Long legs and short torso - Any tips?
Bikes: 2014 Cannondale Synapse 105, 2014 specialized Tricross
Hey all, I'm curios as to what you'd all recommend. I've always had a slight problem with bike fit. I can ride just about anything, BUT usually I'm not completely comfortable. I'm 5'9 1/2" tall, but an inseam of 32 1/2 inches with short arms. I used to ride 54's, but found the drops always too aggressive (I have a rode bike that I'm fine with in an aggressive position for 2 hours or so) however for commuting / long distance (100 km +) rides it becomes problematic. Sizing up to a 56 brings the handlebars up, which is great, but then the reach is too long. I can shorten the stem a bit but it never seems quite right. What usually ends up happening is I go for optimal leg extension, but my handlebars (even after flipping the stem up) are about 2" below my saddle height.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
Next time that your in the market for a new bike, consider a woman-specific model. Most of them have a shorter top-tube compared to men's bikes.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Get a higher rise stem, or a steerer extender, to raise your bar up, and possibly a shorter stem.
Interestingly enough after the fit the handlebars were actually dropped lower by a few spacers. It certainly didn't feel that way, but I guess by bringing the bars in, and moving my position up I was able to get into a more aerodynamic position, as I wasn't stretched way out (bum way back, reaching way forward = no power and bad positioning, or so it was explained).
Last up is a new seat, but I'll wait to get the bike back before fiddling too much in that respect. Another upshot is now that I've got my ideal (ish) measurements written down I can reference them when buying my next bike.
Bikes: Nishiki Medalist
Quoted: 8 Post(s)
Liked 10 Times
I, too, fall into the long legs (36" cycling inseam)/short torso category @ 6 feet tall. I suppose a bike such as a vintage LeMond or similar geometry might not be a good idea. What do you think?
Wrench science and other fit calculators have me at a 59cm C-C/61cm C-T frame with a 65-66cm reach. I don't own a bike yet ... but I'd like to find a vintage ride.
I finally gave up and had a custom frame built. Perfect fit. My average speed went way up, and other fit issues (some foot and neck problems) vanished. I should have done it years ago. Would have saved a lot of money (less bikes and components) and had a lot less discomfort over the years. Comfort = speed, at least for me.
In particular, a lot of the Lemond geometries exacerbate this problem according to the designer of my frame. They are very short on trail and their bottom bracket drop is very very shallow compared to a lot of other bikes. When you combine this with the longer than needed top tube that is driven by the long seat tube from a long inseam, it really tends to make the bike skittish. For example, no handed riding is tricky.
The bike I was replacing was a 2006/2007 LeMond Versailles. So I can tell you that from that bike to my new custom compact geometry bike, there is a world of difference. My wife is getting really tired of hearing from me about how much I like this new bike.
Quoted: 8 Post(s)
Liked 10 Times
Thanks for all of the suggestions... a bike fitter suggested a custom build might be one solution. She just happens to work at an LBS that has a working relationship with a couple of builders. Still ... that's a lot of money. Might be money well-spent, though.
I've considered steerer extenders and a shorter stem. I'm not sure how short is too short of a stem before handling might be affected. A 57cm top tube might mean a 9cm extension. And not many bikes I've seen on Ebay have 57cm TT and (what would seem to be) the requisite 59 cm seat tube. A more typical 58cm top tube would possibly mean an 8cm stem.
WSD is something I haven't considered. It might work if custom looks to expensive.
Last edited by dfrench52; 04-04-15 at 06:41 AM. Reason: need to rply to all those who made suggestions.
That said, the custom frame was still an order of magnitude better fit. While that is going to matter on a case by case basis, it sure worked for me. As far as expense goes, it meant buying only one bike instead of two or more.
J.
The long leg-short torso is what a Womans specific design is offered to help. as it is often the Gender's Proportions. Terry.
Of course small wheel Bike Fridays cure the short reach and Toe clip overlap issues..
Quoted: 3409 Post(s)
Liked 5,594 Times
I'm 6'1", but have the legs of someone at least 6'4".
The first thing I do on every bike is use a zero-setback seatpost.
