Pulse Ox
Pulse Ox
Anybody track their day and night time pulse ox with a smart watch?
Over the last year or so, and prior to the last few weeks (another covid infection), I was in decent cycling shape for my age (53), with my estimated VO2 max sitting between 58-62 depending on training phase, with my FTP just over 4w/kg. I started wearing a Garmin watch partly to see what my pulse ox was doing as finger oximeter measurements were consistently showing me sitting between 93-96% during the day. I started getting interested in this measurement over the last few years, as I've been waking up with headaches now and then. I'm quite slim, don't have a big snoring issue, and no apnea noticed by my spouse. The watch agrees with finger measurements, and shows that during the wee hours of the morning, around 4am, I'm slipping into the upper 80's most nights. I've been having a lot of waking around that time, which might turn out to be triggered by this o2 dip.
No idea what the origin of the issue is as I don't have obvious lung disease, and my performance number are quite good, although it seemed to get worse after I had the scalene muscles and the top rib removed on one side around 4 years ago due to strongly symptomatic thoracic outlet syndrome. I found out after the surgery that the scalene muscles have a minor but important role in breathing, especially for those that COPD. I do also have LBBB resulting from myocarditis a dozen years ago, but I'm not (yet) in heart failure from it - the LBBB definitely did cut ~20% of my top-end performance though, so no more racing for me.
Curious if anyone else is tracking their pulse ox and what they see.
Early in the pandemic I checked mine with the finger checker just as a way to screen for covid. I figured if I saw a drop I'd do a covid test if I could get one (they were scarce at that point).
I have auto logging of pulse ox turned off on my watch since it is apparently a battery hog. At least that is what I have read.
Likes For staehpj1:
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Liked 1,273 Times
81 y/o. Oxgen stays 96 most of the time.
Does Not drop at Night.
I use a Finger meter.
Passed Life: Pnemonia Twice and TB 15 Months.
Fred "The Real Fred"
I have Dendriform pulmonary Ossification which means I have bones in my lungs in a tree-shaped pattern. I rarely have a reading over 90%. This is an orphan disease, maybe a couple hundred people in the world have it diagnosed. No one knows what to do about it, nor seems to actually care, except to document it. I forgo being an object of study as I wanted my life to be as normal as possible. There's not much to do and I just ignore it, I'm doing the best I can. I lost a whole lot of weight on purpose to reduce any incidents of apnea. I've made it to almost 84, look great, and have noticed a reduction in energy these last few years, which is probably normal for someone my age. I do track every now and then my oxygen level.
Likes For gobicycling:
feros ferio
Liked 1,450 Times
Using my fingertip pulse oximeter, I am consistently 99, occasionally 98%, pulse rate between 45 and 60, depending on how long I have been sitting still.
climber has-been
Liked 4,009 Times
Yeah, same for me. I got a meter during the pandemic. Even when I was COVID+, it never went below 98.
Likes For terrymorse:
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Liked 68 Times
If you are going into the 80's and waking, you may still have sleep apnea or hypoventilation.
It might be related to your headaches.
You should speak to your doctor about getting formal overnight oximetry or a polysomnogram, or seeing a sleep specialist (some places PCP's cannot order sleep studies)
Bikes: 1979 Motobecane le Champion 1973 le champion. 2000 specialized s works cx used as road bike
Liked 42 Times
Don't know what elevation you live at but those numbers are somewhat lower as elevation goes up.
Don't know how accurate that watch is.
If you are concerned about it go to a doctor.
Likes For 3Roch:
just another gosling
Liked 2,084 Times
I've used a finger pulse-oximeter, but mostly for personal interest. My understanding is that if one can get that down to 93 by exercising, you get a dump of EPO and thus eventually a higher hematocrit. I've only been able to get mine that low doing jumping jacks at 10,000', but I guess some real athletes can do that on the trainer. Just can't generate enough power for long enough, I guess.
Results matter
Results matter
dot dash
Bikes: Shmikes
Liked 6,121 Times
I saw the same thing the few times I did an overnight recording, which is why I’m not doing that anymore!
It’s presumably subclinical nocturnal hypopnea/apnea.
Likes For MoAlpha:
climber has-been
Liked 4,009 Times
That's my go-to method when I know I'm out of shape: just ride and don't look at the numbers.
