Aren't we supposed to eat salad and lose weight in our 60's?
I weigh about 190 and am short of 6 foot. I remember twenty years back watching people at my present age eating salad and crackers for lunch.
I'm thinking I should weigh maybe twenty pounds less, but I'm not fat. That's where biking plays a big role, I guess. Just like most of us, i take my riding seriously. I'm just not a skinny guy.
I'm not eating salad and crackers for lunch either, I'm downing a big lunch, albeit a healthy one, after my daily ride. I avoid red meat ,eggs , ice cream, pastries and fast food.
Am I doing something wrong here? I worry about this a lot lately. I'm thinking I should trim down?
Likes For 10 Wheels:
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 397 Post(s)
Liked 327 Times
You may want to do some research on eating meat and eggs. My wife went on the carnivore diet recently to resolve some digestive issues and lost a ton of weight in the process. Carbs and processed foods cause weight gain, eating meat and healthy fats does not (unless you overeat, of course). Note that it's our preference to eat high quality meat and eggs, meaning meat from grass fed animals and eggs from free range chickens... Avoid meats full of chemicals and hormones, which is unfortunately most meat you can buy at the store.
Likes For PoorInRichfield:
Quoted: 5937 Post(s)
Liked 3,648 Times
From what I've read (and based on my personal experience), your metabolism starts to slow down north of 60. I also wouldn't be surprised if there is quite a bit of variation here. I know I need to eat less (and eat smarter) to stay on top of my weight even though I am fit and active.
Quoted: 1984 Post(s)
Liked 2,100 Times
A Whole Foods Plant Based Diet will get you there. It will take time to adjust. The Science is here https://nutritionfacts.org
Likes For Classtime:
I know it’s a bit controversial but I lost 25 lbs over 10 years ago by intermittent fasting. I eat during an 8 hour window which basically is 2 meals a day. I was a classic yo-yo dieter having tried everything from low fat, Atkins and a bunch of other strategies. I’m 5’9 1/2” (was close to 5’11”)at this point and 160 lbs as I said for over 10 years, at one point in my life well over 200 lbs. I continue to eat this way and consistently ride in the early morning before anything except water and coffee. Works for me but YMMV.
Likes For Jtmav:
Bikes: Yes
Quoted: 1882 Post(s)
Liked 1,549 Times
I figured when I reached 65 I'd jolly well have whatever I wanted for dinner (big bowl of ice cream last night!).
More seriously, just keep tabs on what you put in your mouth and cut out the snacking in between meals. Its worked for me. Yes, I did have a bowl of butter pecan ice cream last night, but that type of dinner is the exception.
Quoted: 5234 Post(s)
Liked 3,609 Times
at 64 I’m 5’11.5” & a trainer once told me about 10 yrs ago my target weight based on several other factors is 196. right now I’m 230lbs. doubt I’ll ever see 196 until I’m in my 80s. my HS weight was 175 if that even matters
Quoted: 4644 Post(s)
Liked 5,179 Times
I’m 6’1” and currently weigh 190 lb. I can train down to 165 lb in under 6 months by simple calorie counting, eating the same healthy food in controlled portions. I don’t do that all the time because I feel a little underweight for my height and build at 165 lb, But I will do it for Alpine cycling events, where I find the weight loss is a significant advantage.
Likes For PeteHski:
OM boy
Bikes: a bunch
Quoted: 564 Post(s)
Liked 723 Times
As we age, we're trying to retain positive characteristics and minimize the negative. Keep strong cognitive and thinking/brain function. Retain strength and structural integrity, flexibility and bodily functions and keep illness/disease at bay.
So what and how we eat is , of course, important.
Also important is how we manage our body thru physical and mental functions and processes.
I think it's well accepted that neither muscle/structural integrity nor mental function remain in some constant state. They need to be used, in a fashion which helps maintain or improve.
so, my observations...
Diet/nutrition depends. We've learned a lot, but not everything. Formulating 'the best' diet is very much debatable, and contingent upon personal things.
If we're talkin purely the physical; Weight is not the primary factor.
190 lbs at 6 feet depends, if with a 36 inch or + waist, maybe not as much muscle as other stuff.
Carrying unnecessary weight is not desired as we age. But retaining, building muscle is. Muscle is not just about strength. It's also the primary shock absorber for our skeletal structure and integrity. Really key as bone and connective tissue lose their youthful characteristics.
Diet alone won't achieve that (but is critical important). Cycling alone is clearly not the answer either.
Personally, I know I'm under-muscled, and need to step up the overall muscle building. It's not a one-time thing. Like laundry,eating, vacuuming - it's a constant, steady required job.
The hard part is getting it done without too much 'indoors' - a hard thing.
I'm convinced that some 'objective', knowledgeable outside evaluation of ourselves, is important to properly recognize what needs the most attention.
I'm very lucky t have friends who are Pros in that regard - and have no problems mincing words to let me know what I might need.
Look at others older than you, and honestly evaluate what they show, which you might like for yourself and what you wish to avoid - that will point to what you might need to focus on.
Ride On
Yuri
just another gosling
Quoted: 3920 Post(s)
Liked 1,992 Times
Agree with PeteHski - smaller portions is the way to go. No need to change anything, just put a little less on your plate. Your stomach will adjust to this quite quickly and soon won't know the difference. Only the scale will know.
Results matter
Results matter
Likes For Carbonfiberboy:
feros ferio
Quoted: 1410 Post(s)
Liked 1,366 Times
There is no substitute for cutting out the refined sugar, white flour, and excess sodium. Cutting back on alcohol (or abstaining completely, as I have done my entire life) helps you avoid empty calories, as well.
For exercise, cycling has always been my aerobic conditioner of choice, but I supplement it with weight training for muscle mass maintenance and lots of fast walking for load bearing / skeletal maintenance.
I don't watch my weight, but I do watch my gut and my overall percentage body fat. Staying lean also helps me with my inherited (courtesy of my maternal grandmother) tendency toward hypertension, which I can control through sodium restriction, weight gain avoidance, and diaphragmatic breathing. I monitor my BP periodically at home, and the relaxation response from proper breathing rapidly drops it by about 10 points and keeps me in a normal/healthy range.
Bikes: Shmikes
Quoted: 10239 Post(s)
Liked 5,962 Times
Lean body mass is strongly associated with reduced all-cause mortality late in life. This effect is independent of body fat, which ,has a U-shaped association with mortality. The take home is, once you are old, it’s better to be a little fat and muscular than thin and under-muscled, and fat only seems to be dangerous in old age when you’re very overweight or too skinny. Salads are great and animal protein sources have their drawbacks, but frail is a very dangerous and unpleasant way to end up.
Likes For MoAlpha:
Quoted: 1072 Post(s)
Liked 807 Times
Likes For OldTryGuy:
Liked 1,992 Times
Results matter
Results matter
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2750 Post(s)
Liked 6,105 Times
Besides portion control and staying away from refined products, my wife and I have always been big proponents of the Mediterranean Diet. Longevity studies has borne out how good it is.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 4895 Post(s)
Liked 4,067 Times
70 years old here. HS weight was 150. Had my "Ah ha" freshman year of college that I was to built to handle more than 160 pounds; that I should never get past 165. Raced in my 20s at 145. Spent most of my adult life pushing the Ah ha but never exceeding it. In my 60s started seeing that my life would be better if I weighed less and simply started eating less. I'm now down under 150. And I expect that weight will continue down and continue to feel "right" as it happens.
My crude "take" - my organ weight is probably not going to change much. My bones are getting lighter (sadly). My muscles are getting lighter (also sadly -I can make efforts to slow that process but without heavy weight lifting (steroids and injuries?) I cannot stop it. So maintaining my previous weight is simply adding fat to my declining body. Do I really want to burden my weakening body carrying around increasing load of little worth?
Edit: I've been eating close to the Mediterranean diet for years. Whole grains forever. Little sucrose. Almost no meat save occasional pork or chicken eating out and regular consumption of high Omega 3 fish at home. No dairy except a little cheese eating out. Biggest fat source - the fish and olive oil are battling that one out.
I'm the OP. Whenever I study older people , it seems the one's getting around best are those wiry lean types. Nothing happens instantly. Let me get to 185 first.
Likes For AJW2W11E:
Liked 1,992 Times
Results matter
Results matter
Quoted: 26 Post(s)
Liked 40 Times
https://www.booksfree.org/the-obesit...free-download/
Cliffs Notes version.
According to Dr. Fung it is not about exercise, fat, calories or some superfood.
It is about one thing.
Insulin.
I found the book to be an interesting read.
Intermittent fasting helped me lose the ten pounds I was beginning to think were mine for life.
One more thing.
Belly fat, especially for guys is bad news.
fat biker
Insulin.
One more thing.
fat biker
Likes For fat biker:
Quoted: 2662 Post(s)
Liked 3,228 Times
Insulin.
One more thing.
fat biker
Insulin.
One more thing.
fat biker
It’s Not Calories… It’s Hormones: A Response to Dr. Jason Fung
Quoted: 612 Post(s)
Liked 807 Times
NO
Salads are fine but I recommend a balanced diet.
I enjoy keto and carbs and have a lean strong body.
Be active and try to insure consume <= burn !
Likes For joesch:
Liked 2,100 Times
“Fat burns in a carbohydrate flame.”
Quoted: 844 Post(s)
Liked 1,701 Times
Well, there you have it. Just don't eat meat, eggs, or anything plant based. Or, just don't eat at all. Watch the weight come right off!
Likes For Bald Paul:
