GP5000 28mm pressures you run?
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Been experimenting with pressures on GP5000 28mm tubed tires on Mavic Open Pro rims. Been settling on 80psi rear/ 65 psi front. I weight 150lbs and the bike with gear is about 24lbs. I ride dry tarmac exclusively.
bike is a specialized roubaix
If you run 28mm GP5000 tires, what pressures are you running?
should be more popular
My system weight is comparable to yours and I ride TPU tubes.
Tyres measure 1-2mm wider than advertised on my rims.
28mm (I think it measures 29.5) GP5K rear at 75-80 PSI.
25mm (I think it measures 27) GP5K on the front at 80-85PSI.
I usually pump the tyres above these PSI and then let air out with a small gauge to get my target PSI. I mostly ride at the lower end of these two options but I routinely add 5 based on the type of route/surface/competitiveness/mood of the ride. Below these ranges generally feels too soft, above feels too harsh. Road/path surfaces are varied, there are all sorts of surface treatments and materials on my daily route alone, but I never really encounter really poor surfaces aside from some more remote climbs. Never had a pinch flat with these pressures.
Quoted: 10237 Post(s)
Liked 5,184 Times
I weigh 160 and run them at 80.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Pressure depends upon many factors. This is a good web-site to determine starting pressure:
https://cycling-sport.com/en/resourc...ure-calculator
Modify up or down based upon your feel.
Likes For vespasianus:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Sounds good to me OP. I'm 160ish and inflate to 80rear, 70 front w/ 28mm tires.
Likes For cxwrench:
Quoted: 345 Post(s)
Liked 237 Times
most calculators are suggesting 70 psi rear for me which seems low. I'll give it a try though
I've found the pressure calculator at zipp.com to be accurate. Be sure that your pump gauge is accurate. Mine was off by 8
psi.
psi.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Likes For mstateglfr:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I weigh 205 to 210 pounds and run 80 psi rear 28mm and 75 psi front 25 mm tube tires. On a 2021 Domane.
Bikes: lots
Liked 2,932 Times
Quoted: 406 Post(s)
Liked 389 Times
Not sure exactly what tire you are running but many continental tires have a max pressure of 120 psi (or less). Might want to move to a wider tire.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Depends on internal wheel width/volume also.
HED for example on their 25mm external wheels say you don't need that much. I can only imagine a wider one even lower.
Your weight you don't need 80psi in even a 25mm tire. Much less a 28. If I were you I'd probably go rear at 70 and front at 65. If the tarmac is really nice maybe go 75/70. But you definitely don't need 80 psi in those things.
Quoted: 2333 Post(s)
Liked 2,097 Times
At 210 bike and me, I ran 65F and 70R on 28 mm with tubes. On the 25 mm GP5K and at 240 lbs, I still only run 78/82 psi tubeless. With Tubes, I ran 89 psi front and rear 25 mm albeit a different bike.
If I were you, I would experiment with much lower pressure in the rear and a little lower in the front.
Klaatu..Verata..Necktie?
Quoted: 10430 Post(s)
Liked 11,906 Times
With 17mm internal width rims, I run 28mm GP5Ks at 80F/85R. I weigh 200.
Liked 11,906 Times
This is correct. 25mm GP5Ks have a 120 PSI max rating.
Quoted: 345 Post(s)
Liked 237 Times
Tried 70/60 rear/front
While comfy, it felt too squishy and sluggish to me
going back to 80/65 psi rear/front. Seems to be my sweet spot
Pedalin' Erry Day
I have the 25mm version on Open Pro rims and run 70/75 psi, and that seems just about right for 175lbs of rider + bike.
Likes For Fendertele:
