How do you warm up?
How do you warm up?
I dont ride much. Maybe a half dozen rides a month at most. So its not like I have a base of miles behind me. I'm a painting contractor so I do a good amount of physical labor. Lots of kneeling. Climbing up and down ladders. Pretty much moving all day long. So when it comes to a ride my muscles are usually tight. This morning I rode 30 miles. The first 7 or 8 miles muscles were tight. Hamstrings cramping. After a hard jam up a hill I finally felt good. And really felt great after 10 miles. So what can I do to get the muscles loose before riding?
Quoted: 1810 Post(s)
Liked 1,334 Times
I usually just spin without putting a load on my legs for a couple miles. I can feel when I'm ready to put more of a load on my legs.
Quoted: 6351 Post(s)
Liked 4,950 Times
I just get on the bike and go. Like previous reply I just stay in an easy gear initially.
Cramping might be poor hydration, low electrolytes (unlikely for short rides), or perhaps you are putting out too much torque and need to shift to lower gear ratios. If you are already in the lowest ratio gears, then you need to change them to what you need.
Quoted: 2953 Post(s)
Liked 3,106 Times
Just spin easy for the first 15-20 minutes. For me, that's about as long as it takes for me to finally get out of congestion and on the bike trail or to the city limits.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I ride a little easy until I break a sweat.
It is go time when I'm sweating good.
-Tim-
-Tim-
rebmeM roineS
Quoted: 653 Post(s)
Liked 348 Times
Stretching is a good thing but doesn't have to be before or after a ride. Just do it on a regular basis. I concentrate on legs and lower back.
Some people need to stretch, others do not. I've never stretched in my life -- except in school/the service/groups where they make you stretch.
Bikes: 2 TiSports and a Ho Ko E Koo
Quoted: 54 Post(s)
Don't stretch cold muscles, but if you want to, do it after 5-10 miles or after a ride. Stretching hasn't proved to be of any help.
Quoted: 4560 Post(s)
Liked 2,804 Times
Stretching, before, during and after rides -- especially my neck and legs.
Gradual warm up for the first 10-15 minutes, staying in the small chainring, which conveniently covers the easiest parts of my usual workout routes anyway.
After that warm up I'll stand for about 15 seconds to sorta-sprint or climb the first short steep climbs, just to see how the knees and legs feel. If it goes well I'll increase to 30-60 seconds standing on the pedals to get the blood flowing a little better and check the legs before reaching some tricky segments where I might want to improve my times.
I may start using an indoor trainer before rides to warm up. A friend gave me one he wasn't using. Turned out to be more useful than I'd expected.
After rides I may use a ridiculously heavy nearly solid marble rolling pin on my thighs. It's mostly a kitchen ornament, although I may use it for baking once a year. Yeah, I'll wash it before making those cookies and biscuits.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 599 Times
I try to start by riding lightly for the first couple km and then going harder. But if I leave from home, that's right out the window because first I need to climb a 14% grade, so I guess that's my warm up.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 1071 Post(s)
Liked 804 Times
Need to find what's best for yourself. Spin first, stretch first, hammer right from the get-go ---- every body is different and one must find what works for their body.
some STRETCHING info ---- https://www.nhs.uk/live-well/exercis...re-exercising/
I currently require a "warm up" period of varying cadence and effort, like a race car driver scrubbing tires before a start or re-start. Before my prostate cancer treatment began 4 years ago, I could head out of the garage and within 1 minute push 20/22 mph for the 5 miles to the group ride start.
Tight squeeze ???? I raise the garage door to exit.
I ride a little easy for the first ten mile, then I'm good to go. Occasionally I will stretch when I get off the bike, but almost never before (used to stretch a lot and had a lot of injuries, probably due to cold muscles). Figure out what works for you.
Quoted: 2642 Post(s)
Liked 1,990 Times
But still, take it easy for a few miles. I also wonder about your bike fit, if you're cramping within a few miles.
Bikes: Trek Domane 4.5, Trek 1500
Quoted: 20 Post(s)
I just pedal comfortably for a few miles. To meet club rides now it is fairly easy, as it is 6 or 7 miles (depending on which club) and is a 1% downhill.
Bikes: Volkscycle, Trek Fx3, Specialized Hard Rock
Quoted: 33 Post(s)
I ride in lower gears, spinning a bit until my knees quit burning. Then, I push a bit on higher gears to get my heart rate up until the end. Probably not a very scientific approach, but so far it’s worked for what I do.
Bikes: Shmikes
Quoted: 10223 Post(s)
Liked 5,947 Times
I go slow for a while before I go fast.
Quoted: 800 Post(s)
Liked 218 Times
How do you warm up?
I had previously replied last year to this thread on the Road Cycling Forum, “Pre & post warm-up warmdown.” I have tried to “quantify” my answer (distance and intensity):
…This morning I rode 30 miles. The first 7 or 8 miles muscles were tight. Hamstrings cramping. After a hard jam up a hill I finally felt good. And really felt great after 10 miles. So what can I do to get the muscles loose before riding?
How much if any do you do before and after a ride?
..A ride where you need to shower afterwards...
For me, that’s a ride of minimum of ten miles, and my commute is a minimum of14 miles. I only warm up, and then ride at cruising pace to the end.
When I first started a training schedule for a century, I noted at what mile I spontaneously realized I felt completely warmed up, i.e. I did not consciously look for it, and it usually occurred at about 6 miles. My basic riding routine is:
...last year I developed for myself my"Time-restricted, Personally Ambitious, but Non-competitive CyclistTraining Routine,"…based on ”Relative Perceived Exertion (RPE).”
My basic premise was that I wanted to get significantly fit, within a busy work/family time-crunched life, but not suffer so much that I would abandon the program.
I do have the advantages of a very nice minimum 14 mile one way commute that is easily extended; and a high end, very comfortable carbon fiber road bike that encourages riding.
The RPE scale ranges from 6 to17, with descriptions of the intensity. Multiply the RPE by 10 is the approximate heart rate. Jim's scale is the equivalent on a 0 to 100 scale, easier to think about…
My basic training is to ride at my RPE of 50% for six miles to warm up, then cruise at an RPE of 60%, and do intervals (on hills) at 70% [described as“hard”; 60% is“somewhat hard," and 80% is “very hard" (lactate threshold;breakpoint between hard but steady breathing and labored with gasping). 50% is "fairly light" (my usual happy-go-lucky pace without thinking about it)].
I try to change gears to maintain a cadence of about 85-90 rpm on flats and rolling hills, and about 60 to 80 rpm on harder hills, to maintain my RPE. Shift up to higher gears as the cadence rises, and shift down as the RPE increases.
...I use the semi-quantitative, standardized, but personally relavant system of (Borg’s) Relative Perceived Exertion (RPE) (link) with my own particular adaptation.
Quoted: 5234 Post(s)
Liked 3,609 Times
warm shower
just another gosling
Quoted: 3919 Post(s)
Liked 1,982 Times
I stretch every morning just before breakfast, but I never need to do so until I turned 65.
I don't usually warm up. Maybe I ride a little easier the first couple miles is all. That said, it takes me almost an hour of relatively hard riding before everything is functioning normally. If I ride easy, those changes don't happen.
By far the most useful thing you could do is to ride ~4 times/week, every week. Say three 1-hour rides if that's all you have time for, and one longer ride every weekend. Riding will then be even more fun.
A good way to warm up is to stand for a couple minutes, maybe after the first mile. Gets the blood moving.
Results matter
Results matter
Liked 3,106 Times
This morning I had roughly 90 minutes to do a hard set of intervals (3x2'; 3x1'; 3x30"). Since the actual work time was so short and the efforts so hard, I needed a decent warm up. I spun very easily for the first 10 minutes, then gradually increased till I started to break a sweat (another 10 min or so). Did the intervals and then cool down was essentially a reverse of the warm up.
Rule of thumb: the shorter the event/workout, the longer the warmup.
Not every ride has the same terrain profile or purpose.
A recovery ride is just one long "warm up", power work on the short sharp steep hills and/or HIIT speed work intervals does require thorough laddering up of cadence/effort to start and a cool-down as well.
Going to the Farmer's Mkt on the town bike requires nothing more than remembering to bring cash.
-Bandera
-Bandera
