FFG-2 Tool
Quoted: 77 Post(s)
FFG-2 Tool
I ordered a Park FFG-2 tool for fork alignment. The box appeared new and unopened, but when I opened it, the tools are covered in a layer of dirt and debris and the molded handles on the T are very loose and easily slide off and twist around. Is that normal for this tool?
-j
Quoted: 2027 Post(s)
Liked 1,099 Times
It sounds like only the box was new. I agree, go back to the seller for an explanation and/or refund.
Quoted: 77 Post(s)
I bought it through Amazon. I did send a message to the seller. I wanted to use the tool this weekend, but I will return it if necessary. I can clean the dirt off, but is it normal for the handles to be loose? It seems like it would make it more difficult to use the tool.
Quoted: 5995 Post(s)
Liked 2,932 Times
I used to sell a fair number of these. The tool, as supplied from Park used to come in a large poly bag, and often the knob would be loose in the bag. (things might have changed in the last few years).
Also, the thread tended to be sloppy, but that didn't affect function, since once you set the pointer, you didn't move it during the comparison test.
FB
Chain-L site
FB
Chain-L site
G'fu tool number, gets the 2 T handled ones to get the dropouts parallel ..
https://www.parktool.com/product/fram...auge-set-ffg-2
Clean it up and a little oil on treads . have someone show you how to use them .. I cannot do that from Here.
next one to get is the DAG - 2
https://www.parktool.com/product/dera...nt-gauge-dag-2
Quoted: 77 Post(s)
Park Tool Co. » FFG-2 : Frame and Fork End Alignment Gauge Set : Frame & Fork Tools
Park Tool Co. » DAG-2 : Derailleur Hanger Alignment Gauge : Frame & Fork Tools
The DAG-2 looks like a good tool to have, but the bike I am working on right now is an old Raleigh International. It uses a bolt on derailleur without a hanger. The derailleur that is on it is a Sun Tour V GT Luxe. I ordered new wheels with a 7 speed cassette hub. I think the Sun Tour derailleur will work.
Liked 2,932 Times
Sorry, it's been a while. I confused an FFG-2 with a ***-2. disregard my post.
FB
Chain-L site
FB
Chain-L site
Quoted: 77 Post(s)
I just buy a lot of stuff from Amazon and usually have good luck. I don't think the price was very different from other sources. Does anyone else who owns this tool have loose handles or are they fixed solidly (like I was expecting)?
Are you planning on using the FFG-2 to spread/cold set the frame? If not then good....if so, thats not what they are designed for and can overly stress the dropouts in the process.
-j
-j
Quoted: 77 Post(s)
I am planning to use a 2X4 to spread/cold set the frame using Sheldon Brown's instructions. However, spreading the frame causes the forks to go out of alignment. I bought the tool to re-align the forks after spreading the frame.
Mechanic/Tourist
Thus some of the confusion - whether front or rear they're called dropouts. Rear triangle is what the rear dropouts are attached to, fork for the front dropouts.
Quoted: 77 Post(s)
Adjusting bicycle forkends to be parallel
Mechanic/Tourist
Yes, that's true - fork end makes it more clear.
Old fart
Quoted: 3619 Post(s)
Liked 3,460 Times
This is exactly the reason why I won't buy tools from Amazon. I've been burned more than once--paying the new price and receive a tool that's obviously been used, sometimes improperly, and dirty. They have the option for buying used. If I wanted used, I would've selected used and paid less.
Quoted: 77 Post(s)
Quoted: 77 Post(s)
Here is an update. The vendor sent me a replacement FFG-2 and included a BO-2 tool for free with the
replacement. I hadn't thought I needed a BO-2 tool, but in retrospect it is a tool I would use a few
times during the week and quite a bit on the weekend. I decided to post a review of the tool for
others who may not have considered purchasing one.
As you may know beers manufactured in the US do not require a specialized tool to remove the bottle cap. The cap can be unscrewed by hand. However, the rest of the world has not adopted this American innovation and a bottle opener is required to remove the cap. Although it is possible to remove it with a flat headed screwdriver, that is more time consuming than using a specialized tool. In order to test the tool, I picked up this British made ale at my LBS (local beverage store).
You can see from this picture that the build quality of the tool is superior to this Lucky Lager
branded tool of unknown vintage. The Lucky Lager bottle opener has developed some rust over the
years, but the Park tool is constructed from stainless steel, so that shouldn't be an issue with the
Park.
The tool has a wrap around design that guides it onto the bottle cap. The Lucky Lager tool is a
little more difficult to line up before levering off the cap. It seems like a little thing, but it is
an important feature if you consume six or more beers in a single sitting. At the end of a long beer
drinking session your hand eye coordination can diminish. The tool has a comfortable blue plastic
coated handle and is built with typical Park quality. I wouldn't hesitate to recommend the BO-2 to
anyone that regularly opens non-American made beers. I also found the British make fine ale even if their packaging is inferior.
Park.
Quoted: 9 Post(s)
Liked 1,099 Times
