Continental 5000
climber has-been
Quoted: 3466 Post(s)
Liked 3,608 Times
Liked 2,995 Times
Likes For Troul:
Bikes: Wabi lightning & Fuji Feather.
Quoted: 769 Post(s)
Liked 1,761 Times
The 5K's are a PITA to mount on most rims, the 4Ks were not. That is a major difference.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Likes For livedarklions:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,045 Times
4000's in the 700x25c size are noticeably larger than a 5000. I learned that because with 4000's there is very little clearance between my fork and tire but with the 5000 there is several mm's more clearance. That may be a contributor to the 4000's having more rolling resistance.
Otto
Liked 2,995 Times
Quoted: 829 Post(s)
Liked 1,676 Times
Boyd Cycling (who makes a darn fine carbon wheel, IMHO) has issued a warning about potential damage caused by attempting to mount the GP5000 tubeless on their wheels. Basically, if you try, and damage the wheel, they won't cover it. Should tell you something.
Likes For Bald Paul:
Quoted: 1947 Post(s)
Liked 2,178 Times
I can tell you from first hand experience that the GP5000 tubeless tires are the most difficult to mount tires I've ever tried. So hard, in fact, that after 4 hours of trying (the last hour at the LBS) we gave up. I went with GP5000 clinchers with tubes and had zero mounting issues.
John
Tragically Ignorant
Liked 9,098 Times
I just had to change a tube roadside on a GP5000 today, and can attest it actually was one of the easiest tube changes I've ever done. What you say about the tubeless version is downright scary. How bad does a tire have to be to pose a danger to the wheel on install? And even if you had successfully mounted it after 4 hours, there's likely no way you ever would have bought another one.
Sounds like Conti needs to go back to the drawing board on that one.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,045 Times
Otto
Quoted: 829 Post(s)
Liked 1,676 Times
