Cleaning chains
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
Cleaning chains
Not another chain/wax thread (but i'm sure it will turn into that)...
In another thread it was mentioned about having to dispose of nasty chemicals used for chain cleaning. i've been hot waxing for about three years now. here are my nasty chemicals, two peanut butter jars each with mineral spirits. i have never needed to dispose yet. chain first goes into the nasty one, then into the clear one. these have been settling for about a week now since the last waxing. the right jar never really clears up anymore but still chains are pulled out quite clean.
maybe i have not been doing this for very long but so far i don't see the problem with nasty chemicals...yet.
Likes For spelger:
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Paper coffee filters are your friend. Dirty ones gone in the fire pit.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
Quoted: 696 Post(s)
Liked 910 Times
What’s with the measuring tape?
Quoted: 7652 Post(s)
Liked 3,478 Times
You probably have recycling stations for toxic materials in your area, or amnesty days .... and some gas stations will take used motor oil, so dump that stuff in.
Pennylane Splitter
Bikes: Yes
Quoted: 1804 Post(s)
Liked 1,442 Times
DO NOT mix mineral spirits or other waste solvents, cleaners, paint products with your used motor oil. It'll contaminate the oil and render it useless for recycling purposes, plus drastically increase the cost of disposal of the contaminated oil. Keep them separate and find a proper household hazwaste disposal location near you.
Likes For skidder:
Quoted: 3513 Post(s)
Liked 2,926 Times
Likes For smd4:
Quoted: 2976 Post(s)
Liked 1,182 Times
No nasty chemicals for me and I'm too lazy to remove the chain from the bike to clean it.
I just clean the chain on the bike with shop towels and a tooth brush and a spray bottle of Extreme Green parts cleaner. Over spray gets caught by the towel and I use the towel and toothbrush to clean the chain. In case there is any dripping I place a piece of cardboard under the bike that eventually will make it's way to the fire pit.
Non toxic...
https://www.fleetfarm.com/detail/ext...xtreme%20green
https://www.fleetfarm.com/detail/ext.../0000000218146
Non toxic...
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Likes For Polaris OBark:
Bikes: Grazzini,Litespeed,and Pinarello
Quoted: 33 Post(s)
Liked 92 Times
What are amnesty days?
Our area has toxic waste days about 4 times a year. They handle paint thinner and mineral spirits with no problem.
Liked 1,182 Times
disposal is the point of this post. sure the right hand jar (first bath) is dirty but after about 3 years it is still doing its job. when it stops doing that i'll dispose of properly. i'm doing only one chain about once every 4 weeks - roughly every 600 miles.
Liked 1,182 Times
Quoted: 6196 Post(s)
Liked 4,810 Times
Maybe your chains get gunkier than mine. I find that just wiping the chains off with a shop rag keeps them clean enough for me. My issue with soaking them in mineral spirits is that you are cleaning out all the lube from places that likely is not very contaminated and possibly moving grit into their place. As well when you do let the chain dry out you will have to hope that the lube gets down into all those places that it was removed from before any damage to the wear surfaces can be done after you use the chain again. Or if you lube the chain while the wear surfaces are still wet with mineral spirits then perhaps the mineral spirits will not be displaced by the lube.
You can leave the container of used mineral spirits open so it can evaporate and leave you with just the solids and other stuff that won't evaporate. However I don't know if that is completely hunky dory by the EPA. And of course whatever is left is probably more a hazardous waste issue but maybe below the amounts that EPA and others are concerned with for disposal.
So if concerns for the environment are primary for you then just wiping off the chain would seem more reasonable. Is the mineral spirits really about extending the life of your chain, which I doubt it does. Or is it more about easily making it cosmetically pretty?
Likes For Iride01:
Liked 1,182 Times
Ever since I started using this I no longer have gunky or gritty chains, cassettes, chain rings or pulley wheels. Chain cleaning takes me about 10 minutes tops nowadays.
https://www.amazon.com/DuPont-Teflon.../dp/B00KMMFE8Y
Liked 1,182 Times
Liked 4,810 Times
Not sure what the thread topic is that you wish to keep the thread on. However for me, when I was using mineral spirits to clean parts regularly, not bicycle parts, the mineral spirits would get pretty clean and all the solids fall to the bottom. There might be a discoloration of the mineral spirits, but as long as it is cleaning off what needs to be cleaned, I never felt a need to replace it.
But still the most environmentally friendly thing would be not to clean your chain at all. Second to that, just wipe it off.
Mineral spirits are simple hydrocarbons with a chain length of C7 to C12 .
Chemistry 101: Methane, a gas, is one carbon atom surrounded by 4 hydrogen atoms. When you connect 4 carbon atoms in a chain, they become butane, a liquid. At chain lengths above about 12, you get a solid, or basically paraffin. So mineral spirits are a liquid hydrocarbon mix somewhere in the middle.
Mineral spirits evaporate (slowly), where they are exposed to UV light, cosmic rays and the 21% oxygen content of our atmosphere. Like all organic molecules, they do break down (oxidize) into water and carbon dioxide.
This is why mineral spirits are about the most enviro option for degreasing and cleaning. The solvent can be used multiple times, and the bad stuff filtered out and discarded. Ultimately, the solvent evaporates and is broken down in the air.
Contrast this to water-based cleaning products, including anything: 'green'. Being water-based, they are ineffective at actually degreasing. Chemistry 201: polar molecules (water) only minimally mix with non-polar (grease and oil) molecules. So with the water-based products, you have to use far greater volumes, and far more mechanical scrubbing to get the same effect as with a hydrocarbon-based degreaser. And where does the mix of oil/grease and water go? Down the drain of course, where it causes far more enviro harm than with mineral spirits.
Likes For Dave Mayer:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Where does a soap molecule fall in this oil mixing capability? As far as I understand it, one end of a soap molecule is polar, the other end is non-polar.
Resident PIA
Quoted: 212 Post(s)
Liked 356 Times
mineral spirits is not what i'd call "extremely hazardous." but i'll let cyccommute chime in, i think he is the forum's chemical expert on this.
Sorry.
Shad
67'er
Shad
67'er
However,, when degreasing with soap/water, you are left with a mix of water and hydrocarbons which goes where? Water evaporates at a far slower rate than mineral spirits, so you are left with a large volume of liquid mess that just begs you to be flushed into the sewer system.
Second, the 'green' degreasers are not as much soap based, but depend on strong acids for degreasing. You do not leave metal parts in these for any length of time. In contrast, you can leave metal bike bits in a hydrocarbon-based bath such as mineral spirits. I have: chains a derailleur bits left forgotten for months with no apparent effect.
Liked 1,182 Times
For some materials it is a perfectly acceptable method and EPA approved. I don't know specifically for mineral spirits and likely it may involve what the total quantity of mineral spirits is that is being allowed to evaporate. A question better left to those that deal with EPA policy and hazardous material disposal.
Pennylane Splitter
Bikes: Yes
Liked 1,442 Times
Pennylane Splitter
Bikes: Yes
Liked 1,442 Times
Very good... soaps are molecules in which one end is polar, and the other non-polar. The non-polar end attaches to the oil or grease, and aggregates into little bubbles of hydrocarbons dispersed in the water. I haven't checked the solubility charts of oils mixed in water with detergents/soaps, but I can tell you from hands-on experience that mineral spirits is far more quick at degreasing than any any water/soap/detergent mix I've ever used.
Liked 4,810 Times
I know that solvents are used for cleaning chains. I know that you are using mineral spirits, a well known solvent frequently used to clean bicycle chains. Just because it is, doesn't mean you have to use it. I use nothing at all, except maybe the excess lube that I'm wiping off of my chains after applying it.
That way your thread won't be filled with posts and arguments that have nothing to do with what ever it is you wish to know or state!
Liked 3,443 Times
The so-called "odorless" or CA-compliant mineral spirits have mostly non-volotile components, so they don't evaporate readily. They are basically small-chained hydrocarbons -- essentially low melting-point wax.
