design had rendered them obsolete. Most steel rims were made of cheap steel, poorly chromed, and fitted crummy tires; and they went into bikes that fit the same description.
High quality lightweight steel rims (such as Dunlop Special Lightweight) are really very nice. they are no heavier than aluminum and have a much more attractive finish. If someone made double walled 700c hooked bead rims from 531 steel, we could make a fair comparison.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 660 Post(s)
Liked 601 Times
Those fixies with the BIG wheel.
Steel rims? You mean Schwinn Varsity and those Sears bikes.
I throw in my "dont even bother" list to include my unholy trinity of stem shifters, turkey levers and chrome dork disk.
Liked 348 Times
Yup.
My limited understanding (very, very limited) about those Dunlop rims you've referenced is that they're easily taco'd. Perhaps the aluminum rims at that time were too, but I wouldn't want one of those either.
So - we have hypothetical steel rims that would cost more to make and steel rims that may have been comparable to aluminum 70 years ago. You'll have to forgive me, but I still don't want them. Steel Dunlop specials were actually the main reason I moved that clubman on to photogravity.
What??? Only 2 wheels?
Quoted: 1225 Post(s)
Liked 658 Times
Steel rims will never be the last against-it as long as gas pipe is still available.
But we all have our own against-it's, don't we?
Real cyclists use toe clips.
jimmuller
jimmuller
multimodal commuter
Liked 575 Times
My limited understanding (very, very limited) about those Dunlop rims you've referenced is that they're easily taco'd. Perhaps the aluminum rims at that time were too, but I wouldn't want one of those either. ... Steel Dunlop specials were actually the main reason I moved that clubman on to photogravity.
www.rhmsaddles.com.
www.rhmsaddles.com.
Bikes: LESS than I did a year ago!
Quoted: 70 Post(s)
Liked 6 Times
Frame/fork - "electro forged boat anchors" from Chicago
Wheels - steel rims (probably along with the "electro forged boat anchors"), just include the hubs that come with those steel rims
Tires - "crappy" ones
Crankset - cottered crank set, preferably of French origin...with non hardened cotters
Pedals - non-clipless...no brand/origin preferred
Shoes - old, non-clipless versions
Lights - carbide lamps
Seat post clamp - per earlier picture (I do not even know what to call that one!)...but...may as well add in the steel seat post that comes with that type of clamp
Brake Levers - any with turkey levers
Rear cluster - add the dork disk!
Shifters - stem shifters
Couple of additions...
Rear Derailleur - plastic Simplex model
Front Derailleur - any Simplex that I have come across
Anyone want to add to this? Seems like a fun build! Maybe we should all pool our resources here, one of us volunteer to actually do the build...and build this scary, disliked Frankenbike! Of course, at the rate this is going, we could just as easily say...buy a Schwinn Varsity...it seems to fit almost all of the criteria!
Quoted: 3039 Post(s)
Liked 3,944 Times
In addition to crank_addicts seat post clamp, I'm going with toe clips and straps.
At least for anyone with a large wide foot.
Single pivot long reach side pull brakes. They don't stop.
one life on two wheels
Liked 19 Times
"Schwinn Approved" decals on other manufacturers components.
Campagnolo NR seatposts.
Campagnolo seatpost binder bolts.
