First Time Chain Waxer Calling on Chain Waxing Gurus
#126
Quoted: 798 Post(s)
Liked 1,864 Times
Since I used the gulf wax they had the 4 blocks, so I used the pressure cooker setting on high for the first 5 mins to get the initial melt really going, then I dialed it back to the Slow Cook + Less setting which cooks at 190F. Based on my poor googling skills, I found this....Slow cooker setting + Less – Cook at low heat. Reach 190 °F only.
Slow cooker setting + Normal – Cook medium heat. Similar to the “Low” setting on the slow cooker. Reach 195-205 °F
Slow cooker setting +More – Cook at high heat, similar to the “High” setting on the slow cooker. Reach 200-210 °F.
Anyway, once it was all melted, I slowly introduced the PTFE and used an old whisk I had to ensure it did not clump, and then introduced the chain letting it cook for 20 mins and swishing around every 5 mins or so to move any air still in the chain out. When I pulled it out, I let it drip for a few seconds, did a quick wipe of both sides with some paper towels then hung it in a 5 gallon bucket to cool. The little gizmo I made to dip the chain I created a little handle that would hang on a hanger with the cardboard pant liner. I just make sure the chain length was short enough to not touch the bottom of the bucket.
It could not have been easier. If there was a "worse" part of this whole thing, it was trying to figure out how to roll the chain post wax to loosen the links. I ended up rolling over a 3/4 in dowel rod I had, but I had to clamp it between a couple of my saw horse in the 2x4 supports. My horses are just abs plastic , so it was less than steady, so I need to create a better solution.
If I was to use a pre-mix wax, the Slow Cooker + Less would be the setting I would use.
Likes For jaxgtr:
#127
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,561 Times
#128
I'm late to this party! I've been reading about waxing chains for about 50 years(yea I'm that old), but never got around to trying it. Recently my parents died, and cleaning out their house I snagged one of my Moms old crock pots to give waxing a try. So I used some Gulf wax, straight paraffin, in the crock pot. Let it melt, which took longer than I thought it would, and dunked the chains from two of my bikes. These are not new chains, and the only prep I did was wiping them with OMS to get as much dirt and grease and oil of the surface. Let them soak for a while(in precise scientific terms) took them out, let them drip, freed them up by bending them, and put them back on the bikes. I have NEVER ridden a bike with quieter chain, There was almost no chain noise. And it's continuing to be quiet a hundred miles later. And it's much less dirty.
My question is; Why is it necessary to remove all oils from the chain ? Doesn't the oil mix with the wax?
I'll keep waxing, but I don't see how going to excessive effort to degrease the chain has any real value other than starting with a clean chain.
#129
Liked 1,561 Times
#130
Advocatus Diaboli
Quoted: 4804 Post(s)
Liked 1,547 Times
I've only ever used Molten Speed Wax. I'd seen the home brew formula posted above, but didn't want to bother tracking down and paying for shipping on all the proper ingredients. Besides, the MSW was less than 20 bucks and, more than a year later, half of it is still in the bag, untouched - I'm a-okay with that kind of value for convenience.
I did see this reference on the MSW website, what's the difference in training vs race chains they're referencing where one type uses twice the volume of wax vs the other?
1 lb. of MSW waxes a minimum of 8 training chains or 16 race chains.
Is 2qt about the right size for the crockpot? Found this value play on Amazn for $20. Use "warm' or 'low'?
#131
Quoted: 20810 Post(s)
Liked 9,456 Times
I'll probably cave and give the hot wax thing a try some day; I was one of those dorks with the 101 Chemistry experiment sets in grade school.
Yeah, 2qt is the size that I have and is good for having enough depth to submerge a chain with less wax volume. My Crock only has Low and High. I use Low.
#132
Liked 1,561 Times
Crock-Pot 2 Quart Round Manual Slow Cooker, Black - Walmart.com - Walmart.com
The low setting of this unit corresponds to about 210 *F, which seems to be a good temperature for waxing. Plus just > $3 for the wax:
Gulf Wax Household Paraffin Wax, 16 oz (4 Pack) - Walmart.com - Walmart.com
If I can do it, anyone can.
#133
Liked 1,561 Times
I read this somewhere else. To clean the wax, someone suggests adding a cup of water into the Crock Pot before turning it on. After the paraffin melts, it floats on top of the hot water, and the dirt previously trapped in the wax sinks down into the hot water. Then turn off the Crock Pot and wait for the wax to solidify before removing it and dumping the water with all the dirt in it. Obviously this only works with paraffin without any additives (e.g., PTFE, MoS2, WS2).
Likes For SoSmellyAir:
#134
Wow, I only leave my chain in the pot for about 10-30 minutes. After two to three rounds of sonic wash with simple green and water, my chain gets a hot water bath, cold rinse, mineral oil shaking, and another hot bath followed by a cold rinse. I then use a heat gun to dry my chain before droping it in the pot. I can get four to five chains in the sonic wash and shuffle to the pot for waxing. I am up to 10 chains per cycle (roughly every two months or so). I get around 150-200 miles per chain.
#135
Likes For Racing Dan:
#136
Quoted: 243 Post(s)
Liked 234 Times
I use a 1 1/2 qt. 1 lb of wax fills it about 2 1/2 inches deep.
#137
Liked 1,561 Times
Dang, you guys got good deals. But a 2 quart Crock Pot fits my chain so neatly in a single layer.
#138
Liked 1,561 Times
The most recent time I left the chain for half an hour in the melted paraffin in the Crock Pot on low with the cover on, swishing a few times; I think this is sufficient time for the chain to reach the equilibrium temperature and for the paraffin to penetrate the chain.
#139
Liked 1,561 Times
End of July Update. Second ride after second wax application, 33 miles this morning, so total mileage is about 58 miles. Over the course of about the latter half of my ride, the chain seems to sound noisier compared to similar mileage on lube, but not in a bad way. It is a bit hard to describe; the chain sounds louder mechanically when just pedaling along, but no squeaks, scrapes or other friction sounds. No shifting issues. Dark grey wax flakes on entire drivetrain which brush off easily and do not stain fingers. The mileage I can get on this wax application may indicate the cleanliness of the chain and whether it needs to go through another cleaning prior to the next wax application.
#140
Just got turned on to waxing recently. Refined paraffin wax and PTFE powder in a crock pot. Rode for just over 200 miles over the past few weeks and it performed flawlessly and super quietly….and is still clean. I could’ve gone longer, but changed it out for the brand new(freshly waxed) Ultegra chain I have.
Put 10 miles on the Ultegra chain(w/ Wipperman master link) today. Whisper quiet.
I’m completely sold on waxing.
Likes For GBK233:
#141
Quoted: 798 Post(s)
Liked 1,864 Times
when I got back today from my ride, I noticed a very small amount of gook on the chain, which I believe might be some of the left over squirt residue from the chain rings, which I do not remember wiping down and cleaning while I was running my chains through the wax protocol, but at this point, it not worth the effort to do anything about it until I am ready to use the next chain in the rotation. I will re-clean the cassette, pulleys, and chain rings at the point and should be good to go.
Likes For jaxgtr:
#142
Quoted: 798 Post(s)
Liked 1,864 Times
#143
Liked 1,561 Times
I have read the same too but I have also read many anecdotal reviews stating that waxed chains are whisper quiet. I suppose that discrepancy is due to the prior state of chain maintenance on lube.
#144
Bikes: 2020 S-Works Roubaix, Infinity seat
Quoted: 20 Post(s)
Liked 25 Times
#145
Sure, lots of bike lube "advice" is highly dogmatic and is never really challenged. If you want to know, do your own test and make up your own mind, as you kind of already did. Im betting not deep cleaning old lube from the chain makes minimal difference unless its silicone or other compound that prevents other lubricants sticking to the chain. For instance, factory chain grease and ordinary oil is fully miscible with hot wax and its likely fine just dunking and swishing the chain in hot wax.
Imo, the single tallest barrier to start waxing and sticking to waxing, is the excessive and convoluted cleaning processes combined with little crock pots that take forever to do what you can do in a saucepan in a few minutes. Im not aware anyone tried tried dunking a fresh chain straight out the box and compared it to a fully degreased chain. Im betting the difference i minimal.
#146
Liked 1,561 Times
Yes, but one is free to do other things while the crock pot is taking its time to melt the wax.
#147
"But nonetheless, I am not sure that the first pre-waxing cleaning "makes minimal difference" if the chain has factory grease and/or regular lube."
You will never know unless you try. For a while I dabbled in waxing with old school MC chain wax, - the kind you get in a big flat tin to put on the stove. Its similar to paraffin wax but less brittle and impregnated with graphite. I could detect no ill effects of a new chain directly in the tin or a used one that didnt get other than rudimentary cleaning, except the wax getting slightly dirty with grit falling to the bottom. The wax adhered just fine. If I was to go down that route again I wouldn't dream of engaging in elaborate cleaning regiments that ppl around here claim to be necessary.
#149
Liked 1,561 Times
Labor Day Weekend Update. Put another almost 200 miles on the chain since my end of July update, including a ride two weeks ago when I was caught in a drizzle that did not show up in either weather app. Chain sounded fine on first ride thereafter but maybe slightly raspier during my last ride a couple of days ago, so decided to wax the chain today. Chain had dark grey wax boogers which easily came off in boiling water, then washed in detergent, rinsed thoroughly, and baked (at 225 *F for 15 minutes) to dry. Afterwards, chain still bent like there was residual wax in the links! Actual waxing part was easy. Thank you to everyone who had suggested above to wipe the outer link plates upon removal from hot wax. I did that before reinstalling the chain and no shifting problems this time.
#150
Bikes: yes, i have one
Quoted: 1152 Post(s)
Liked 1,198 Times
Still think your process is too labor intensive with the baking, boiling, and boogers but if it works for you then enjoy the ride.
tomorrow I'll be waxing too.
Likes For spelger:
