Noise is Driving Me #&8^!@
Old 03-01-22, 05:44 PM
Paul Barnard
For The Fun of It
Paul Barnard's Avatar
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times in 829 Posts
I am generally pretty good at figuring noises out. I have one now that has me stumped. Ting, ting, ting with each rotation of the wheel. Increases in frequency with increase in speed. Continues when I stop pedaling. When I dismount and spin both wheels, no noise. When I ride, if I lean my bike to the left it stops. Straight upright and a right lean, and the noise is there. I checked all of the spokes, and they are all tight. I removed the wheels and spun the bearings by hand. Buttery smooth. It's a metallic ting that sounds like a spoke. I looked to make sure the spokes weren't bumping the calipers or any cable ends. No obvious interference.
GAAAHHHH!
Paul Barnard is offline
Old 03-01-22, 05:50 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
You would happen to have a magnetic sensor bike computer?
John
70sSanO is offline
Old 03-01-22, 05:51 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
Brake rotor? Seat post?
The later is easy to troubleshoot, stand up while pedaling and listen.
katsup is offline
Old 03-01-22, 06:00 PM
CAT7RDR
Quoted: 822 Post(s)
Liked 1,960 Times in 943 Posts
Micro-fracture of an aluminum rim?
My spokes were fine but I had a fine fracture coming out of one of my nipples.
Made the same tingy noise you described.
CAT7RDR is online now
BlazingPedals
BlazingPedals's Avatar
Quoted: 1514 Post(s)
Liked 734 Times in 455 Posts
I had that once. I turned all the spokes 1/8 turn tighter and the noise went away.
BlazingPedals is offline
Old 03-01-22, 06:04 PM
jamesdak
Quoted: 2323 Post(s)
Liked 4,988 Times in 1,776 Posts
Valve stem pinging against the rim?
Steel is real...and comfy.
jamesdak is offline
Old 03-01-22, 06:54 PM
Paul Barnard
For The Fun of It
John
Nope.
Old 03-01-22, 06:55 PM
Paul Barnard
For The Fun of It
Nothing obvious with the rotor or calipers. Everything is tight and clearances are good. Definitely not the seat post.
Old 03-01-22, 06:57 PM
Paul Barnard
For The Fun of It
I didn't look the rims over closely. I'll get it out in the sunlight tomorrow and inspect them.
Old 03-01-22, 06:58 PM
Paul Barnard
For The Fun of It
That's something else to check out tomorrow.
Old 03-01-22, 06:59 PM
Troul
Troul's Avatar
Liked 2,971 Times in 1,918 Posts
Shoe lace strap striking something
-Oh Hey!
Troul is offline
Likes For Troul:
Paul Barnard
For The Fun of It
I do have a few spokes that are not as tight as the rest. Not loose mind you.
Old 03-01-22, 07:08 PM
CliffordK
CliffordK's Avatar
Quoted: 18376 Post(s)
Liked 4,511 Times in 3,353 Posts
When was the last time you built/trued the wheel?
Do you unwind your spokes after tightening? It becomes very obvious if you use bladed spokes, but I've heard of people marking the outside of all the spokes with a sharpie before working on the wheel.
CliffordK is offline
Old 03-01-22, 08:08 PM
digger
digger's Avatar
Quoted: 1295 Post(s)
Liked 157 Times in 132 Posts
Ouch!!!
digger is offline
Old 03-01-22, 08:14 PM
CAT7RDR
Quoted: 822 Post(s)
My wheels and I are one and the same.
Originally Posted by digger
Ouch!!!
Old 03-01-22, 08:21 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
Try to see if the noise occurs when the seam is at the bottom of the wheel's revolution. Some Mavic rims were known for that; they wouldn't make a sound in the truing stand or workstand, only when ridden. I can't remember if they were pinned or welded.
Rolla is offline
Likes For Rolla:
Old 03-01-22, 08:55 PM
rosefarts
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times in 490 Posts
I had that on tied and soldered spokes. Drove me nuts.
I removed the wire and solder and retensioned the wheels. Never another peep.
rosefarts is offline
Old 03-02-22, 10:44 AM
Erzulis Boat
Le Crocodile
Erzulis Boat's Avatar
Quoted: 370 Post(s)
Liked 787 Times in 311 Posts
I have had the "same" issue (sound wise) and it was due to the spoke nipples fretting in the rim eyelets. I just put a tiny drop of oil at each nipple/eyelet union, and it went a way. Sometimes that characteristic sound under load can be due to where the spokes cross (if applicable) and a re-tension was in order.
Because you are describing a "ting" vs. a "click", I would say that the spokes are a very likely culprit.
Erzulis Boat is offline
Likes For Erzulis Boat:
Old 03-02-22, 12:27 PM
rydabent
Quoted: 3352 Post(s)
Liked 1,056 Times in 635 Posts
Could be a crack in the frame, it happened to me.
rydabent is offline
Old 03-02-22, 01:45 PM
livedarklions
Tragically Ignorant
livedarklions's Avatar
Quoted: 8186 Post(s)
Liked 9,098 Times in 5,054 Posts
Mites.
livedarklions is offline
Old 03-02-22, 01:49 PM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
If you haven't had your wheels checked by a good wheel person, then do so. Usually doesn't cost very much at all as long as nothing needs replacing. I just take them the wheels leaving the bike at home. Spokes can sometimes make noises from where they cross each other or at the flange or rim. Getting them all tensioned correctly might help. Oil, soap or paraffin around those area might help too for a while.
Have you checked the bolts on your chain rings? I had some get loose. I wouldn't describe it as a ting, but more a click that developed to a creak before I found them as the issue.
Iride01 is offline
Likes For Iride01:
Old 03-02-22, 02:10 PM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 998 Post(s)
Liked 1,206 Times in 692 Posts
This. A "ting" with every revolution of the wheel could possibly be a spoke loading and unloading or rubbing a neighbor spoke. Could be too high of tension, too low of tension, or even just rubbing like Iride01 mentioned.
It's like riding a bicycle
urbanknight is offline
Likes For urbanknight:
Old 03-02-22, 02:44 PM
Trakhak
Trakhak's Avatar
Quoted: 2482 Post(s)
Liked 2,955 Times in 1,678 Posts
If the noise has shown up coincidentally with your riding on the first few truly warm and humid days this year in your area, I'd look for aluminum-on-aluminum "twinning," a term I learned from a materials engineer, if only to eliminate that possibility. Creaking comes and goes when it turns warm and humid around here with my aluminum handlebars and aluminum stems on various of my bikes.
Trakhak is offline
Old 03-02-22, 04:21 PM
hayden52
Quoted: 23 Post(s)
Liked 41 Times in 22 Posts
They don't have to be loose when unloaded, but they may get loose when loaded and make a noise as they load/unload. I would tighten all the spokes.
hayden52 is offline
Likes For hayden52:
Old 03-02-22, 07:45 PM
Paul Barnard
For The Fun of It
These are essentially new wheels. They have about 400 miles on them. I bought them from Velomine.
