Unsure about cycle brand to choose for 330+ rider
Hi! I have previously used to bike casually for exercise until a wreck totaled it. Some decades later I've gained a little weight, 337 to be exact; I'm also 6' 5". So I've been doing some research on what to get and all I get is some bikes going for 2,300 to 3,000. If that's not all, I see so many recommendations for this Mongoose "Dolomite" style of bike. Been to cycle shops that always tend to recommend a hybrid.
So making the long story short, I get the idea about having enough spokes to keep the wheels' integrity, don't necessarily need shocks on a bike, can do hardtail. Just looking for something that can handle my said weight and up to 350 lbs.
As of this post I was also recommended bikes like Cannondale Quick 5, Giant Escape 2 and Momentum Vida.
In advance, I greatly appreciate any suggestions!
Do you have a particular style of bike you would prefer to be on given you already have some riding experience?
My go to recommendation is a low end 29er MTB. IMO they’re the most versatile bike. Built MTB strong so should have less problems with your weight and their generally narrower MTB rims give you access to a truly wide array of tyres so you can easily and relatively cheaply change the ride characteristics going for road race slicks to MTB knobby tyres and everything in between.
To start with you can get away with the largest offerings from nearly all manufacturers, but if you get keen, a properly fitting bike won’t be cheap. I have lived this story being 6’5” myself.
On another note, I’d be cautious of Cannondale as some of their bikes use proprietary bits that I read of people having issues with when they start looking for alternative parts
Bikes: 2014 Avanti Circa (Rd Dist), 2020 Giant Toughroad (Rd Tour), 2021 Trek Allant+ 8S (eCommute), 2021 Scott Aspect 940 (Mt HT), 2014 Santa Cruz Superlight 29er (Mt FS), 2022 Scott Spark 960 (Mt FS)
Quoted: 35 Post(s)
Liked 52 Times
Consider what Trek has to offer - although their parts are inhouse, they are also generic sizing so you can swap out parts fairly easily, and they also have some good sizing options.
I would however stay away from dropper seatposts - they are probably more hassle for you at this stage.
https://www.trekbikes.com/us/en_US/b...rCode=greydark
My go to recommendation is a low end 29er MTB. IMO they’re the most versatile bike. Built MTB strong so should have less problems with your weight and their generally narrower MTB rims give you access to a truly wide array of tires so you can easily and relatively cheaply change the ride characteristics going for road race slicks to MTB knobby tyres and everything in between.
I'd also go this route as well.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I'd get a good, but older, rigid steel frame MTB. They are plentiful, lots of 26 tire choices. They are also cheap. If the goal is to just get out and ride, then an old school rigid frame MTB will do that just fine. MTB suspensions tend to not be made for someone your size.
And regardless of your budget, its OK to spend less! I've owned a lot of bikes, still own quite a few. My go to bike continues to be my 1988 Schwinn Cimarron.
Yes, you can spend $10,000 or even more on some bikes. But you don't have to. There are even some bike co-ops in Houston that can get you started!
Bikes: Konas: Jake the Snake-Fire Mountain-Zing Supreme, Dew Deluxe,Zone Ltd. (frame, needs parts), Surly Long Haul Trucker, Santana Arriva tandem, Montagues: Paratrooper-Fit, Trek 1200, Bianchi Ocelot, Fantom Cross Uno, Bridgestone 200
Quoted: 108 Post(s)
Liked 227 Times
I'll second the older cro-mo mtb. Also, a good steel touring bike is a good training stand-in for a clyde road bike. My Surly Long Haul Trucker has been great for this purpose. I was somewhere north of 370 when I started riding some (hiked more, until I got closer to 300) and it held up great. The stock wheels, 36h Alex Adventurers, are still true even.
I also built, later, what would be a fabulous Clyde Ryde out of an old Bianchi Ocelot with some 40h/36h Velocity wheels I bought a while back. As I'm a roadie and decided to use it as a Winter trainer, I mounted drop bars and bar end shifters. I like this bike a lot more than I thought I would. A neighbor gave me the original bike in exchange for a couple clean/tuneups, so the cost was mostly parts I had laying around, and the long pull brake levers.
Likes For velojym:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Touring bikes are built to carry a heavy load, so a touring bike, new or used, should be strong enough.
Likes For tyrion:
Likes For JCS1971:
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times
Quoted: 1088 Post(s)
Liked 1,025 Times
OP: the surly isn't a bad recommendation. If you're just looking for fitness I'd be inclined towards the c-dale quick that you mentioned or a trek FX bike, both will be upright and comfortable and probably not ride much differently then the surly touring bike. Similarly relaxed geometry, longer stays, wider tires. The surly will have drop bars which I prefer for variety of hand positions but a basic set of bar ends will offer another grip on the hybrids. The surly will have a wheel advantage, that said I had a friend who's heavier ride his marlin hybrid for 4 years before the wheels became a problem and he put in plenty of miles every year. I built him a new set of wheels which can be a later, good investment on any bike, and he's been trouble free for the last 8 years now. Make sure any bike you buy has an 8, 9, 10sp cassette wheel. If its 7sp it'll be a different hub design that's old and weak and should have been abandoned over 20 years ago.
Regarding the dolomite, there's a desire to have heavier riders on fat bikes like the lighter bikes can't hold up. This is nonsense, worse, fat bikes are typically outside your price range unless its something like a mongoose dolomite and they won't be good for your weight. The rims are stronger but the cheaper versions are 7sp freewheel and those are weak.
Likes For Russ Roth:
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Whatever it is you get, get something with a freehub.
A freewheel tends to be found on cheaper offerings. You don't want it. A freewheel is just a poor design, even for people 1/3rd your weight. what good is 32 or 36 beautiful spokes if the axle bends or breaks constantly?
A freehub is worth the cost in avoided heartache alone.
While you're shopping, you might want to avoid single piston mechanical disc brakes. They fit awkwardly in the low/mid price point & may seem like a feature, but they're really there to put lipstick on a pig. Weak & not worth the hassle.
If you can't afford or find full-on hydraulic disc (best), you might find dual piston mechanical adequate/available depending on what bike you are looking at. For the money difference, hydro may be better.
They are out of fashion, but honestly at your budget, rim brakes brakes will still be a better bang for your buck than single piston disc & stop a million times better.
TL;DR: A wheel with a freehub & rim brakes is a good solid combo to save a few dollars
Suburban Dad
Bikes: 2019 Trek Domane SL5 Disc, 2021 Giant Talon 2, 2012 Trek 7.1 FX, 2005 Trek Fuel 70, 2003 Trek 4500
Quoted: 17 Post(s)
Liked 33 Times
A few years ago I started riding again at 330 lbs. I bought a Trek FX and lost 70 lbs riding (and dieting). I did pop a couple of spokes until I got under 300 but otherwise the bike held up fine. I still have it today.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I would highly recommended Cannondale. they have frames that are or were higher rated then most big brands. Their CX bikes are good to 360 or used to be.
Quoted: 581 Post(s)
Liked 921 Times
There a re a few things to look out for as a heavier cyclist, but these are really long-term durability of parts like wheels and bearings and seatposts, and all these can be dealt with if/when they become problems. Really, just about any bike that fits will be acceptable, aside from some of the most superlight road racing bikes, and if you are prepared to make a couple modifications or repairs as moving parts not built for bigger cyclists begin to wear out.
At 6'5" your limiting factor will be that you need a very large bike frame that might not be available in all models or styles. Seriously, many brands sell what they call an 'XL' size that will likely be too small for you, and many brands only make sizes up to what they call 'Large', which is a sure sign it's not gonna work. If you get a bike that is too small it will not be properly comfortable and you are likely to get discouraged from riding. This is my experience as a lifetime cyclist who has at times been up close to/slightly over 300# and is also 6'5". Some modifications can be made, like stem risers and extra-long seatposts, but these are usually just bandaids to cover the root cause, which is a bike that doesn't fit.
Generally speaking, a 'flat bar' bike (mountain bike or hybrid) needs to have at least a 22" seat tube for a strapping lad such as yourself, preferably 23"-24". A 'drop bar' (road, cyclocross, gravel) frame with traditional road geometry needs to be at least 62cm, while modern sloping top tube bike might fit even if they call the frame size 58cm or 60 cm.... most companies have gone to S/M/L/XL sizing because it's not really possible to compare two bikes just because they both claim to have a 60cm frame size.
As for price, yeah, $2k is IMO a reasonable starting point for a bike that can actually last a few seasons of regular use. Cheaper bikes are available, but expect to need to start replacing moving and load-bearing parts soon after purchase. IF money is tight, there are lots of 2nd hand bikes around, but 2nd hand bikes aren't available in multiple sizes for you to try, so you have to know what you are looking for. Buying 2nd hand is also a good way to save some $$$$ so you can easily upgrade bits like the rear wheel to a sturdier model.
Likes For ClydeClydeson:
Quoted: 581 Post(s)
Liked 921 Times
Just looked on Houston CL and found an ad for a 'Soma Smoothie ES' in XL size. It's a drop-bar road bike, so maybe not what you ar elooking for, but the asking price is $475. That could be a good thing to check out.
There is also a trek 1200 road bike in 64cm on Cl
There is also an older Fuji road bike with a very large frame. THe rear wheel might need to be upgraded before you do any major mileage on that one, but Fujis are great bikes.
I didn't see any mountain bikes or hybrids with XL frames, but I only took a quick look. Check out Zuckerbergs Marketplace as that typically also has lots of activity.
NB, the first ad at the top of the 'bikes' category on CL was definitely an XL, and some folks would enjoy riding it, but it was NSFW and not bicycle related! You've been warned.
Liked 2,011 Times
If you want to stick to a tight budget this is available in 64cm:
https://www.bikesdirect.com/products/...ng-bikes-v.htm
At $600 that leaves money for a new stem, handlebars, saddle, etc to dial in the fit.
Likes For tyrion:
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
One nice thing about that is you'd be able to spec out a good-quality, high-strength wheel set, and you might be able to use a number of other spare parts that you've got (or that can be found pre-owned at a nearby bike co-op or shop). It'd likely be more cost-effective to do it that way, in order to ensure it's strong enough both with the frame+fork as well as the wheel set. Otherwise, with most any off-the-shelf sub-$1K bike you're likely to find it's going to come with wheels that'll be highly strained at that load. You could have them rebuilt, or wait until they begin popping spokes (which I'd think is fairly likely). But going DIY starting with a good frame is one way around that.
Something like, for example, the Surly Bridge Club. Supports brakes with big rotors. Supports wheels in 26", 27.5" and 700c/29'er sizes. You could have the shop build it up with basic components and then install your own wheel set. Or you could piece it together as you pick up individual parts (or those taken from other bikes you've had or acquire as "parts" bikes). All told, it won't be a sub-$1K bike. But Surly's basic "built" price for the Bridge Club is $1200. But it's all but guaranteed to be stronger than most anything else you're likely to find at anything near that price.
JMO.
Suburban Dad
Quoted: 17 Post(s)
Liked 33 Times
JCS1971 I'm in Kingwood, TX (Northeast Houston). HMU if you want to get together for a ride.
Likes For Grudey1:
Just came from a local bike shop not too far from where I work. Looks like they have a Quick CX 4. Plan on going back on the weekend to see if they have it, but right now I'm leaning towards Surly Crosscheck.
Likes For JCS1971:
Another route might be: acquire a decently strong frame+fork, then build up your own bike.
JMO.
JMO.
Super Moderator
Bikes: Surly Crosscheck
Quoted: 1542 Post(s)
Liked 868 Times
The Surly comes up quite a bit. So, I visited a bike shop not far from my job and was shown two bikes. One was a Surly Crosscheck and the other was Salsa Rangefinder. I'm leaning towards Surly after a test spin on it. Would love to know more about Salsa though, never heard of them.
Good Night Chesty, Wherever You Are
Liked 2,011 Times
Salsa Rangefinder is a plus-size-tired mountain bike. It can handle rougher terrain than a Crosscheck, but it will be less efficient on pavement.
