Do you use the same bike with trainer that you ride outdoors?
I know they're designed to be quick release to use that way, just wondering if anyone does that? Is there more or a chance that the rear tire might blow out, or would you see the wear before it ever got to that point?
Quoted: 20810 Post(s)
Liked 9,456 Times
I use the same bike, but I prefer the wheel-off trainers - they're generally more quiet, it takes tire wear out of the equation, you don't have to worry about wheel/tire slip and I find set-up to be less fussy.
With the wheel-on trainers that I used in the past, I preferred to have a dedicated trainer tire - for me, a trainer tire was more quiet, less prone to slip during sprint-type efforts and less likely to cast off black rubber dust. This, of course, meant that I'd either have to have a dedicated trainer wheel or I'd have to change the tire if I wanted to take the bike out for a ride.
I have one bike and no room for a 2nd, so same bike, but different tire, so it's not an easy switch. This coming indoor riding season I expect to use a different tire and different wheel, so the switch to riding on the road will be easier. I think. My skills have definitely deteriorated.
OTOH, my bike lives in our foyer, which is where I ride my trainer, and my wife does not object. She's a peach.
Likes For philbob57:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I use a Wahoo kickr Bike.
It is configure exactly the same size as my road bikes, even with the same saddle brand/model.
Best part is it's always ready to go.
Barry
Barry
Likes For Barry2:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,639 Times
Have a dedicated trainer bike which uses a freewheel rather than a rear tire. Wahoo Kickr. Adjusting the rear mech between two gear sets is too much of a PITA, so it stays there.
Had a squirrel cage ‘trainer’ many years ago and it ate tires after it would glaze them over.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
i have one bike i can ride and i use it on the road and with a wheel off trainer. sort of stinks but only really a hassle when the riding season winds down or up.
I have a wheel-off Wahoo Kickr Core trainer with an 2016 Orbea Avant permanently attached. Before purchasing the Orbea, I would mount my Cannondale Synapse to the trainer only during the Winter months. I found the Orbea on Facebook Marketplace. It was being sold locally, in near-new condition, priced right and the test ride was comfortable.
I had it adjusted to match the settings from when I had the Synapse professionally fitted. Both bikes now feel almost identical and I can now use the trainer when the weather is lousy during the riding months and throughout the Winter without having to mount the Synapse on it.
Very happy with this 2-bike setup and consider the money spent on the Orbea well-spent. The only difference is the Synapse was ugraded to an Ultegra Di2 groupset while the Orbea has a mechanical Ultegra groupset….but I can live with that. It does, though, give me an appreciation fr how good the Di2 system is!
Quoted: 506 Post(s)
Liked 638 Times
Simpler solution: get a set of rollers. Nothing to change and no tire wear issues so no special tires needed. Is better for your riding skills too, making you a much smoother and stable rider.
Bikes: Way too many
Quoted: 900 Post(s)
Liked 606 Times
When I had a wheel-on trainer, I used the same bike inside and outside because it could a few seconds to set up and I used the trainer almost like a stand.
Now I've moved to a wheel off trainer, the bike stays on the trainer unless I really want to use it, otherwise I take my other bike out. It doesn't even take that long to detach it and put the back wheel on, but I'm lazy and the other bike is just ready to ride.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
I just bought a Saris H3 (on sale at REI) and am thinking about this while I wait for delivery.
My wife and I have primary rides that are titanium and steel, respectively. Contrary to some claims, neither of these is necessarily less fragile than carbon, and in our cases, it is more expensive. So the question arises, are we putting these bikes at a significant risk by putting them on a direct-drive trainer? The stays are designed to support a rear wheel, and I doubt the forces imparted while in the trainer are identical.
(I also have an inexpensive aluminum frame bike that isn't being used right now, so it might make more sense to use that, but it is kind of like people who won't use their fine dinner plates when they eat for fear of breaking them.)
Liked 3,434 Times
I think many people want variable resistance "smart" trainers that play with Zwift, etc. Are there rollers that do that?
Liked 3,434 Times
Barry
Barry
But then I saw where you live ...
Grupetto Bob
Liked 5,639 Times
I tried that in 1992. It lasted about a week until I gave them away. My attention wandered, and the next thing I knew, I was smacking into the closet doors.
Quoted: 9653 Post(s)
Liked 6,365 Times
Barry
Barry
have the settings written down so my wife and I can both use it. Even have different saddles and posts (his and hers) that can be easily swapped.
Liked 3,434 Times
Yes Dorthy, wishes can come true: https://www.wahoofitness.com/devices...rs/kickr-rollr
Grupetto Bob
Liked 5,639 Times
Grupetto Bob
Liked 5,639 Times
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I'm going to be riding @ 72F !!!!!
Year-round my tush.
Barry
Bikes: Way too many
Quoted: 900 Post(s)
Liked 606 Times
If you're worried about it, just keep a close eye on the tread/wear and replace it earlier than you otherwise would.
Likes For Herzlos:
Liked 3,434 Times
Thankfully, I live near the shoreline, so it is only 109°F here. Even with air conditioning, the only thing I am doing with the bike is changing the bar tape.
climber has-been
Quoted: 3431 Post(s)
Liked 3,566 Times
On the cooler side of the Bay, my ride today got up to just 108F.
All things considered, it wasn't that bad. As long as I kept moving.
Cooling down at Starbucks
Likes For terrymorse:
