degree of incline
#51
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Well, power tells you how much power you were putting out. How “hard” it was to generate that power seems grade dependent. 4 W/kg at 6% feels a lot easier than 4 W/kg at 15%. To me.
I just finished some climbs with 15% sections, and my quads feel it. Aerobically, not so bad.
In this plot, look at where the "center of mass" is for 200 watts, then move up to 300 watts, then 400. I think you'll see that there's an overall pattern.
#52
Quoted: 4416 Post(s)
Liked 4,872 Times
#53
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Maybe it's the lower cadence that makes it feel harder. But I just looked at a steep segment from today, and my cadence was 65 -- not "that low". On a 7% segment, my cadence was 75.
#54
Cantilever believer
Quoted: 536 Post(s)
Liked 1,841 Times
After a short but steep climb in the Tucson area, a visiting friend asked what the gradient was. I had no idea, so I guessed 10%. He disagreed, saying it felt more like 13%. When we got home, I checked the state highway website, and they actually listed the gradients of the steepest roads in the state, probably for truckers, RVers, etc. It listed this particular road (Gates Pass) at 13%! I was impressed with my friend's guess.
I can attest to that 10% grade being a bit of a challenge.
This is the hill leading into my neighborhood, as seen from the Google Street View camera:
I rode this twice yesterday on my fixie (both up & down). I surveyed it with a level and rod a while back, and the maximum grade is 17%, but fortunately only for less than 100 leg-straining feet.
Another steep hill in north Phoenix was 9th Street coming into the Pointe Tapatio Cliffs resort. This private road is now closed and double-gated due to slope instability, but was a 20% grade my friends and I used to have grudge sprints up when we were in the mood. Had a few people run out of momentum before they got to the top and pull a "full Arte" as gravity won out over balance and down they went. Again we turn to (annotated and corrected) Google Street View - it's the upper street in this picture.
#55
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
[QUOTE=RCMoeur;23044416]Do you remember which website this was?...[QUOTE]
No, and you're right, it wouldn't have been ADOT. It may have been Pima County, but I can't find it now. All I see are biking sites and I wouldn't trust those.
Gates Pass Road doesn't strike me as particularly steep--I was surprised to see the 13% number, somewhere. I lived in Phoenix for a couple of years and never rode those slopes you mention. There were a few steep local roads in Prescott, where I lived for four years. Local lore was that they were 15%, but I never saw any engineering data to back that up.
#56
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
A bit more than a decade ago I corresponded with a guy who was trying my approach to measuring CdA and Crr. He had laid out the roads in a nearby subdivision but during the 2008-9 crash the developer had gone bankrupt so the place was empty and there was no traffic so he was using one of the hills he'd laid out for aero testing. He couldn't get the virtual slope and virtual elevation to line up: my calculations showed the hill must be about a meter taller than he'd designed. So he pulled out his Topcon GPT-3000 laser surveying instrument and went out there to measure the hill. The hill was about 1.2 m higher than he'd laid it out to be -- before the developer had gone bankrupt, he'd tried to save money on grading and moving dirt.
Likes For RChung:
#57
Quoted: 8287 Post(s)
Liked 9,061 Times
Was he an Englishman?
#58
Liked 9,061 Times
Possibly for the same reason some people (probably the same ones) seem obsessed concerned with collecting and recording all kinds of detailed route data and/or personal performance "stats" for every ride, as well as the various devices they can buy and use to better collect and record that presumably all important data.
#59
Liked 4,872 Times
#60
climber has-been
Liked 3,567 Times
Power was pretty close, about 15% higher on the steeper grade. Both "high zone 3" efforts.
#61
Liked 4,872 Times
#62
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Cited in "The Dancing Chain":
Take the inverse of the grade, multiply by 7, and that's the ratio in gear-inches that one needs when standing on the pedals.
Example given: 10% grade = 1/10; 10*7 = 70 inch gear (I think I can handle that seated, with a bit of effort, although I would normally prefer to use something closer to 60 gear inches)
Extending this: 20% grade 1/5; 5*7 = 35 inch gear (I think I believe that one as a conservative estimate
Low gear on my mountain bike = 24 gear-inches; low gear on most of my road bikes is 39.5 gear-inches
#63
Quoted: 1401 Post(s)
Liked 1,886 Times
#64
Quoted: 18424 Post(s)
Liked 15,580 Times
I rode up this the day before in 90+ degree heat and high humidity. During an unsupported overnight camping/cooking trip. It was one of two 14% sections.
#65
Liked 15,580 Times
Check out this route profile:
COOPER PASS - A bike ride in Wallace, ID (ridewithgps.com)
I have camped in Wallace twice before heading back into MT. The above roads were not available on Street View at the time. As such, I always went over Dobson Pass to Delta, Kings Pass to Murray and then over Thompson Pass (the last 4 miles of which average something like 7.4%, with the final two averaging 7.8%) to get to Thompson Falls, MT. The above route is noticeably shorte, but has some intense grades, especially on the descent, the first three miles of which are almost all in double digits. And look at that unpaved section on Street View.
#66
Quoted: 2496 Post(s)
Liked 739 Times
Found this earlier this evening. Wrote a post about it but don't see it. Since you guys are still at this I figure why not.
#67
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
It will be interesting to see if there is a negative reply.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#68
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
#70
Liked 739 Times
If they've done it right the fluid will have just enough 'damping' to steady the ball. Still, my guess is that thing is quicker responding than a phone based app or standalone computer, at least as accurate, and just as free from 'jitter' (jumping around). Not too shabby at the price.
#71
climber has-been
Liked 3,567 Times
But it won't connect via BlueTooth to Strava app, and that's a deal breaker.
#72
Liked 4,872 Times
#73
climber has-been
Liked 3,567 Times
You are probably right, but it doesn't tell you what grade is coming up ahead or how far to the top of the climb. Knowing the grade I'm currently on is only of academic interest. It has no influence on my riding. But knowing exactly what lies ahead I find invaluable for pacing.
But now that I've been using a power meter for several years, that's my preferred pacing tool. I just keep the power in my target range, and just keep on pedaling.
#74
Liked 4,872 Times
Yes. When using hills as intervals, it's great to know how much farther it is to the top of a climb, and Garmin's ClimbPro feature will tell you that.
When I ride events in a group it's usually pretty obvious which riders know the profile of a climb and those that don't. I use ClimbPro to set my strategy and my power meter for implementing it.
Likes For PeteHski:
