Head position while cycling?
I've read an article about the causes/solutions to neck pain while cycling. I know that more aggressive positions are more likely to cause neck pain, and handlebar height and excessive reach are the two main things to check when you are having neck pain...
I just got a new to me road bike and it has aero bars. I love riding with the aero bars, but I don't really understand how my head should be positioned? So that I can see ahead, although that strains my neck? Or so my neck is comfortable, but I can't see very far ahead? Or maybe alternate between the two? What do you do?
Liked 2,979 Times
going full speed ahead, i look forward. With enough ride time, the neck strain shouldn't be a pain if the bicycle fits you right.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
prior to having aero bars on my ride i used to ride with a base ball hat becasue the bill sheltered my eyes from teh sun. once the bars went on the had had to come off due to the excessive strain on my neck to see enough road ahead of me. if yo have a visor on your helmet you may be adding additional neck strain to compensate.
Likes For spelger:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
How old are you? If you are in your 20s, it is a lot easier to get in an aero position than it might be at age 50 or 60. Also, bike fit is key; you should be balanced fore/aft on the saddle such that you are putting very little pressure on your wrists. This will also remove the tendency to strain your neck, which is a consequence of fighting to maintain balance.
Liked 3,443 Times
Sorry duplicate post
Quoted: 4416 Post(s)
Liked 4,872 Times
Quoted: 2604 Post(s)
Liked 1,933 Times
You might give up a bit of forward vision on a track or a closed course, if you know the road really, really well. Other than those situations, you'd be foolish to ride so you can't see ahead of you.
Then the question devolves into "how can I ride aero bars and see in front of me?" As with so many other things about bicycles, the correct answer is "it depends." Perhaps you can swap out your stem to raise the bars (aero and ordinary) so you can lay your body flat and still lift your head up to see. Perhaps you need to work on your flexibility. Both these posit that if your back is arched, your neck will have to flex more to allow you good vision; conversely, if your back is flat and level, you don't have to bend you neck as far. Or perhaps the best way to proceed is to reduce your girth, so you don't need to round your back over your gut to reach the bars down low.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
For me, an interesting ride in the ambulance reinforced the notion that it's good to look where you are headed. If your vision is obscured, flip up the brim of your cycling cap.
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
If I find my neck is hurting from holding my head up, it's generally because I'm hunching my back, rather than keeping my it mostly straight while rolling my hips forward. I also make sure my sunglasses allow me to look out the tops, so I can see far down the road even without holding my head vertical.
Old guy & bikes
Too much neck bend can lead to pinched nerves in your neck, over time. That can cause not only neck pain, but also hand numbness. Ask me how I know.
What is your use? If you’re not racing, why tuck down so low? If touring or utility riding, get an upright setup.
IMO, this position is another case of racer wannabe. Aim for comfort. Aim for long term health. But if you really want the aero advantage, be aware of the risks.
Likes For canalligators:
Liked 4,872 Times
Likes For PeteHski:
Seeing ahead at least as far as you need to brake to a stop is pretty essential if you don't want to have an accident. So that should be your minimum target, which is also speed dependent. Unfortunately the latter is at odds with a more aero position, but I don't take that risk.
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 358 Post(s)
Liked 122 Times
Glasses
On a side note, if you wear glasses, if your glasses slip down you have to crook your neck up more to see. This causes me some neck strain . There's a post on here about that where a guy modified his glasses with an extension. I bought a well fitted curved pair that seems to help .
Likes For rossiny:
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
I found, incidentally, that a little isometric strength work on the deep neck extensors helped me get a lot lower on the bike.
Quoted: 790 Post(s)
Liked 348 Times
You just got the aero-bars so of course it is going to take time to get used to them, common sense. The more you do something the easier and more natural it becomes. Your neck muscles will strengthen and adapt. Go for a ride and sit up with your hands on the hoods, drop down onto the drops or aero-bars for a bit until it gets uncomfortable then get back up on the hoods. With time you will spend more and more time down comfortably. Once you can stay down for the length of a 20 or 40 kilo TT you are in good shape.
While riding fast on the drops or aero-bars you do not have to have your head looking straight ahead every second. If the road is smooth and straight ahead for many feet or yards then look down at the line on the road for a little bit, turn your head side to side a few different ways to keep it from getting stiff or cramped. I am in my 60s and I ride down on the drops all the time with no problem. Me on my race-bike;
Likes For beng1:
Expired Member
Liked 5,441 Times
Likes For shelbyfv:
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 171 Post(s)
Liked 395 Times
Likes For beng1:
Expired Member
Liked 5,441 Times
Well, you are all on bicycles so you have that in common!
Likes For shelbyfv:
Liked 11,914 Times
No, your position is much shorter, with a lot more overlap of your knees and elbows, because your bike is too small/stem is too short.
Likes For genejockey:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
His hip angle is less. His shoulder angle is less.
These angles are considerably below what is recommended by bike fitters, even for a temporary or time trial position.
Quoted: 790 Post(s)
Liked 348 Times
The TDF riders are not down on the drops like I am, if they were, they would have identical knee-elbow overlap, that is easy to see. Try doing a pushup with your arms outstretched in front of you then with your hands under your shoulders more, which is easier? So the short stem is a benefit. The bike has no problem cruising along at 19-20mph for miles with my old weak body powering it, so that is the proof it is perfect. I am one of the only ones on the forum putting up photos of their aero riding position instead of just talking about riding positions.
