Anyone on 30mm road tires? How do you like them?
Quoted: 1278 Post(s)
Liked 1,392 Times
i just switched from 30mm GP5K TR S to 28mm. feels faster, but isn’t really. the difference is modest but very noticeable, next time around i’ll probably go with whatever is more readily in stock, and if both, the 30s.
Quoted: 1397 Post(s)
Liked 1,878 Times
I have been running 30mm for several years now .. first some Specialized S-Works Turbo and now GP5000 S TR. Its not worth going up 2mm if your old tires are not worn out, but when my old 28s wore out a few years ago I got 30s and definitely appreciated the touch of extra comfort and grip.
When the Turbos wore out I thought about getting 32s but decided to just stick with 30s.
Note that todays 30 is the same as a 28 from several years ago - tire companies shifted their sizing since the average rim got wider which fattened how tires sit. If you are on fresh 28s those are like 25s from the past. Another reason to bump up the size a bit perhaps.
Liked 1,878 Times
unless you get carried away and reduce pressure too much
but of course there is a weight increase as you go up in size
( see chart above and link below )
https://www.bicyclerollingresistance...000-comparison
Likes For t2p:
Liked 1,878 Times
they are relatively light, roll well, and have a little more puncture resistance than a GP5K ... good compromise tire
don't roll as well as a GP5K - but then again not many tires do
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 464 Post(s)
Liked 547 Times
We have GP5K tubeless running right at 90 PSI on the tandem. They work just fine. Noticeably faster than the Schwalbe Marathons they replaced, but that is to be expected. The first set went over 2,000 miles with zero issues or flats. They are ready to go again when the snow is gone next spring.
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
I generally will ride the widest tires my frame can take without causing issues. If I could fit 30s on my 28c frames I would do that in a heart beat or even go to 32. I think maybe my mountain bikes I am not absolutely maxing it because I want room for mud and debris. Wide tires and lower pressures is the way of the future.
Quoted: 10236 Post(s)
Liked 5,184 Times
All of my bikes have GP5000. My race bike has 32mm. They have lasted about 6,000 miles and still going. I weight 163 wet and run them at about 80 psi. I don’t see myself switching tires anytime soon.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
the 30mm prob rolls faster than the 28mm - and a 32 might roll faster than both
Don't want to start (another) tire width debate, but tests done in labs are only good in labs. Real world usage is another thing, and there are several other factors to consider than RR.
I ride Continental GP 4000 Four Season 32mm. Love these tires. No flats in three years. Nice, comfortable ride.
Quoted: 4408 Post(s)
Liked 4,861 Times
Yeah, in the real world the benefits of wider tyres are even more noticeable i.e. ride comfort, grip, faster rolling over rough ground etc. Potential downsides are aero (although some modern rims are optimised around wider tyres) and weight. I find the benefits of 30 or 32 mm tyres massively outweigh any disadvantages for any road conditions I experience. I think my chances of going back to traditional narrow tyres are zero at this point.
Quoted: 989 Post(s)
Liked 586 Times
I'd rather feel fast and comfy and actually go slower, than to feel slow and uncomfortable and go faster.
Quoted: 2975 Post(s)
Liked 1,182 Times
I went from 28mm Continental GP5000s to 32mm Continental GP5000s. Night and day difference in comfort and I can go faster over the rougher sections of pavement with the 32mm tires. Would never go back to 28 again.
Liked 4,861 Times
I must agree with you, sir! I find that 28mm is the perfect balance, especially that I ride on tarmac that's in very good condition most of the time, but I may very well try 30 next year. They're cheaper as well for some reason (less popular than 28mm I guess).
Liked 1,392 Times
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 285 Post(s)
Liked 267 Times
I went from Conti 5000 tubed 25 on one bike to Vittoria Corso 30 tubeless on another bike, and I'm in love. I love the 30. I know I'm comparing apples and oranges because of the two different bikes, tubed vs tubeless, but that's my limited experience.
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
the issue i have with BRR (which i love reading!) is that the differences are so tiny in this kind of tire (a few watts max) that they’re totally swamped by aerodynamics, which is not discussed. i know that i only see consistent/measurable differences in speeds on segments which have pretty high averages, meaning some descending. the 28mm tires i’m on now come closer to the ideal profile with my current rims, and i definitely am braking more on descents that i do multiple times a week. wouldn’t be surprised if there was another 2mph at 35+. but it’s not really useful, since i’m braking it off, and at the more typical 15-20 average i see no difference at all other than a rougher ride.
My Lynskey has a GP4000 25mm on the back (fills out to about 28mm), and the OEM 28mm UltraSport 2 on the front (fills out to just under 32mm).
The UltraSport 2 looks massively chunky compared to the GP4000. It seems comfy, and it does seem to have reassuring bite on curves and under braking.
That said, once the UltraSports wear out (I have two), I'll probably replace them with something smaller, or at least lighter. I've noticed that I'm fairly sensitive to how a bike feels under acceleration, and heavier wheels and tires just make a bike 'feel' slower and less fun to me. Might be some time though - nearly 3500 mi on that front tire, and I can still clearly see the wear dimple...
Liked 1,392 Times
Of course looking at that chart, you should also likely be comparing the 23s at 100 or so PSI to 32s at about 60psi. In addition from aero perspective, the assumption is generally all-else-being equal. Ie. a bike that's built to take 32mm+ tires, conceivably isn't going to be as aero as a bike built that could only take max 25mm tires. Nor could said bike likely be built to the same weight as a bike that hasn't been built to take only narrower tires. IOW, there's a number of factors.
Quoted: 896 Post(s)
Liked 2,064 Times
I've run 35mm and 32mm GK Slicks, and now 32mm GP5k, on my rando bike. Prior to that bike build, I'd never run wider than 28mm on a road bike.
I'm not too lazy to ride a 1200km brevet, but I'm too lazy to try analyzing data to determine any speed difference.
If GP5k came in 35mm, I'd run those. In 40k of rando miles, I've often wished for wider tires; not once have i wished for narrower tires.
30mm gp5000 clincher on a Spec SL4. Would have preferred 32's but they might be a little too wide. The 30s ride great and similar to the 28 Corsa they replaced.
I have GP 5000 TL on my TCR and absolutely love the 30mm. Its the perfect middle ground IMHO for comfort and speed.
Quoted: 581 Post(s)
Liked 921 Times
I ride 32s - currently a Conti F and Maxxis R. I could go a bit smaller for most of my riding, but there is a stone dust rail-trail near my house that I feel a bit better on wider tires for the occasions I ride there.
If you have no specific rough terrain or loose surfaces you struggle to ride with 28s, I would keep them on until they wear out, THEN consider getting slightly wider tires. As someone said above, it's not worth the effort or expense to go up 2mm, but tires are a wear item and will need replacement sooner or later, so for sure try a wider set then.
