I couldn’t resist this Cilo
But, I probably should’ve. I keep telling myself it will be a decent rider. Not sure yet where I’m going with it but I got a good package deal with 2 sets of Campy wheels and spare parts.
Semper fi
Semper fi
Likes For sloar:
Quoted: 3242 Post(s)
Liked 2,514 Times
Nice score!
Could someone illustrate the correct pronunciation of Cilo? Thanks.
Quoted: 4722 Post(s)
Liked 3,039 Times
SEE-low. At least that's how it was pronounced by the distributor, Rick Carter of Security Bicycle Associates.. Prior to that, I had always pronounced it CHEE-low, in the Italian fashion. It's a hard habit to break and unless I think about it, I revert to the incorrect version.
Liked 2,514 Times
Quoted: 3815 Post(s)
Liked 3,348 Times
an earlier discussion thread on this piece resides here -
https://www.bikeforums.net/classic-v...-question.html
Waiting on a Valentino rear derailleur and some Panaracer Pasela tires I thought I’d mess around with a different build. I kinda like the setup.
Semper fi
Semper fi
Likes For sloar:
Liked 3,348 Times
as you work with it you might wish to keep an eye out for a tubing hallmark
possible it might be something like three-tube 531 plain gauge - the Cilo parallel to the Raleigh Super Course of the same era
a saddle pillar size of 26.2mm would be indicative of this
one thing found striking is how shallow the seat tube be as compared with the head...
let us know if shell be metric or CH
is there a serial marked on the upper surface of the NDS?
HS may be an EDCO product, their manufacture of cycle fittings goes back to about the first decade of the last century
pedals appear to be Lyotard model 460A
lug pattern looks to be BOCAMA 31/I
seat lug BOCAMA pattern H/I
fork crown VAGNER PL
pump peg NERVEX Ref. 845
when you repack HS it shall afford an opportunity to examine steerer for marking(s)
when you repack BB you will be able to see the interiors of four tubes to check for seams
best wishes with the project.
